Old 11-27-2007, 03:45 PM   #1
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
Electrical Gremlins...maybe bad ground?
Ok. So ive had my Battery Relocated for 2 years. But recently I had my starter go out (along with a laundry list of other probs). I replaced it. My car wasnt starting still. So I redid my distribution block all new connections, new terminals, and a fuse block.
I think my problem may be the ground in my trunk? I'm not sure. I'm looking for a good solid place to ground it, but im not having much luck. A local car audio guy said that even grounded to a solid piece of metal in the trunk that it still may not be completing the circuit.
any advice on where to ground this or what may be wrong.
oh and the car starts fine when i hook up my jump box to the power wire and ground in the engine bay.
heres some pictures.
jumping the car from the Box to the power wire and ground in engine bay.
power wire distribution block
ground? bad?
any help is appreciated.
CoasTek240 is offline   Reply With Quote
Old 11-27-2007, 10:09 PM   #2
aznpoopy
aznpoopy's Avatar
i ground it using the spare tire tie down bolt thinger
Old 11-27-2007, 10:19 PM   #3
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
does anything else work ?
will it just not start or are you getting nothing at all?
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 11-27-2007, 10:33 PM   #4
jsuhs14
jsuhs14 is making a name for him/her selfjsuhs14 is making a name for him/her selfjsuhs14 is making a name for him/her self
Send a message via AIM to jsuhs14
this might not be your problem but hey, it worked for me when i had a similar issue. the bolt on the alternator. might have come lose.
jsuhs14 is offline   Reply With Quote
Old 11-28-2007, 12:47 AM   #5
CoasTek240
CoasTek240's Avatar
everything works. just not starting.
the bolt on the alternator is tight.
Old 11-28-2007, 12:57 AM   #6
deesz
deesz is making a name for him/her selfdeesz is making a name for him/her self
I would say it is very simple grab a dvom and do voltage drops at the back of the car if you are getting 12v then i would check other things like the alternator and also the distribution block, the ground looks fine in the trunk. you can also check your grounds in the engine compartment
deesz is offline   Reply With Quote
Old 11-28-2007, 01:17 AM   #7
EAT Motorsports
EAT Motorsports's Avatar
EAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of lightEAT Motorsports is a glorious beacon of light
Send a message via AIM to EAT Motorsports
if you have extra wire run it back to the front and ground it to the motor if it starts the its a ground problem in the back, or get really long wires for a dvm and try to see the resistance from the front to the back...
EAT Motorsports is offline   Reply With Quote
Old 11-29-2007, 09:53 AM   #8
CoasTek240
CoasTek240's Avatar
Well I finally extended the ground cable and replaced the + and - terminals. I also installed a 100 amp fuse in between the battery and the distribution block in the engine bay.
cranks up perfect now.
thanks everyone.
