S13 power window problem.
I have two issues with my driver side power window that I was hoping someone may be able to help me with.
1.) the window is slightly off track, how do I fix this? 2.) When I press the button for the window to go up/down, sometimes it wont do anything until i hit it a few times where you rest your elbow, then it goes up/down just fine. Any ideas? Thanks! |
theres 2 nuts and bolts to each window passenger and driver... take your door panels off check to see if they're in place take the plastic cover off too if u have any... its a really tight squeeze...(both of mine fell off and the window just stayed inside the door) they can get loose after 17 years of going up and down inside the car.. fixxable 20min tops
....and as for your button problem.. its the connection to the relay(lil box inside the door panel) the connector to this box tends to get loose... zip tie it with one or two so it connects really well .. very doable time it takes is also included in ur 20min doing the window |
