Old 09-09-2008, 01:13 AM   #1
GTSR
GTSR is an unknown quantity at this point
My SR24 build
Hey all, thought I'd share with ya the progress of my ride. Pretty much completed now. cheers d
KRPS13 SR24
Engine Head
Hypertune 77mm TB Custom intake plenum
TOMEI 270 cams / Solid conversion IN & EX
TOMEI IN & EX cam gears
TOMEI Solid Pivot
TOMEI Shim clearance set
TOMEI gasket kit
TOMEI RAS
SUPERTECH double valve springs
SUPERTECH +1 oversized stainless intake valves (6mm stem)
SUPERTECH +1 oversized inconel exhaust valves (6mm stem)
SUPERTECH titanium valve retainers
SUPERTECH manganese/bronze valve guides
SUPERTECH Spring locators
SUPERTECH Valve seals
NAPREC rocker arms
NAPREC cam cap studs
NAPREC timing chain
ARP Custom half inch head bolts
ARP Stainless Intake and Exhaust Stud Kit
Power Enterprises new 90mm head gasket
Ported and polished head
Engine Block
TOMEI Billet Crank 91mm stroke
GReddy/Trust H beam conrods made by Carrillo with CARR bolts
CP 90mm pistons, anti-detonation grooves, skirt coating, double pin oiler & black tungsten pins
Power Enterprises F1 Black Metal bearings, crank end, main and conrods
ARP main bolts
DARTON cylinder sleeves
CNC billet crank girdle
Rosstuffbond harmonic balancer
S15 Oil Pump JUN Water Pump
Engine Accessories
TRUST Type R blow off valve
TRUST AirInx Pod filter
TRUST / GReddy Oil cap
TRUST Big Capacity Sump
TRUST / GReddy pulley kit
NISMO engine & transition mounts
CUSCO Oil catch tank
SARD silicone lines
SAMCO silicone rad hoses
EMBLETON overflow tank
BILLION Power Steering tank
Blitz silicone top radiator hose
Power Enterprise Belts
PIVOT Raizin volt stabiliser
SPEEDFLOW SS lines and fittings
BILLION cold air induction 3inch
Ignition
SPLITFIRE Direct Ignition system
HKS Twin Power Type-DLI
NGK Iridium plugs
Drivetrain
EXEDY hyper twin-plate clutch and flywheel
NISMO LSD 2 way 4.1
GTR32 diff / axles / craddle
SPEEDFLOW #3 Flull Clutch line
MAZWORX Z32 adapter kit with prop shaft
VG30 transmission with (PPG 5 speed straight cut gears coming)
Induction
Garrett GT3540 0.82
6Boost steam pipe exhaust manifold
HKS GT II 50mm wastegate
HKS Turbo shield
GENIE Front pipe
MAGNAFLOW high flow cat
TRUST cat back exhaust
Fuel System
HKS Billet Fuel Rail
HKS 1000cc Injectors
Sard #6 FPR
Sard Fuel Gage
BOSCH 044 external fuel pumps x2
TOMEI Intank fuel pump
KRC fuel filters
GOGEAR surge tank fuel
SPEEDFLOW #6 Teflon braided lines
Cooling
SUNLINE RACING Oil cooler kit with relocation
TRUST VSP-L front mount intercooler
TRUST / GReddy airbreather tank
TRUST Air diversion plate
KOYO 3 layer copper radiator
DAVIS CRAIG 12" thermos x 2
ARC Thermostat
NISMO Power Steering cooler
Electronics
EMS 4860
TRUST Profec B spec II boost controller
Blitz turbo timer
Suspension and Handling
TEIN type HA coil over suspension
KAZAMA Hicus lock bar
KAZAMA Pillow ball castor rods
KAZAMA Alloy subframe bushes
KAZAMA tie rods
KAZAMA tie rod ends
D-Project Rear Upper Arms
D-Project Traction Rods
CUSCO 7 point safety 21 cage
CUSCO front and rear strut brace
CUSCO Front Tension Rod Bar
CUSCO Master Brake Cylinder Stopper
NISMO Front Power brace
Brembo GTR33 Calipers front & rear
PROJECT MU SCR Pro rotors front
PROJECT MU SCR rotors rear
PROJECT MU Type NR Brake pads
PROJECT MU Inner shoes
PROJECT MU Brakelines
NISSAN GTR32 Non ABS BMC
NISMO Steering Rack bushes
NISMO Power Brace
NAGISA AUTO Strut brace
SUNLINE Steering Rod bush
Interior
RAZO race pedals
PIVOT Stepping boost, oil temp, water temp
PIVOT small shiftlight 3 pod dash gauge holder
OMP Kill switch
WORKS BELL Quick release
MOMO 'course' steering wheel
MOMO Compition shift knob
MOMO gear boot
BRIDE BRIX II seats
BRIDE Rails
BRIDE Trim
TAKATA Harness x 2
Cyberstork white dials
CUSCO E-brake Drift button
Exterior
BOMEX Carbon Aero side mirrors
MSports Carbon Diffuser
MSports FRP Bonnet
MSports type B Front bar, skirts, rear bumper and front fenders, flared rear guards
