Old 02-09-2009, 04:20 PM   #811
G240
G240's Avatar
G240 is on a distinguished road
What would guys recommend for tire size. S14, 18x9.5 +20 all the way around. I'm ok with staggered tire fitment. My initial thoughts are 245/40/18 Fronts and 265/35/18 Rears. Would that work or do I need to rethink my tire selection?
Thanks!
G240 is offline   Reply With Quote
Old 02-09-2009, 05:09 PM   #812
RAMM
RAMM is an unknown quantity at this point
Do 285/40/18 all around. haha
RAMM is offline   Reply With Quote
Old 02-09-2009, 05:15 PM   #813
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
Thanks!
Nitto reccomends a 275/35/18 for a 18x9.5 in their nt01.
That should fit both the front and rear with a little r&p. No need to stagger if you've already got 4 of the same wheels.
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 02-09-2009, 06:30 PM   #814
G240
G240's Avatar
Makes sense thanks Sic.
Old 02-09-2009, 06:36 PM   #815
JRas
JRas's Avatar
JRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfectionJRas is close to perfection
Send a message via AIM to JRas
Thanks!
I wouldn't stagger, what power are you making?
255mm to inches is 10.03
265mm to inches is 10.43
275mm to inches is 10.82
a 9.5 inch wheel from lip to lip is about 10.5 inches
depending on what you want to run out of those.. I'd probably go with 265 being it's the closest.
JRas is offline   Reply With Quote
Old 02-09-2009, 08:04 PM   #816
mr.booie
mr.booie's Avatar
mr.booie is an unknown quantity at this point
i have some 14 inch wheels. 0 offset 8 inches in the back and 7 up front. what would be a good size tire? car is s13.
http://zilvia.net/f/image.php?type=sigpic&userid=70890&dateline=122764  6693
mr.booie is offline   Reply With Quote
Old 02-09-2009, 09:07 PM   #817
JRas
JRas's Avatar
you can do the math
covert the tire width from mm to inches
than know your wheel is one inch wider than it's spec'd ( from lip to lip )
pick the one that fits best
Old 02-10-2009, 07:28 AM   #818
G240
G240's Avatar
I should be making about 230 ish to the wheels once I get the car back. I'm leaning toward the 255/35/18 all the way around. According the the tire calculator provided a few pages back it would be the closest in aspect to the 16" OE rubber I am currently running.
Old 02-10-2009, 08:20 AM   #819
mr.booie
mr.booie's Avatar
you can do the math
thank you sir!
Old 02-10-2009, 02:43 PM   #820
ZilviaKid
ZilviaKid's Avatar
ZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the roughZilviaKid is a jewel in the rough
the dunlop z1 star specs, how long would they last if being driven on the street? i cant afford to run tires that will die after being driven for 2k...
2004 Nissan 350z
2002 Nissan Silvia
ZilviaKid is offline   Reply With Quote
Old 02-11-2009, 12:40 PM   #821
RAMM
It really depends on your alignment settings. That's a really vague question. Are you going to be driving hard on the street w/ aggressive alignment settings, then I would say they would last about a summer.
Look at different tire treadwear ratings. Generally a sticky street tire ranges from 140-220 utqg. So the higher the number the longer it will last.
Old 02-13-2009, 11:08 AM   #822
ZilviaKid
ZilviaKid's Avatar
thats not as bad as i though it would be. excellent.
2004 Nissan 350z
2002 Nissan Silvia
Old 02-14-2009, 10:00 AM   #823
dirtdiggler666
dirtdiggler666's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
thought this was cool check it out, this should limit the questions
Wheel / tire size calculator / comparer - RIMS-N-TIRES
dirtdiggler666 is offline   Reply With Quote
Old 02-20-2009, 01:02 AM   #824
hondanissan
hondanissan's Avatar
hondanissan is on the path to ruinhondanissan is on the path to ruin
excellent reference page dirt!...kinda.
hondanissan is offline   Reply With Quote
Old 02-22-2009, 09:46 PM   #825
Devens240
Devens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really niceDevens240 is just really nice
ok so i wanna run 17X9 and 17X10's on my s13 with 255's and 275's without pullling the front fenders. so if i go with a 17X9 with a 255 in the front what is the HIGHEST offset i can run before hitting the coils? (stange GR+ Pro). i wanna run 5zigen fn's but there 5 lug 17X9's only come in +15 and + 35 sooo i think i might get the +35 and put a spacer on it so i dont have to pull the fronts. and i dont wanna run alot of camber. thankyou
Deven
Devens240 is offline   Reply With Quote
Old 02-22-2009, 09:58 PM   #826
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
Do some research in this thread. There is a very useful link right above your post that will help a lot. Sic posted the max front and rear offset you can run. If you put all the numbers together with the link above you will find exactly what you are looking for.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 02-22-2009, 10:14 PM   #827
kingkilburn
Philosopher King
After doing some research it looks like you will want 17x9 +15 and 17x10+35. Based on the information available in this thread those sizes seem about perfect but I would recommend you look into it yourself as well.
