Old 02-22-2008, 11:06 AM   #151
DrifterProdigy85
DrifterProdigy85 is an unknown quantity at this point
Send a message via AIM to DrifterProdigy85
I agree that the 3071R .63 will spool faster and make more power than the 2871R .86. I think the .86 housing is just restrictive. Ive always been curious of the GT2871R w/ .63 T3 housing. Might give the same top end power of the .86 with the spool that it lacks.
370cc can max out with only 10psi pending on the setup. When i dynoed my stock block w/ 2871R .86, Greddy IM, and HKS 264 Step 1 Cams, I was doing 315whp @ 14-15psi.
INeedNewTires, i believe you can hit your 400hp goal if you get a new Intake Manifold and some kind of Tubular Manifold. I like my Ichiba Vers II Manifold. Same design as the Tomei but half the price.
1995 Nissan 240sx
*RB25DET*
DrifterProdigy85 is offline   Reply With Quote
Old 02-22-2008, 11:07 AM   #152
xxchurroxx
xxchurroxx's Avatar
xxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to beholdxxchurroxx is a splendid one to behold
Send a message via AIM to xxchurroxx Send a message via Yahoo to xxchurroxx
377 HP and 320 ft/lbs of torque at 18 psi
s14 SR
V-mounted IC/rad w/ dual FAL fans
larger s13 throttle body
stock intake and exhaust manifolds
stock bottom end w/ no head work done
GT2871r .64
BC 264 in/exh cams
BC spring and titanium retainers
z32 maf
Apex'i PFC L-Jetro
exedy stage 2
fidanza flywheel
Deatschwerks 600c injectors
CS flat DP/elbow
Apex GT Spec with JDM 3" gutted cat
FYI, exedy Stage 2 clutches slip @ 320 ft-lbs of torque...hence the flatter torque curve.
v-mount ftmfw.
xxchurroxx is offline   Reply With Quote
Old 02-22-2008, 11:15 AM   #153
steve shadows
steve shadows's Avatar
^ Nice Torque curve!
Like Me on FaceBook !
Old 02-22-2008, 11:17 AM   #154
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
Originally Posted by steve shadows View Post
EVC?
I think the greddy Profec B and the PFC are the best in my experience in controlling the boost spike or drop off.
other than that you can try porting the wg door hole a little bit and like you said pre-loading your adjustable wg.
Yeah HKS evc V. like I said It's not having problems untill I try and set it in the 18-20psi range which was making me think that the internal wastegate was the problem. I may try preloading the wastegate actuator a little more and see what it does.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 02-23-2008, 10:12 AM   #155
s13envy
s13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nice
Send a message via ICQ to s13envy Send a message via AIM to s13envy Send a message via MSN to s13envy Send a message via Yahoo to s13envy
Can you give me specifics? I contacted BC and they arent being very receptive. Im going to a machine shop to get them looked over, but a little more info would be helpful.
only thing i know is that they centerline of the cams have been known to be off by a few degrees. basically saying the cams aren't timed correctly. Which can be fixed by adjustable cam gears.
s13envy is offline   Reply With Quote
Old 02-25-2008, 12:12 PM   #156
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Originally Posted by Steeles View Post
Steve, have you seen any issues with the stock internal wastegates not holding 20psi? mine seems to flutter between 20-25 when I try and set the HKS EVC. 15 holds fine. actuator is set at 10. alot of this has me wanting to get the .64 housing and swap out. (i was supposed to be getting a .64 when i bought mine. got an .86 instead)
From first hand experience with two different boost controllers, different sources (boost) and different wastegates, there really is no reliable way to hold under 15 psi and then 20 psi on the highside.
I've preloaded, un preloaded, done everything in the book.
The solution (hopfully) is getting the external gate provision on my stock manifold (thanks to Enthalpy himself).
Originally Posted by INeedNewTires View Post
here's my setup
S14 SR
Crower rods
Weisco forged pistons bored .020 over.