SuperMade Headlight Conversion (original Japanese)
URAS Flasher Kit D-Style smoked side indicators
VOLK GT-N 18x9+25 and 18x10+25
NISMO wheel studs RAYS wheel nuts
Potenza Tyres RE01
TOPSECRET Areocatch pins
Type X Kouki Taillights
C-West Smoked Taillight Covers
OMP Tow Hooks
Comming soon
Cusco front & rear sway bars
Do-luck cross bar ladder bar front and rear
Ikeya Formula Front & rear lower control arms
Midori hicas rods (replace factory toe)
GTSR is offline   Reply With Quote
Old 09-09-2008, 02:45 AM   #2
S13SilviaGirl
UGH Really?
S13SilviaGirl's Avatar
S13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfectionS13SilviaGirl is close to perfection
Very very nice! Glad to see another nice aussie car on here!
My Review Thread
Originally Posted by DTCSuperstar
I surf Zilvia naked in my home...
S13SilviaGirl is offline   Reply With Quote
Old 09-09-2008, 02:49 AM   #3
DreEzed
DreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfectionDreEzed is close to perfection
Droooll... . Your car looks nice makes me wish I had a hatch.
DreEzed is offline   Reply With Quote
Old 09-09-2008, 04:43 AM   #4
Master Chief
Master Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to allMaster Chief is a name known to all
What exactly is the Crank pooly ?
The build looks amazing !
Master Chief is offline   Reply With Quote
Old 09-09-2008, 04:55 AM   #5
irax
irax's Avatar
only way that car would be cooler is if it was dry sump, itb, and ran on HHO
irax is offline   Reply With Quote
Old 09-09-2008, 05:07 AM   #6
GKTECH
GKTECH's Avatar
GKTECH is making a name for him/her selfGKTECH is making a name for him/her self
Damn Aussies spending too much cash!
Nice car mate, and VERY nice build!
USA Warehouse now open
www.gktech.com.au
GKTECH is offline   Reply With Quote
Old 09-09-2008, 07:13 AM   #7
Style
Style's Avatar
Style is on the path to ruinStyle is on the path to ruin
show pics of the engine bay.
Style is offline   Reply With Quote
Old 09-09-2008, 07:43 AM   #8
JDS13
JDS13 is an unknown quantity at this point
Nice very clean!
JDS13 is offline   Reply With Quote
Old 09-09-2008, 07:47 AM   #9
sncs14
sncs14's Avatar
sncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond reputesncs14 has a reputation beyond repute
I don't say this very often, but, that is a BAMF build
sncs14 is offline   Reply With Quote
Old 09-09-2008, 07:53 AM   #10
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
car came out hot man alot of pricey parts to say the least
Old 09-09-2008, 08:07 AM   #11
bigtom
bigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymorebigtom is not welcome here anymore
very expensive but very nice. props for using good parts.
bigtom is offline   Reply With Quote
Old 09-09-2008, 08:10 AM   #12
blackej7
blackej7's Avatar
blackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really nice
Video please!!!
blackej7 is offline   Reply With Quote
Old 09-09-2008, 08:28 AM   #13
Z33dori
Z33dori's Avatar
That car... I love that car.
def gonna keep my eye on this... Insane parts list.. my god....
Old 09-09-2008, 08:42 AM   #14
ESone3
ESone3's Avatar
ESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of light
had the same rims, looks hard as hell!
www.illgarage.com
ESone3 is offline   Reply With Quote
Old 09-09-2008, 09:04 AM   #15
ROUGE180
ROUGE180's Avatar
ROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfection
Send a message via AIM to ROUGE180 Send a message via Yahoo to ROUGE180
Originally Posted by blackej7 View Post
Video please!!!
i would like to second that. What and amazing build. It looks bulletproof
ROUGE180 is offline   Reply With Quote
Old 09-09-2008, 09:09 AM   #16
Volchok
Volchok's Avatar
Volchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to beholdVolchok is a splendid one to behold
Send a message via Yahoo to Volchok
wow...wow....absolutely gorgeous...nice work...inspirational...
