Old 10-12-2008, 08:52 PM   #631
Devens240
Devens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really nice
quick question. how would the fzigen fn's 17X10 +12 fit on the back of an S13, stock body?
EDIT: i plan on running 275/40/17, would i be better off with a higher offset?
Devens240 is offline   Reply With Quote
Old 10-12-2008, 09:33 PM   #632
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
I run 17x10 +18 with 275's
you'd be extended out 6mm ( 0.23in ) more than me
my fenders and pulled as you cans see from the pictures
I think it can be done ( with pulled fenders of course )
JRas is offline   Reply With Quote
Old 10-13-2008, 08:57 AM   #633
Devens240
ok thankyou. how much camber are you running?
Old 10-13-2008, 04:53 PM   #634
JRas
JRas's Avatar
-3 in the front
-2 in the rear
Old 10-13-2008, 08:14 PM   #635
mondojackal
mondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choicesmondojackal has made poor choices
Send a message via AIM to mondojackal
Originally Posted by racepar1 View Post
The 595-SS is the drifter favorite. The 595-RS is feddy's version of the rt-615. It is not quite as sticky, but it is really cheap. Feddy is also coming out with a 595-RSR which is supposed to at least match the azenis if not beat them.
ah, thanks for the clarification.
in you guys' opinion(s), what are some of the best of the inexpensive grippy tires. i want to put something pretty sticky on my daily, but i dont want anything with a really low treadwear rating, and i'd rather not spend a couple hundred on each tire, either.
mondojackal is offline   Reply With Quote
Old 10-13-2008, 08:46 PM   #636
Devens240
Originally Posted by JRas View Post
-3 in the front
-2 in the rear
ok. would i be better off going with a higher offset? like 17X10 +25? will i rub the coils? (stance gr+ pros) and plan to auto-x and want to have 275's in the back and 255's on a 9 up front
Old 10-13-2008, 09:05 PM   #637
RPS13-604
RPS13-604's Avatar
RPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really niceRPS13-604 is just really nice
255's up front you wont clear ur gonna be rubbing like crazy
RPS13-604 is offline   Reply With Quote
Old 10-13-2008, 10:12 PM   #638
mondojackal
depends on the offset and ride height and camber settings.
to Devens240, though..
17x10+25's will NOT clear the coils on an s13 (front) without a rather large spacer. at least 15mm. they will fit on the back though, for sure.
Old 10-13-2008, 10:53 PM   #639
Devens240
yes i know sorry i didnt specify, i meant 17X10 +25 rear. probably 17X9 +20 or so up front
Old 10-21-2008, 02:33 PM   #640
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
Hey guys im in Devens240' boat. I really dont want to get overfenders for the front.
Would 17x8.5 with I guess a bigger offset than +20 with an azenis 615 255/40/17 with a 5 or 10mm spacer work on the front with a little camber. Or does the size of the rim not matter that much?
And sorry for the newbie question but what does it mean to pull your fenders?
moses is offline   Reply With Quote
Old 10-21-2008, 06:47 PM   #641
golfer17
golfer17's Avatar
golfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nicegolfer17 is just really nice
Send a message via AIM to golfer17
Originally Posted by golfer17 View Post
YOUR CHASSIS: s14,
WHEELS: Work Emotion CR-Kai, 17x8 +25-f, 17x9 +38-r
TIRES: yokohama avs es100 235/40/17-f, dunlop direzza 255/40/17-r
MISC DETAILS: approx. 350whp, j30 diff. approx. 3100lbs with driver. these tires will hook the power in first gear but only on the best of roads and usually only on a good, hot day. the traction in cool to cold weather is terrible, but they really do well when the temp is above 80 or so and the roads have been heated by the sun.
I have 275/40/17 avon m-tech's and 245/40/17 falken fk450's waiting to go on, and by my measurements the rears should easily fit and the fronts will be as close as i want to get. the suspension is currently tein s-techs and tokico blue struts, but I also have stance gr+ coilovers waiting to go on that I am hoping will give even more tire clearance for future wheel and tire choices.
PURPOSE OF CAR: street, all-around performance
PICTURES: www.cardomain.com/id/golfer17
The coilovers and 275/40/17 rears are now on and at the last second I went with 245/45/17 potenza re760's for the front.
Glad i did the tires with the coilovers, as I think these front tires are a little bit too tall and too wide for a spring and strut combo. Currently the front left rubs in the middle of the plastic when it hits a bump on a fast corner and when I first had them at -2 camber(-1.5 now), there was only a finger width clearance (good enough) between them and the coilover spring. Next time around, I think I will sacrifice some ride quality to go with the low profile 245/40's.
For the rears, they fit quite well, with only slight rubbing around the edge on one side because the suspension is now so low that the subframe is actually leaning slightly to one side or the other depending on how the toe is set (It tends to lean to whichever side the toe is off, or the toe is probably off because of whichever side it leans too; have toe arms ready to install to get more adjustment). I am hoping to help fix this a little with some subframe spacers (just something I've had laying around I need to install) to stiffen things up. Also, I don't think it was rubbing at all when I was at -1.25 camber (at -1 now), so i will probably go back to the sportier -1.25,r/-2,f camber settings. As far as how much room to fit wider tires goes, there is a ton on the inside; makes me wish I had gone with an even higher offset and a wider rim.
