#31 | |
bottom out? as in? what compress the shock? meagans ride like total shit compared to my 600 dollar suspension KYB AGX + GC Eibach. sorry man I dont know what your talking about. GC also sells bumb stops. Im sure with Konis my car would ride night and day. But I cant afford the fuckers right now.
Like Me on FaceBook ![]() |
#32 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
The front suspension has less than 2 inches of compression travel before you hit the bump stops in stock form. Lets say you drop the car 2 inches, now you have no travel at all. So then you cut the bump stops in half, now you have about 1.5 inches of travel. Not to mention that the sleeves themselves will likely interfere with compression travel. With that little compression travel you are almost sure to bottom out your suspension. Any full length adjustable coilovers will leave you with at least 2.5 to 3 inches of travel (if they are set-up right), which will be plenty of travel to avoid bottoming out. Also, how the car rides is a non-issue to me I ONLY care about how it handles! |
#33 | |
your argumnet confusing. The problem with GC cars that ride improperly is the SHOCKS the Valving! not the length. some one else back me up on this here
#34 | |
![]() Join Date: Dec 2006
#35 | |
![]() Join Date: Feb 2007
![]() ![]() Friends help you move. Real friends help you move bodies. |
#36 |
Prove me wrong then, someone post pics of their front shock travel with the ground control coilovers (with the weight of the car on the suspension on that corner). I will guarantee you that even with the bump stops completely removed there will be about 2" of suspension travel max (unless you are running 4x4 status).
#37 |
![]() Join Date: Nov 2005
what experience do you have with this setup? as stated i have had it since 2003/early 2004. never have I blown anything. then again im not wreckless by any means in my car and only sprited weekend cruises with different groups sometimes alone. bottoming out has never been an issue and suspension has plenty of travel. now i dont know if i would suggest going for the ground with this setup. because that is not what it is intended for but it only allows so much any way with the length of the sleeve. if your trying to drag a bumper the no GC is not for you. if you want to put your car on rails then give it a shot.
im not sure what kind of pictures you want ![]() ![]() here are two that i have handy |
#38 |
All you're proving is that a double height adjustable coilover will let you go lower than a ground control setup with an OE replacement shock. Good for you, you're right. Unless you do something to the shock, you won't be able to lower the car as much without losing a lot of suspension travel.
As for the ride versus handling relationship, they're a lot more connected than everyone seems to realize. All those bumps and the harshness you feel at the driver's seat has to come from somewhere. So if it is getting transmitted through the tire into the suspension and into the chassis, then what kind of fluxuations in vibrations do you think the tire is seeing. That's bad for grip. The shock is meant to control the accelerations that the tire and the chassis experience. So a good ride will allow the car to handle better than a harsh ride. Of course, it won't ride like a caddy, because things will be happening a lot faster due to stiffer components, but it can still ride nicely. I've built dampers that ride nice and perform better. On the street, they were perfectly fine, not much harsher than a stock Accord, and on the road course the benefit of this ride quality was seen in several sections of the course where there were some larger bumps or rougher sections. These sections were unsettling a lot of the car, but our car could go right over them with no problems. So a spring sleeve setup is not something for people who want to slam their cars or don't really know what they're doing. There are a million different ways to do the suspension and they all have their pros and cons. It depends on what you want and what you care about. Tim |
#39 |
That pic is totally at the wrong angle to see what I wanted to see, but the set-up looks a little different than I was picturing. I was thinking like the honda fags where they just set a sleeve in there. My bad guys, I guess its not so bad.
#40 |
thats the reason you have those little red things in your info. because you post like you have unlimited experience when in actuality you have very little or none.
please note this was not a bash or petty jab it was just a suggestion on how to improve your rep since you seem to struggle |
#42 | |
hey steve, how much did u pay for that setup, kyb agx +GC? how stiff are you running? any problems yet? for how long have you had them? |
#43 |
![]() Join Date: Dec 2004
You can find AGXs for like, 600ish.
I was planning on running GC sleeves with Koni springs, and Swift dampening springs. One of my buddies had the Koni Special, and swears by it to the death. Too much damn hearsay nowadays. It is GAY. |
#44 | |
![]() Join Date: Apr 2003
im REALY glad there is someone here with proper brain matter. All the coilover sackriders should read a bit on proper suspension setup.
#48 | |
![]() You can find KYB AGX for about 300-400 bucks brand new Tien Camber Plates 120-175 depending on new or used GC Sleeves and coil kit + 1 hour of fabrication 400 + tears of joy If your going to use the AGX shocks use a lower spring rate than I did for street. 375 Front and 300 Rear should be perfect.