Volchok is offline   Reply With Quote
Old 09-09-2008, 09:20 AM   #17
orangejdmsilvia
orangejdmsilvia's Avatar
orangejdmsilvia is an unknown quantity at this point
Send a message via AIM to orangejdmsilvia
thanks for making US look bad....awesome build!
orangejdmsilvia is offline   Reply With Quote
Old 09-09-2008, 09:31 AM   #18
luvsr20
luvsr20's Avatar
luvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to beholdluvsr20 is a splendid one to behold
Send a message via AIM to luvsr20
my my my what a beautiful lookin whip, congrats on your build!!!!!!!!!!!!
luvsr20 is offline   Reply With Quote
Old 09-09-2008, 09:37 AM   #19
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
awesome build i am so jealous of your motor.
idahotuner is offline   Reply With Quote
Old 09-09-2008, 09:49 AM   #20
SILVIA_KIDs14.5
SILVIA_KIDs14.5's Avatar
Trader Rating: (-1)
SILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choices
Feedback Score: -1 reviews
+1 for using rare parts and utlizing mazworx for your block and head as well as the tranny look forward to seeing the numbers and times.
SILVIA_KIDs14.5 is offline   Reply With Quote
Old 09-09-2008, 10:11 AM   #21
Om1kron
Om1kron's Avatar
you just broke my penis. YUP, you did....
Wayne Edwards
https://om1kron.blogspot.com
Old 09-09-2008, 10:14 AM   #22
BRAIN_Z33
BRAIN_Z33's Avatar
BRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfectionBRAIN_Z33 is close to perfection
This build has inspiration and awesomeness all over it!!!!!!!!!!!!!
BRAIN_Z33 is offline   Reply With Quote
Old 09-09-2008, 10:15 AM   #23
1QUICK4
Stop or I'll Shoost
1QUICK4's Avatar
1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection1QUICK4 is close to perfection
Send a message via AIM to 1QUICK4 Send a message via MSN to 1QUICK4
so uhhh no numbers???
-383 RWHP & 407 RWTQ-
Review Thread= http://www.zilvia.net/f/showthread.php?t=201106
1QUICK4 is offline   Reply With Quote
Old 09-09-2008, 10:33 AM   #24
blitzsti22
blitzsti22's Avatar
blitzsti22 will become famous soon enoughblitzsti22 will become famous soon enoughblitzsti22 will become famous soon enoughblitzsti22 will become famous soon enough
Send a message via AIM to blitzsti22
nice build
blitzsti22 is offline   Reply With Quote
Old 09-09-2008, 10:41 AM   #25
silviakid2790
silviakid2790 is an unknown quantity at this point
i want some numbers on this thing.
its soooooooooo damn sexy
silviakid2790 is offline   Reply With Quote
Old 09-09-2008, 10:47 AM   #26
yingiang
yingiang's Avatar
yingiang is making a name for him/her selfyingiang is making a name for him/her selfyingiang is making a name for him/her self
wow, thats a lot of money invested, beautiful car. nice build. keep it up
yingiang is offline   Reply With Quote
Old 09-09-2008, 11:07 AM   #27
whereda40at
whereda40at's Avatar
whereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nice
Send a message via AIM to whereda40at
that bitch is tight. videos and numbers are a must in this situation.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE!
10.79 @ 124 MPH WITH A 1.48 60'
whereda40at is offline   Reply With Quote
Old 09-09-2008, 11:36 AM   #28
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
i would trade my gf for this motor.
clark is offline   Reply With Quote
Old 09-09-2008, 01:21 PM   #29
S13SilviaGirl
UGH Really?
hahaha....I would be his GF for this car....lol....if I were single!
My Review Thread
Old 09-09-2008, 02:10 PM   #30
liv2drift045
liv2drift045's Avatar
liv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfectionliv2drift045 is close to perfection
Send a message via AIM to liv2drift045 Send a message via MSN to liv2drift045
could use 8mm of spacers or so in the rear or a fatter tire...
But its is BA none the less.
Great job.
StreetSliders.Blogspot.com
liv2drift045 is offline   Reply With Quote