Old 02-22-2009, 10:19 PM   #828
z3nk1dr1ft
z3nk1dr1ft is an unknown quantity at this point
FR500 Anthracite.
17x9 +24 (-1.7° camber)
17x10.5 +24 (-1.7° camber)
Stance GR coilovers
255/40/17
315/35/17
I was making 462rwhp on my ka-t then it decided to throw a rod.
Now im rocking a ~300 rwhp rb25.. thats now rocking 5 cylinders and a blown turbo.
z3nk1dr1ft is offline   Reply With Quote
Old 02-22-2009, 10:54 PM   #829
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
got some new pics in with the fresh paint job
as always
18 by 10 + 18 275 up front
18 by 11 + 18 315 in the rear
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 02-22-2009, 11:02 PM   #830
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
i need help from you guys... to keep it simple...
18x8 +30 (weak offsetttt), im thinking of going with maybe a 245 or a bit more in the back... you guys think a 10-15mm spacer mike fix the fitment on that bad offset?
it's a s13 fastback and i want NO PULL... already have a roll and thats what i want for the moment... the only other size they come in is 17x9.5 +15 great fitment but not much space for rubber without a pull...
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline   Reply With Quote
Old 02-22-2009, 11:27 PM   #831
palmdale_mob
palmdale_mob's Avatar
palmdale_mob is an unknown quantity at this point
Quick questions...
I am finally going 5-Lug, and have decided to get some MB Weapons 17x9 +27 all around
How would 235's fit up front on rolled flat fenders with no pull?
Also how would 255's fit in the rear, with a slight pull?
Car is somewhat slammed
Any help is appreciated
palmdale_mob is offline   Reply With Quote
Old 02-22-2009, 11:50 PM   #832
gsracer
Originally Posted by palmdale_mob View Post
Quick questions...
Rear should be no problem, the front will probably crash in to the coilover with that offset.
ANTI-STRETCH NAZI
Old 02-22-2009, 11:52 PM   #833
gsracer
I cant tell you for 100 percent on an s13 but the 9.5 would be a much better choice imo, tires are easy to change out if you decide you want to pull later that rims are.
ANTI-STRETCH NAZI
Old 02-23-2009, 07:51 AM   #834
palmdale_mob
Thats what I was thinking, Would a 5mm spacer makin it +22 make this doable?
Old 02-23-2009, 10:17 AM   #835
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
I have some new wheels the fronts are 17x9 +12 and the rears are 17x9.5 +12. I already have coilovers, and the car is not slammed to the ground, but it is lower than stock height. I want to know what width tires to put on the front and back, I prefer to have the back tires wider than the front tires. But I have not rolled my fenders, and I am not sure I am going to any time soon. Please help PM me
handinpants is offline   Reply With Quote
Old 02-23-2009, 10:45 AM   #836
xs240
xs240 is an unknown quantity at this point
17x9 = 255/40/17 you will probably need wider fenders although racepar1 pulled it off on 17x9+12 so maybe just a serious pull on front fenders.
Rear, 17x9.5+12, definetely will have to roll/pull arches... but you will be able to fit a nice 275/40/17 rear on that tire.
xs240 is offline   Reply With Quote
Old 02-24-2009, 05:27 AM   #837
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
So you wouldn't recommend 275/35/18 all around on an 18 x 9.5 +24 wheel on an s14? WOuld I have a hard time fitting it in the front?(stock s14 fenders) Or should I use bmw spec sizes like 245/40-f and 275/35-r to help with fender clearance? Im trying to keep the car as stock looking and flush as possible. Help me out here guys Im ready to order tires asap!
SuicidnS13 is offline   Reply With Quote
Old 02-24-2009, 07:31 AM   #838
xs240
well ideally a 10" rim u would want a 275, if there is a 265/35/18 sure..
Old 02-24-2009, 08:08 AM   #839
SILVIA_KIDs14.5
SILVIA_KIDs14.5's Avatar
Trader Rating: (-1)
SILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choices
Feedback Score: -1 reviews
Originally Posted by Prok0 View Post
315 bfg drag radials, stock fender.
more info like rim size width ect
SILVIA_KIDs14.5 is offline   Reply With Quote
Old 02-24-2009, 09:48 AM   #840
brunswick240
brunswick240 is making a name for him/her selfbrunswick240 is making a name for him/her self
Send a message via AIM to brunswick240
I was just showing my dad your youtube vids, he wants a v8 240 lol.
brunswick240 is offline   Reply With Quote