HKS cams 264's
rebuilt head
GT2871R .64
Hybrid IC
Apexi intake
Z32 MAF
740cc injectors
walbro 255 fuel pump
Apexi 3 in exhaust
Greddy elbow and down pipe
megan test pipe
Tuned with Apexi power FC
So at 1.3 BAR she made 363 whp and 353 tq w/ 93 octane
Get the stock exhaust manifold extrude honed and coated, get a Greddy Intake Manifold, and get a retune
Not sure if the I/C is hurting any or not either...i'm not an intercooler master by any stretch....
Old 02-25-2008, 03:38 PM   #157
Steeles
Steeles's Avatar
hmm thats what I was worried about. not that I mind running 15psi as the base but I figured theres two settings might as well use them. but I'll try bumping the base up to 15 and see if it'll hold. If I go external I'd rather go top mount and get the T3 housing for the turbo.
Old 02-25-2008, 04:22 PM   #158
codyace
codyace's Avatar
Trader Rating: (58)
Certainly an option as well. I've yet to see a t3 housing 2871r .63 dyno yet, so I'm worried that the tubular top mount options will hurt spool as well.
the greatest advantage IMO with that turbo is the stock manifold. It helps keep heat in the manifold, helping spool and torque. Not to mention OE is also divided/twin scroll sort to speak.
Old 02-25-2008, 04:52 PM   #159
Steeles
Steeles's Avatar
true, I've got my stocker in a box somewhere. may see about having a wastegate port added to it and coat it like yours is. ah well. other fish to fry on the current setup to handle first. like getting my timing dialed in lol
Old 02-26-2008, 11:33 AM   #160
rotation3x
rotation3x's Avatar
rotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choices
Send a message via AIM to rotation3x
What fitting do you guys use for your circuit sports oil line. I know it needs a restrictor fitting (which came threaded in my turbo) but will not thread onto my new line. The circuit sport line came with a fitting that threads into the turbo and line but dosn't have the restrictor.
rotation3x is offline   Reply With Quote
Old 02-26-2008, 10:42 PM   #161
codyace
codyace's Avatar
Trader Rating: (58)
/\ I have no clue. I bought the TAKA kit and restrictor.
Old 02-26-2008, 10:45 PM   #162
Steeles
Steeles's Avatar
+1 they've been on my car longer than the Turbo!
Old 02-29-2008, 09:36 AM   #163
rotation3x
rotation3x's Avatar
Can someone that has a gt2871r .64 tell me the numbers on your wastegate actuator? (there is a little sticker on it) I bought one from jgycustoms and my receipt says for fwd gti-r. I just want to make sure its right.
Old 02-29-2008, 09:53 AM   #164
water
water has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud of
Originally Posted by jspaeth View Post
Codyace....I was just playing on the numbers....again, the best measure is taking it to the drag strip, assuming equal driving skill
Thank you. I'm glad someone else realizes that dyno charts are more or less useless for anything other than tuning and a general idea of power. There's no magic in anyone's setup when the trap speeds they hit at the track are that of the average 360ish whp setups.
Moral: don't get caught up in numbers people.
water is offline   Reply With Quote
Old 03-03-2008, 09:05 AM   #165
s13envy
what hp would you rate a basically full interior s13 trapping 128? lol
Old 03-03-2008, 09:37 AM   #166
codyace
codyace's Avatar
Trader Rating: (58)
Very true! I love going to the stip and seeing trap speeds and thinking 'hmmm, a bit generous with that dyno'
At 18 psi, I was trapping 118. My dyno's are all at 20.....full weight s14...so I'd say the dyno numbers I have are spot on (400whp)for the setup.
Probabyl in the 440-460 range...
Old 03-03-2008, 10:14 AM   #167
McRussellPants
uh oh.
I was hoping it would last at least a month or so.
McRussellPants is offline   Reply With Quote
Old 03-03-2008, 10:15 AM   #168
steve shadows
Moral : Don't get caught up in most DYNOJET numbers people
Please Believe it.
