#121 |
![]() Join Date: Mar 2006
uhm 225 is not wide... wrong thread
![]() I would fit it on an 8... 7 ur maybe talking 215... imho... to really benefit from the full thread... Edit: my dad runs 225/50/16 on a 16x6 lol.. sure itll work but yea it won't really be solid... he bought new 16x7.5 wheels though ![]() |
#122 |
#123 | |
Because if it isnt, then you obviously have the reading comprehension of a house cat. There are guys on here running 9-10" wide wheels with way more rubber than a 225 on stock fenders and youre asking if a 7.5 on 225s is too wide??
#124 | |
![]() Join Date: Sep 2005
Unless you have some crazy offset rims that setup will work just fine. I ran a 225 on S13 SE rims
#125 |
a 225 tire will be pretty much perfectly square on a 7.5" wide wheel, meaning your sidewalls will be pretty much vertical, no bulge nor stretch.
#126 | |
![]() Join Date: Jan 2007
Correct, I was asking if the tire would fit the rim, not the rim/tire the car.
In the market for a Clean Coupe |
#127 |
![]() Join Date: Jun 2003
Monty - looks good, you gonna lower any more? With a bit of a pull, you could go at least an inch lower and still have all the travel I assume you want.
![]() Team Pterodactyl SHARK ATTACK!!! LookoutDrift |
#128 | |
Another issue I have is that I live in an area that is very hilly, driveways and alot of the local businesses have steep entrances that cause low cars issues with scraping entering/exiting. I do have an Eastwood fender roller in the garage and will be using that and whatever else it will take to roll/pull the fenders to fit what I have now. I'm sure with the spring rates that I'm running that it probably isn't needed unless I have an off at high speeds... which is more than possible with my local track and lack of ABS. I was able to take a few more pictures from the front and back after finishing up the install this last weekend... to bad there's still snow on the ground here or I'd be out driving it ![]() ![]() ![]() |
#129 |
![]() I've had stretched tires and now i'm looking for as maximum amount I can put down. Sold the te37's 18x9 +10 245/18 Bridgestone re-01r 18x10.5 +15 265/35/18 Bridgestone re-01r The shine work wheel is what I currently rock on my s14 17x8.5 +44 w/ 25mm slip spacer 245/40/17 (wish I had gone bigger) 17x9.5 +44 w/ 5mm slip on spacer 275/40/17 I have a plently of room for 285. Folded the lip up, that was all the mods ![]() ![]() ![]() ![]() |
#130 |
Cool thread! Nothing crazy by any means.. but on my S14, here's MT ET street bias plies 26x11.5x16 on a 16" mustang wheel (sorry don't know the offset.. internet probably has it somewhere. i believe the wheel is 8" wide but don't quote me on that).. fender was unrolled during fitment picture. It clears when the car isn't low but eventually I rolled the lips cuz the car went lower. I share the drag wheels with a friend who has an FC. Fits pretty decent on both.
![]() ![]() On the street/turn track I'm running 275/40/17 R and 255/40/17 F, RT-615s on R33 wheels (17x9+30). No spacers. Sorry no good pics of it |
#132 |
Buddy of mine put a setup on his car
s14 275/40/17 Front R33 17x9 +30 Roll the front lips over and liners come off (tein coilovers) 275/40/17 Rear R33 17x9 +30 Roll the Lip and your good to go. |
#133 |
any spacers? i find it hard to believe that he could fit 1" more tire on the inside compared to my setup (225 on R32 GTR wheels with c/o). there's barely any room as it is.
#134 |
R32 GTS wheels are 16x6.5+40 and R32 GTR wheels are 16x8+30... I run GTS wheels on mine... it all depends on coilover/damper housing setup/suspension settings like camber... and banging/no liners :P Also tire/height/sidewall profile etc.. matters when it comes to fitment
*Edit* Double post Last edited by a_ahmed; 01-09-2008 at 05:43 AM.. |
#136 |
edited. i figured everyone could figure out/assume i was talking about GTR wheels. i left out all the other info because it's superfluous.
#137 |
![]() found this image on the internet (credit to whoever's photo it is) of my car (after redline time attack where I was a last minute replacement for my cousin) with said r33s no spacers. rt-615's 255/40/17 F, 275/40/17 R. rear fenders are rolled a bit, fronts are stock, fender liner still in place. I tried putting the 275s on the front (tein flex coilovers) and had fitting issues. aznromeox says his friend did it, but the inner tire sidewall hit the spring on mine (factory camber settings at the time). Not saying it's not somehow possible but I didn't attempt much further (don't want to use spacers or crazy camber just yet) With 255s on the front no spacer, the rim itself is maybe 3-5mm away from interfering, and the lettering on the inside of one of my 255s has just barely been rubbed away from the spring. I need to pull the coil towards the inside more before tightening to clearance it, then make camber adjustments up top at the perch. Haven't gotten around to it cuz of time, but the rubbing is very surface (raised lettering only) and has since stopped. |
#138 |
![]() Join Date: Mar 2007
maybe with camber bolts in the lower mounts of the tein coilovers and then setting the camber plate to full negative he was able to gain some clearance to the strut around the spring perch for such a wide wheel?
just an idea, I know a lot of guys tinker with using camber bolts in both locations on the knuckle on each side of the car and sometimes at all four corners of the car, STIs do it to gain neg. camber and some do it to gain inside wheel well clearance to the suspension.
cardomain.com/id/LS1T56FC = my crazy ls1 v8 rx7 = sold |
#139 | |
I'll have to see If I can get pictures of it. Its pretty impressive. BTW: hes running for tires Fusion ZRI 275/40/17 all the way around. From my experience with this tire, it seems a little bit narrower than some. To note, its damn close to the strut with maybe 1.5 degree of camber up front. Some may have issues with it hitting struts as I have had in the past, it depends on the coilover, some are larger in diameter than others. |
#140 | |
#144 |
![]() My ca rhas R33 wheels on it w 245/40 17 in tires w 10mm spacers. no fender trim or roll, GPsports coilover all around and big brakes. everything clears just fine, though the car sit rather high..pics to follow
#150 |
I just bought Work equips, and am wondering about what tire size I should run and how it would fit, and how much pull/roll I need.
98 s14, stance coilovers 18x9.5 front +8 18x10.5 rear +16 I want to run up to a 305 in rear if I can....what do you recommend? Anyone have pics of a similar setup? |
