Polls Post All Polls in Here. |
View Poll Results: sell turbo and run NA, sell turbo and get bigger, or buy another and run twin | |||
Run twin hks 2835 on ls1 | 21 | 42.86% | |
sell hks 2835 and run single GT35r | 21 | 42.86% | |
Sell hks 2835 and run NA | 7 | 14.29% | |
Voters: 49. You may not vote on this poll |
12-03-2008, 03:11 PM | #1 |
SELL HKS 2835? Go bigger? Run 2 of them?
Alright, i have a hks 2835 i got from a friend. It is in prestine condition, and i wanted to use it on a twin turbo setup for the ls1 i am putting in my s14. But i kinda have thought to go with a larger turbo such as the GT35r as a single setup. And have debated the NA build as well.
So VOTE..
99rs coupe Currently Collecting parts for STi swap |
12-03-2008, 09:35 PM | #5 |
Exactly - also, what's the budget? That turbo's worth a large chunk of what a GT35xx would cost.
12-03-2008, 11:31 PM | #7 |
"GT35R" is too vague, hp ranges go from low 500s to high 800s, IIRC. So depending on the build and how much space you have, twins might be an option. For reference:
APS LS1/LS6 kit: Custom cast manifolds: They use T3 .84AR hot sides (50lb/min) with a .65AR compressor, times 2, for 600+whp at 8psi. And those turbos will be efficient to the upper teens, almost 20psi. Wowsors. I believe BLU808 was using a single Turbonetics T6x (don't remember exact size) for his LS1 RX7, and the power goal for that was large.
12-04-2008, 12:34 AM | #9 |
12-04-2008, 08:16 AM | #10 |
I say twin 30r's
Although i do love and used to own a 35r but i think twin 30r's would be great on an LS1 not too big not too small... And i'm sure they would kick out a lil bit more power than those APS turbo's |
12-04-2008, 12:44 PM | #14 | ||
Since my Dad and I built a forced induction setup on his Z06 vette (with me doing the research/work and him swiping the credit card), I would say I'm "informed" on the topic.
The reason you don't see more F-bodies or Vettes with twins is because there's no room for them - the frame rails come right up to the headers. So yeah, turbos would be different. Quote:
As above, if you're pushing the cylinder pressure/power limits of the engine, you're not too small. Big single would be big hp, but most likely not as fun to drive in any car, much less a 240. Even those twins don't spool up instantly (full boost around 2500rpm).
12-04-2008, 10:10 PM | #15 |
IF you really want to boost then go with/ LSX block with stand 2000hp,cast iron 6.o block with stand 1000hp, or 6.3/7.0 block with stand 1000hp! PSI ON a LS engine is going to be serious hp/TQ & $money$. Then you really have to look at your chassis and wounder if it going to put the power down. Best bet go with a BUILT RB26 For the S chassis if going over 700hp due too higher RPMS! 9000rpms rb26
12-05-2008, 12:39 PM | #16 | |
The cast iron blocks will withstand more boost than the LSx blocks, so everyone going for big power but still using a standard block would use those. I've never seen LSx blocks go above 1000hp. Why would a build rb26 be any different? Because it doesn't produce as much torque down low? You do understand that it would be heavier, with half the displacement right? Ugh. Anyway - whadda you think you're going to do Sac?
12-05-2008, 11:16 PM | #17 | |||
I think i am going to invest $ into a camshaft(not sure maybe you could give some insite), longtube headers (sikky manufacturing), and run a true dual exhaust from it. That along with a single piece aluminum driveline, and a reflash on the computer should be good to about 385rwhp. And just get used to the feel of the car. Then if i want more i can go to a large single. Cause unless i did a remote setup, i doubt a twin turbo setup would fit in the engine bay. Let alone clear the steering column. BUT THAT HKSGT2835 WILL BE UP FOR SALE SHORTLY SO STAY GLUED TO THE CLASSIFIEDS GUYS
12-06-2008, 02:26 AM | #18 | |
I totally agree with selling the turbo, swapping the engine in, and getting a feel for it. In the Z06, the LS6 felt anemic, like an NSX - the rest of the car is a 9, but the engine just leaves something to be desired (until you supercharge it ). I think of putting that engine in an S-chassis that's 500lbs lighter with 3/4 the traction, and it seems like a good fit.
12-06-2008, 06:06 AM | #19 |
I personally recommend a 454 aftermarket small block. Throw as much boost as you want at it and it can hold more than anything GM can offer, even the LSX block.
I'm building a 454 Motown iron block for myself, but I'm keeping it NA though. My motor now makes about 400 ft-lbs at the crank. My goal is to make about 600 ft-lbs at the crank with the new motor. A 50% increase I know this motor has a lot more to give but: a) I don't want to overstress the motor, although I'm not sure anything below 1,000 ft-lbs would be pushing it, and b) too much power becomes unusable. If I wanted to do something crazy I could throw a Vortech with mild boost and it can potentially make 700 bhp at the wheels easily, but that would definitely be overkill for a daily. |
12-06-2008, 06:31 AM | #20 | |
I think he means the LSX block, not an LS series block. iirc those were designed for high hp.
12-06-2008, 05:19 PM | #22 |
How much does your rat-motor weigh? Still uses the ZF 6-spd, or did you have to go T5?
12-06-2008, 11:19 PM | #23 | |
01-06-2009, 07:21 PM | #24 |
my cousin runs twin 2835's on his gtr
XS Engineering - Site Home 851 rwhp with crazy response! i say go twins...but i guess it all depends on what your car is built for |
01-06-2009, 09:46 PM | #25 | |