Old 03-03-2008, 10:25 AM   #169
codyace
codyace's Avatar
Trader Rating: (58)
Please Believe it.
Hehe. I wouldn't care if the car made 350 whp, as long as it's faster than z06's and 997's on track is all I'm worried about
Old 03-03-2008, 04:33 PM   #170
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
i have
BC 264 cams
Gt2871r .64
Greddy intake manifold
740cc injectors
enthalpy tuned ecu
z32 MAF
hoping for 400 hp around 19-20psi.
just got to get her to fire up first.
idahotuner is offline   Reply With Quote
Old 03-03-2008, 06:54 PM   #171
DrifterProdigy85
My S13 full weight, did 117.5mph in 1/4 mile and dynoed 353whp. 1/8 mile was 90mph i believe. New setup does 93mph in 1/8 mile. still waiting for weather to let me go to the track for 1/4 times/speeds.
1995 Nissan 240sx
*RB25DET*
Old 03-03-2008, 07:42 PM   #172
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
s14 SR
GT2871r .64
BC 264 in/exh cams
z32 maf
Apex'i PFC L-Jetro
exedy stage 2
fidanza flywheel
CS flat DP/elbow
I am hoping to hit 400 at about 20 pounds, similar setup, just haltech/map sensored and 850cc injectors. Hopefully this should be tuned by the end of the month.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 03-04-2008, 12:16 AM   #173
codyace
codyace's Avatar
Trader Rating: (58)
What track do you goto again?
I need to get some place new...Island sucks. Talk about spinning all over....
Old 03-04-2008, 07:11 AM   #174
DrifterProdigy85
Cecil County. I was gonna go this friday but it looks like rains moving in. Its like $15 to race on friday nights. Real relaxed tech inspection too. ive got an illegal mounted battery and they never check for it.
1995 Nissan 240sx
*RB25DET*
Old 03-07-2008, 07:33 AM   #175
s13envy
Hmmm...only time I dyno'd my car with that setup, i had a slipping clutch and only 1 nut holding the turbo to the mani and it dyno'd 378whp. This was on a 2871R .86.
Old 03-07-2008, 07:55 AM   #176
OBEEWON
OBEEWON's Avatar
How come no one goes to Maple grove. Isn't that closer to you than Island Cody?
I miss Alabama. Midnight madness, $10 every Sat night starting at 12. I could get 10 runs in by 3. Usually left before they closed.
Old 03-07-2008, 02:35 PM   #177
codyace
codyace's Avatar
Trader Rating: (58)
Cecil is so far away
Island is actually closer. On that note, Island actually got repaved this past week! Lets hope it brings decent track prep with it!
Then you must have spun the shit out of your tires.
Old 03-08-2008, 08:17 AM   #178
jspaeth
jspaeth's Avatar
^^ If anyone wants to go to Atco, I will probably be heading there next weekend.
The good thing about Atco, is they don't make you wear a fire-jacket or whatever.
Last time I was at Englishtown, the guy let me by tech, but said that from now on, because it is an FI car that wasn't FI from the factory, I would have to wear a "fire-jacket"
Fuck that, I just go to ATCO now.
Daily driven
Old 03-10-2008, 11:14 AM   #179
Steeles
Steeles's Avatar
dammit. my 2871r bit the dust this weekend. out of nowhere i hear a whining noise. thought I suddenly picked up an alternator whine through the radio... but then i had 0 boost. checked couplers manifolds and everything. finally when it cooled down took the intake off the turbo and reached in. shaft play (side to side no front to back play) whining was the blades on the housing apparently.
Old 03-25-2008, 10:30 AM   #180
((sr)) kelly
((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute
2871r .86
hks 264 step 2 cams
740cc nismo
power fc
greddy intake mani
fmic
tubular mani
330 whp at 15 psi
290 whp at 12 psi
dyno jet
((sr)) kelly is offline   Reply With Quote
