#2851 |
please somone help me.. what are the these wheels and the sizes ? i need them!!!
just as title says i need these wheels for my supermade s13coupe. i would love the specs of these wheels and tires if possible .. thanks in advance guys
#2855 |
![]() Join Date: Apr 2002
^^^^ what the specs on those? It's extremely rare to see a gc with aggressive fitment (although the rear sticks out to much for me or needs negative camber/smaller tires). All I ever hear about is wheel bearings failing when this is brought up.
89 S13 hatch/////98 Subaru 2.5RS |
#2856 |
![]() Join Date: Jun 2007
i've seen worse , it's temporary anyhow
16x8.5 -16 epsilon with 225/40/16, 16x8 +13 ssr with 5mm spacer making it +8 with 205/40/16 , i'm super ghetto so it's on cut springs , enjoy temporary slightly good fitment. ![]() |
#2857 | |
its true our wheel bearing suck, GC are very hard to fit aggressive.
anything below +33 is considered pushing it alot of fender work is needed. my wheels aren't aggressive at all they just look it because I have GD rear end which gives me a 16mm wider track tires size is 225/50/r16 16/8 et+45 not agressive offset at all, have a minor pull and rolled fenders Quote:
real aggressive GC= ![]() ![]() the Aggressive thread for the GC and GF Faithful - NASIOC |
#2860 |
Updated pics of this with overs?
Sittin' Sidways Since 2007 |
#2861 |
![]() Join Date: Oct 2005
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
Shitty.
17x9 +20 (with 25mm spacer) 215/40 ![]()
www.realize-jp.net |
#2862 |
![]() Join Date: Mar 2008
could i pull off a 17x9+30on the front of my s14 with a 5 or 7 mm spacer. i dont wanna run 10mm because i dont wanna have to use extended studs. I have bridgestone NPG coilovers.
#2863 |
no...just no....
My Feedback |
#2864 |
![]() Join Date: Apr 2007
SSR AD's Front: 17x10.5 -4 / 235-40R17s Rear: 17x11.5 +6 / 255-40R17s To fit: Rolled front and rears, relocated chassis harnes and ran hood cable through engine bay, and slight pull in the rear. No wheel spacers! i know i need to go lower... first i have to beat out the front wheel wells with a sledge hammer!! |
#2867 | |
rules: ssr vienna sovereign front:18x9 +13 rear:18x9+3 +25mm spacer all around ![]()
#2868 |
![]() Join Date: Sep 2008
at the risk of being flamed for not rocking 18x12 -25 all around (random ballin' wheel size), here are some "wheel" fitment pics. keep in mind, this car is daily driven on shitty oregon roads. i was actually rubbing in the rear before switching to a smaller tire size.
![]() ![]() ![]() ![]() Last edited by shreeveco; 01-21-2009 at 02:04 AM.. |
#2869 |
![]() Join Date: Sep 2007
This thread is getting good again
* I know my non informational post just conrtadicted what i just said and ruined everything but, good work to everyone on this page |
#2871 | ||
![]() Join Date: Feb 2008
![]() ![]() ![]() ![]() ![]() Feedback Score: 20 reviews
<333
SPLparts.com * PoweredByMax.net Quote:
#2872 |
![]() Join Date: Oct 2007
Ok, so I'm trying to figure out if an 18x10 -7 wheel would fit (without MAJOR modification) on the front of my S13 hatch. I used a wheel offset calculator, and compared to a 18x9 +12 wheel, these would extend an extra 25mm. I already have Origin 20mm fenders and JIC coils. Would these fit and not bind with just some camber, tire stretch, and hammered lips? or would I need to tub the fenders for proper clearance? I looked through here for similar set-ups, but I didn't see anything.
Blow me, bitches. ![]() |
#2873 | |
BTW I have 17x9.5 -7 w/ Federal 595 235/40/17s. Soon to switch out to FK452s in 235/40/17s. |
#2874 | |
So other than this, you don't think there would be any clearance issues??
#2876 | |
My harness is out of the way, but the tire is still rubbing the GROMMET part. Guess it's time to put more caster in... and probably open another can of worms. |
#2877 |
![]() Join Date: Jul 2007
You should not have any problems with the harness. I not and I had a set of wheels almost exactly that size just a little more aggressive. Just take a hammer and get some anger out for a little bit on the inside and sport about -4 of camber. This is if you are planning on being pretty low.
http://walk2liv.blogspot.com/ |
#2878 | |
#2879 |
![]() Join Date: Oct 2002
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
That's where I had a problem. Search "harness" under my username and you should find some posts about how I fixed that problem. I'm leaving now and don't have time to find it. Somebody find it and post it. It worked out really well. I haven't had any trouble since.
#2880 | |
Be this the one?