#49 | |
![]() Join Date: Aug 2005
They are not on the car yet, thus the "off the car" pictures. ![]() I still need to get around to ordering the GC coils and rear koni shocks. I will be ordering 400/350 springs w/ the GCs. |
#50 | |
for me im gonna be riding on motons and gc for my s2k. when i get it. |
#51 | |
#52 | |
What rear shocks are you using? Yellows, like AceinHole? Or something else? And to the other guy that posted, why would you need ground controls with Motons, that makes no sense at all. |
#53 |
Wow I'm glad i saw this thread, I've been obsessing over what to do with my suspension since I will finally have some money. Sounds like ground control is where its at in terms of performance. +rep is on its way.
#54 | |
I have a setup almost identical to PJ (aceinhole) with the exception of the 8610 RACE insert, these do require custom housings, especially if you want to gain back some inner tire clearance on the S13 chassis. For the rear, I'll be reusing the koni yellow with GC hardware for the time being, but will switch over to an 8610 in a custom housing to work with a Z32 rear upright. Here is what mine looks like currently... still waiting on the rest of my GC order to show up. I'll be running some 550lb springs up front and 400lb springs in the rear. ![]() Where the glan nut is threaded into the top to secure the insert into the housings. ![]() |
#55 |
Correct, they are held in by a round head hex bit bolt/lock washer. I'll probably be using off the shelf Koni rears also. Cool thing is w/ this setup once you have it finished you can just swap out shocks and springs. S chassis stock struts are dime a dozen. If you eff it up, get another one.
#56 |
![]() Join Date: Jul 2001
This is friggin great.
Evolution. Added to the logs of "common 240 lore". Life is Good. A year or 2 ago, this thread would've been 3+ pages of me, Drift Freaq, and a few other vets trying to bat down the overwhelming hordes of ignorants who swore GC's were just the same as DropZone or APC or any other eBay-ish manufacturerer. Arriving late to the thread, and seeing it already pages long, I expected the worst. Overjoyed am I to see so many Zilvians with CORRECT and ACCURATE knowledge on this subject Finally! I luv u guys ![]() I guess I'm just all sunshine and buttercups today ![]() Must be cuz this is my Three Thousandth Post ![]() |
#57 |
Fromxtor, so wait, are you saying there's something at the bottom to hold yours in? Or have you not welded on a threaded section for the gland nut on the top yet?
But anyway, I like the 8611, the 8610 is also good, but the compression curve didn't match the numbers I was looking for the last time I ran the numbers. But I think it was for an 600/500 setup. As for the rear, I'm not sure if the off the shelf yellow is the best option. I mean it will work, don't get me wrong there. But I just wish there was something a little more comparable in price and quality to the 8611 for the rear. But Koni doesn't offer any twin tube, double adjustable shock that would work for the rear for approximately the same price. You could always use a strut insert in the back and it should work fine. Or I guess there is always the option of having Koni convert a yellow to double adjustable and well they're in there, they could also revalve it. I can't remember what it costs for them to do that, but it wasn't cheap, $400-500 per shock, I think. But in the end, you would still have a pretty nice setup. As for ground control, just look at what I posted before. If you guys are that into this and want to save some money, you can find sleeves, collars and hats other places and then get Hypercoils springs from a lot of places and it will probably come in a good bit less than ground control. I'm not saying buy the ebay crap, but there are a lot of good quality pieces out there that will work for this. And whoever said swift springs, why would you waste money on them, when there are better options easily available in the states. Hypercoils is my obvious choice, but even Eibach (who makes ground contols springs) would be better and cheaper than swift. Tim |
#59 |
Right, the yellows do, but I didn't think the 86 series did.
#60 |
i have off the shelf gc's and illumina's on my FC. im no suspension god but its a good setup.
i got the gc's on some blown stock shocks for $150, and it was horrible when i ran it for fun until the illuminas came in. but once the illuminas went in, it was smooooth. with camber plates itll go as low as any other coilover in the front, the back is still limited, but its possible to get shorter springs to fix that. ive had it low enough to rub 205/50/16's up front on the frame rail above the tire under normal braking and never bottomed out the shock. it isnt as stiff as the namebrand one piece coilovers, but its still plenty stiff, and they still work great. its night and day from stock and handles great when im not sliding, and when i am sliding. car is so much tighter with them, it feels like a whole new car. yeah i went with it because i got a killer deal, but its still a good setup. |
