Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
#271 | |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
#272 |
![]() Join Date: Sep 2006
I thought Progress also made an adjustable front and rear swaybar kit. If you're interested I can give you a quote later today.
-Jon
momentumgt.com - "building blocks of speed" |
#273 |
![]() Join Date: Jan 2003
BAm this season is goin to be great over here on the east coast guys. Just got my car tuned today on a dyno for the first time in 2 years after all street tuning.
suspension will be assembled in a week and dialed in. bumper brackets will be made and fitted in about 2 weeks. oh dyno yeilded 270whp 220 torque at 12psi on my S15 T28. Dyno numbers dont usually mean dick to me, but im excited since its the first time in the past 2 years with tracking this car that i actualy have a number instead of a guess. Deff goin to scoot along now, toques holds pretty good to redline, only drops about 10-20 ft/lbs. over 2k rpm after it peaks. ill have a nice little chart to post soon enough, assuming my buddy rememberes to email it to me.
***NASA HPDE Instructor*** |
#275 |
s14 rear subframe is sooooo much better thsn s13, the btm arms are at a much better angle and are flatter......hole centres on the subframe mountings are sliightly wider but this can be done with some custom alluminium subframe bushes....i think the difference is only 5mm.
the weston performance car in EDC had this dont last year ![]() |
#276 |
some pics of the shell swap i did on mine last week ready for the 08 season.....still lots to do though sadly
copied straight over from sxoc so apologies if some of the text doesnt make sense right then the shell swap! started off with my old shell being trailered down to sideways dannys barn/workshop ![]() and then we stripped it down ![]() ooh erm i wasnt doing anything........ ![]() my favourite part of the week! ![]() ![]() ![]() kiz enjoying my recaro a little too much ![]() engine had to come out which meant removing the gearbox drain plug for the very first time......turns out itd had a hard life as not only was there all this fur but several large lumps also came out ![]() then engine out so time for ghey pic ![]() then the rest of the front end comes off ![]() ![]() |
#277 |
then we had a little accident.........and also discovered how rusty my shell really was!
![]() ![]() ![]() so anyway after that it was time to get the rear subframe off and grab the bits i needed from it ![]() then hammer time ![]() and the left over pile of bits ![]() |
#278 |
next day was a long drive for me from northampton to norfolk to get the new shell (mucho thanks to lee for helping me bolt everything up!)
![]() ![]() ![]() then danny and i had to apply some MAN and drag a half ton shell onto the car trailer so i could take it to the metal recyclers ![]() ![]() ![]() ![]() then the new shell came in to be stripped of looking beautiful for a lot of welding ![]() ![]() taped on wide rear arches ![]() cage propped in for photos sake ![]() then i got busy with an angle grinder so that it was ready for when danny got back to weld ![]() ![]() and welded ![]() ![]() |
#279 |
then the cage had to go in properly and boy was it a poor fit!
![]() and i had to see what this looked like ![]() rear strut brace welded in ![]() and then i fitted my 4inch intercooler but forgot to take pics except the on byebye posted earlier ![]() ![]() ![]() as you can see from the last pic its sat on a nice bit of inch box section which should help stiffen up the front end then lots of trim hacking so it fitted round the cage ![]() ![]() |
#280 |
also started to remove the rear seat supports to allow access for seam welding there, sadly we lost power on the last night of work we had available and as such we didnt get it finished
![]() ![]() the last saturday of the week was a mega depressing one for me as it was time for the shell to go to the metal recyclers ![]() ![]() ![]() though it turns out it weighed half a ton so i got £48 for it ![]() then on the sunday we had a mad rush to get everything packed up so i could go home ![]() ![]() ![]() and back home where it is to come back to pieces to have a bit more welding done and the bushes fitted along with some btm arm modifications ![]() ![]() |
#281 |
That really is a pretty good build and it looks like you are doing good work, but it just doesn't belong in this thread. If you wanna show-off your build you should write up a build thread. This thread is for discussion of track/autocross set-ups and pics of your car actually on the track, and NOT DRIFTING.
#282 |
#283 | |
![]() all this work is to enter time attack so i thought you guys might be interested........... |
#284 | |
if anyone notices the first 8 pgs are all me, old shit from long time ago. I like seeing the work everyone is doing, id much rathe rsee mroe videos and general setup improvements instead of bickering over track times though...
#285 | |
![]() some lovely lovely work btw! ![]() edit: hows the modifications to the ohlins coming along? i think my rears need rebuilding ![]() also your cooler set up was part of the inspiration towards my current location ![]() ![]() |
#286 | |
#287 |
ohlins cant be modified, the GC sleevs will not fit over hte massive shock bodies. So i just went through alot of trouble to get the stiffest stock style springs i could find, we will see how they do come the end of this month.
