Old 09-04-2008, 01:19 PM   #1
Dirty Habit
Dirty Habit's Avatar
Dirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfectionDirty Habit is close to perfection
s13 Crank crank *grind*
Thats all Im getting when I try and start my car. Pulled the starter to see whats up. Had it tested, its all good, turned the motor, didnt see any broken teeth. KA24DE FYI.
Always started up just fine before. Just fixed cooling issues..now this.
Ideas. Everytime it cranks twice and then grinds.
Help is appreciated.
1982 280zx Turbo
Dirty Habit is offline   Reply With Quote
Old 09-04-2008, 01:31 PM   #2
Massimo Power
Massimo Power's Avatar
Massimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to all
Send a message via AIM to Massimo Power
Ive seen this happen before.. but each time has a been a different cause..
It could be the starter.. not being able to pop out far enough to grab the flywheel properly..
It could be the flywheel.. maybe 1 or 2 missing teeth out of 200..
it could be your battery.. not properly giving out enough amps to power the starter to puch onto the flywheel properly..
it could be the wiring. not making proper contact causing the starter to not funtion correctly...
any of those could be the culprit.. let me know if that helps..
www.massimopower.com
PH: 1(951)402-5386
EM:[email protected]
Special Thanks To:
www.aeperformance.com
www.domospeed.com/blog
For Their Continued Support
Massimo Power is offline   Reply With Quote
Old 09-04-2008, 01:33 PM   #3
WaNa-DrIft
WaNa-DrIft's Avatar
WaNa-DrIft is an unknown quantity at this point
imma have to agree with that guy...
Where ohh where to find my love...Silvia, please come to me once more.
WaNa-DrIft is offline   Reply With Quote
Old 09-04-2008, 03:09 PM   #4
Dirty Habit
Thanks massimo. Im gonna go have the battery checked or recharged, see what happens. I marked a tooth with a paint marker and cranked it all the way back around, no teeth missing that I could see.
Wiring is fine, went back through with a multimeter, just checking shit. So it could be the starter not lining up or the battery, hopefully its the battery.
1982 280zx Turbo
Old 09-04-2008, 03:24 PM   #5
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
check the grounding of the starter. there's a small little ground cable that goes from the motor to the body of the starter itself. i took mine off and roughed everything up with a dremel and that fixed all my starter issues. after that you could even try bolting a temporary ground straight into one of the starter bolts
otherwise it's gotta be battery or the (+) cable
96Turbo is offline   Reply With Quote
Old 09-04-2008, 03:25 PM   #6
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
sometimes hitting it with a hammer actually works in this situation, it can knock the silenoid smart
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 09-04-2008, 03:50 PM   #7
96Turbo
96Turbo's Avatar
^^yes, but we've already established it's a good starter (he had it checked)
so it has to be wiring/power supply
Old 09-04-2008, 09:08 PM   #8
180ways2slide
180ways2slide's Avatar
180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known180ways2slide is making his/her stupidity well-known
make sure the wire that gives the starter the signal has a good connection my car did the same and that little connector was not connected good
180ways2slide is offline   Reply With Quote