Traction? Insane. Of course upgrading to coilovers at the same time probably helped out a ton, but I can't believe how well this thing grips and takes corners now. Straight line? Unbelievable. I can now hook on almost any road, any gear or speed, as long as the temperature is above about 50-60F. And when its colder than that it just spins them a little. Even on high boost! When I'm not even pointed straight!!! I can't wait to get it to the track and see how fast I can pull out of corners now that i can actually give it gas as I'm pulling out of a corner (with the old tires, I had to be pointed straight or in a higher gear, like third!)
golfer17 is offline   Reply With Quote
Old 10-22-2008, 06:58 AM   #642
moses
is there a reason that no one puts 8.5 rims in the front with 255? Will it fit?
Old 10-22-2008, 07:00 AM   #643
mikez97
mikez97 is an unknown quantity at this point
on the z i have re30's flat black
front 255 35 18 on a 18x9.5 +18
rear 295 35 18 on a 18X10.5 +15
mikez97 is offline   Reply With Quote
Old 10-22-2008, 07:03 AM   #644
mikez97
Old 10-22-2008, 01:07 PM   #645
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
Will fit fine... If you look through the thread, you will see there are ppl are running x9's in the front w/ at least 255. My post shows me running x9 & 265's (18's - on wide fenders of course, but use your imagination since you are running a smaller wheel & tire), 8.5 w/ 255 are easier to fit.
Ppl don't usually run 8.5 because that's not as common as x8 or x9.
EDIT: and to more fully answer your question, I've seen people run x9 +20 on the front w/ stock fenders, usually only 235's or so and a roll. For 255's, since you will balloon a bit w/ the sidewall, you'd want to slightly pull your fender if necessary depending on your ride height. And if you still don't know what that means, just search for "how to pull fenders" on here or google.
bew bews!
brokeAs240sx is offline   Reply With Quote
Old 10-22-2008, 03:50 PM   #646
longfellow
longfellow's Avatar
longfellow is an unknown quantity at this point
I have the 17x10+12's with 255 RT615's on my S14 and with -3* camber and pulled fenders it hardly fits. I say your better off with the +25s.
I plan on buying a pair of +25 FN's to so they clear and I can run -1.5* to 2* neg camber for better handling/ long tire life.
longfellow is offline   Reply With Quote
Old 10-24-2008, 05:09 PM   #647
moses
I just put my buddies 17x8 +28 offset with a 245/40/17 on my s13 front and it came out a little less than an inch and that means if I put a 17x8.5 +28 offset with a 255 and that is +10mm. How far can I roll the front fenders without it looking too bad?
Does it make a difference at all in clearence if i go with a 8.5 rim or 9 inch rim in front? The calcuator says no but I just want to make sure.
Old 10-25-2008, 08:18 AM   #648
moses
Old 10-25-2008, 12:11 PM   #649
JRas
JRas's Avatar
one word offset
read up on it, I think we have a thread in the tech section
Old 10-25-2008, 04:48 PM   #650
moses
I dont know why I didnt think of that. thanks
Old 10-26-2008, 12:54 AM   #651
mondojackal
one word offset
+1
offset is more important than width, IMO. you can make a 10 fit where an 8 wont just by picking the right offset.
me either, since you mentioned using a calculator.
Old 10-26-2008, 02:05 AM   #652
vodka2
Trader Rating: (18)
vodka2 has a spectacular aura aboutvodka2 has a spectacular aura aboutvodka2 has a spectacular aura aboutvodka2 has a spectacular aura aboutvodka2 has a spectacular aura aboutvodka2 has a spectacular aura about
Feedback Score: 18 reviews
what happend to all the pics? so i can stare at them for minutes at a time and think how im gonna fit these 18x11's and 18x12's lol.
vodka2 is offline   Reply With Quote
Old 10-26-2008, 09:19 AM   #653
moses
A 17x8 w/28 offset and 245 sticks out about 20mm in front with finger clearance.If I get a 17x8.5 w/ 255 I can go with the same offset and add a 5mm spacer. It would stick out about 26mm all together maybe more with the bigger tire. How bad would that be of a roll and pul in front?
Old 10-27-2008, 12:12 PM   #654
golfer17
golfer17's Avatar
i don't think it would fit with stock fenders and -2 degrees or less camber. if you read my post, the 245/45/17's I have barely fit with the coilovers (approx. .25" clearance between coilover and flush with fender at -2 degrees camber).
Old 10-27-2008, 10:16 PM   #655
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
Im gonna whore myself out some more
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 10-27-2008, 10:27 PM   #656
mondojackal
fine by me.. i love your car!
what color are you going to paint the car?
Old 10-27-2008, 11:16 PM   #657
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
Those 315's mlook lovely, what size Fenders ar those? 50's?
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 11-02-2008, 03:23 PM   #658
articdragon192
articdragon192's Avatar
I test fit new stuff. Only up front right now, will test fit the rears later.
Alignment:
-2.7° Camber
0.0 Toe
10.5 Caster
18*10.5 +15 CE28
285/30-18 BF Goodrich KD
Stock Fenders
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 11-02-2008, 05:17 PM   #659
brokeAs240sx
Trader Rating: (40)
nice! but Edgar:
1) maybe note it is z32/s13/s14? I'm pretty sure that's your Z, but not EVERYONE knows what you test fit rims on
2) better pics please, i.e. further back/diff angle so that we can see how close it lines up w/ the fender, etc.
bew bews!
Old 11-02-2008, 08:31 PM   #660
articdragon192
Lol, oh yeah, sorry to burst S-chassis owners bubble, but that's on a Z32. I'll get better pics this coming week.
It lines up close to what this 265 on the same wheel looks like. Just a slight bit more square.
Better pics to come soon. With more light and a real camera, lol.
Need help?
Click here
Still stumped?
Try this
Here you go.