DYNO SHEETTTT!!!!!! ![]()
#288 |
Wait..... You're still using the ohlins? I thought you sold them, I saw them advertised. The stiffest stock style springs I have seen are the rsr race springs. 5 front 4.5 rear I believe.
#289 |
no one wants to buy them...so i might as well use them....
i have found sprinsg that are 6k 4.4k, just trying to varify how they will fit or even lower the car any more then it is....
#291 |
the ohlins springs these came with certainly were not 8/6....more like 180 lb and 165 lb.....WEAK!
power level doesnt have anything to do with spring rate. I want to run 7/5 because otherwise things are getting. I have been running on crappy spring rates for 3 years now (all track time) just so i could get more used to the car and how it behaved in a heavily shifting manner. Now that i am extreamly used to it and consistantly use it to my advantage on track its time to upgrade. Even if i had 5000hp a spring rate of 8/6, 7/5, 6/4 is all dependent on the driver and how they can handle the car and its reactions to throttle and steering inputs.
#292 |
![]() Join Date: Mar 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
so I have been searching and looking into suspension setups as I am going to be upgrading sometime soon. I have been looking in this thread mainly and the ground control thread because you guys seem to have the most knowledge about setups that actually perfrom. I just have a few question dealing with adjustable arms. When are adjustable arms actually necessary and which ones are necessary? I am looking at a koni and ground control setup but am trying to figure out the rest. Also for those on cali where would you be able to get an alignment done if you have adjustable arms? thanks for any info. Also this would be fr road race/autocross applications.
http://s165.photobucket.com/albums/u63/ajhartma/ 1990 240sx hatch....currently monster truck status, with sunken battleships. ![]() *Junkyard Scavenger* |
#293 |
As far as alignments go it is Darrin at west end alignment or fail! Darrin is the man! He's the only person I would trust to align my car. For corner weight and align he charges like $220, and it is WELL worth it. Just alignment is $90 I believe. The REALLY necessary arms are tension rods, RUCA's, and toe arms. If you really want to track/autocross your car though I would reccomend the trac arms as well though. If you shorten them up it helps the car "dig in" off the corner a bit more, which 240's really need. Make sure you at least get the subframe bushing collars and energy polyurethane bushings as well. It is also a good idea to get stronger tie rods as well as the s-13 tie rods are known to break. You don't need the bumpsteer adjustable ones unless you do something to correct the roll center in the front of the car.
#294 |
great info just the kind of solid answer i needed
#295 |
So I was at willow springs yesterday with Oli Thordarson that drives a slightly modified corvette who made a post on page 9, we were at streets of willow going clockwise with blowby and skidpad and he ran a 1:23 on race tires that weren't gripping all that well. you can't really imagine how fast or crazy it was riding along with him, you can only imagine haha he is a great driver no doubt one of the best i've ever seen. just wanted to put it out there for some of the people that didn't believe 1:25 and under were possible on a slightly modified car
http://www.amazon.com/gp/prod Amazon book! |
#296 |
a corvett with r-comps doesnt count as a "slightly modified car", they are already so much more capable than 95% of factory dressed cars. Suspension is half decent, especially if its a newer corvette, brakes, wheels width, power, etc... Take a plymouth laser and slightly modidy it.....then we are talking, or even a 240, or an EVO, WRX, etc....all way under developed than most stock trim corvettes.
im not a corvette lover or anythign guys, just realize how capable they are with just tires, i have talked to and been on track with many vettes and most of them have had just tires and brake pads....
#297 | |
![]() Join Date: Apr 2004
Cars I would like to have stock and never modify: ITR, Evo RS, Z06, GT3. |
#298 |
thats a very steady upgrade in quality.....ITR i would remove, not a great track car from factory nor very fast....to keep things within a reasonable price range id stick with Z06, EVO RS, STI, Elise, not much else off the top of my head i would choose and keep in the reasonable new factory price range.
#299 |
UPDATE!!!!
Suspension is done Camber - -2* F/R Caster - 6.5* F (not adjustable) Toe - 0* F/R all new ES bushings, sway bar links, Ohlins suspension and soon to be Cobalt XR2 brake pads. We will see how the suspension feels once i can get out on the road later today or tomarrow and moe it around a little to findout if there is anything wrong. I should be just fine, but i cant make that promise to myself anf just hope for the best. I am attending the NASA MA instructor clinic next friday and instruting for my first time that very same weekend at VIR. I am very excited and nervous at the same time. We ill see how everything goes, i should have some good video from Sat/Sun as well as Traqmate Data Aquisition for helping me improve my line and corner speeds, etc... Be ready for alot of information after next weekend. Its going to be good.
