05-23-2009, 07:46 PM | #4711 |
Man w/ CTSV & a Car Seat
NO, dont listen to anybody in here, leave the harness where it's at. The tires are keeping it clean by gently scrubbing road debris off it.
05-23-2009, 10:06 PM | #4712 |
Zilvia Contributor
Quick question on fitment, i have a set of Weds 3 peice wheels (similar to VS-XX face).....Supra firment 16x9.5 +44 and 16x10.5 +44 ....any hope of fitting on my S13 hatch? I have +25 bolt on spacers up front as well and rolled (not pulled) fenders in back.
thanks!
400x200 |
05-23-2009, 10:14 PM | #4713 |
that isnt even a question. You basically just told us what you have.
If you are wondering how they will fit... very poorly unless you are running like 0 camber. 18x9.5 +17 225/40/18 bfg gforce 18x10.5 +17 255/35/18 bfg gforce I want different tires cause these ones are tarded. also needa get some 15-20mm spacers for the front so I stop rubbing my coils. gonna match up the rears with some spacers too so I have an excuse to run more than -1 degree of camber. |
05-23-2009, 11:19 PM | #4714 | |
Here's a clean picture...it looks way higher because I'm on sunken ass gravel compared to grass.
Instagram - SJKnoop |
05-23-2009, 11:46 PM | #4715 |
Are you the guy who bought the MAE's from Erich???
Battle Idol Works 2015 |
05-24-2009, 05:23 AM | #4717 | |
05-24-2009, 09:56 PM | #4719 |
can someone help me figure out what gullflames i will need to fit my set up. s13 240, 20mm fronts, 30mm rears. i was thinking 17's in front, 18's in back. what offsets would be best? thank you. here is a site to what offsets the gullflames come in. any help would be appreciated:
GP Sports Gravity Gullflame |
05-24-2009, 10:18 PM | #4722 | |
Retired General
I'd run 20mm or 25mm spacers all around with that set up...depending on how much camber you want to run. |
05-24-2009, 11:12 PM | #4724 |
Work meister s1 3pc 18x9.5 -3 on a 20mm front fender and a 18x11.5 -22 on a 50mm. i know it needs more low im getting the inner lip cut off on tuesday then im gonna slam it all the way down
05-24-2009, 11:17 PM | #4725 |
Need help with tire fitment on rims on a s13 hatch.
18x8.5 +35 F and 18x10.5 +35 R widest tire i can put on rear with roll/shave. Spacers needed? I have z32 f/r calipers, tanabe coils as well. |
05-25-2009, 02:59 AM | #4727 | |
i got the same wheels but mine at 18*9.5 all around 12 offset before coilovers ill try and get better pics tmr morning |
05-25-2009, 06:07 PM | #4728 | |
SPLparts.com * PoweredByMax.net Quote:
05-25-2009, 07:17 PM | #4729 | |
more pics nowwww!!! lol are you running spacers in the front? quick question... i got a set of Gt-Cs a couple of months back and i wanna run them on my daily kouki... i wanted to do overs all around at first but i really wanna make them fit on the stock body... my question is how big of a pull am i gonna need, or would i be ok with just a good roll. i dont wanna run too much camber since its my daily.. i dont wanna get a second job just to afford tires. lol.. specs are 19x9.5 +9 front 19x10.5 -11 rear i have already thought about all of it, i just want some opinions from more experienced peeps.... thanks in advance.... |
05-25-2009, 10:45 PM | #4730 |
I am completely forgien with picking out 19" tires...and basically fitting 19s in general on S chassis. I know width and offset wise though your fronts will be fine with just a roll and 235 or 245 tire....probably a 245 since you'll probably have 35 series side walls.
For the rear on a S14 they'll stick out ~17mms further out then my rear wheels do. I pulled my rear fenders and am running ~-2 camber out back...so not a lot of camber at all. I'm also running 255/40/17s - which isn't exactly a short tire. If you ran some 245/35s out back (I am not even sure if you can stretch that because I'm out of my territory with 19s) with some more neg camber, like closer to -3 at least you should be able to get away with just a pull out back. Someone who's run sizes closer to that can fill in the gaps. To not clutter the page with nothing buy typing: My friend's S14 - 17X10s all around...I think 225/45s all around...I want to say +12 effectively up front and +15 out back? I will get his actual specs and post them up.
05-25-2009, 10:55 PM | #4731 |
Team Pterodactyl |
05-26-2009, 10:40 AM | #4733 |
im pretty sure for your 19's you are going to need 265's in the rear at least. go look around of z/g forums for tiresize fitment on 19's.
05-26-2009, 09:27 PM | #4734 |
little tease, some new old school shoes . for a bit of change 18x11-14
TRUE thing: True ////OFFSET\\\\ is acheived without spacers Running on E85 570whp Precision 5862....laggy as fuck. hate it |
05-26-2009, 10:06 PM | #4736 |
yep u right Loved it
05-27-2009, 03:40 AM | #4740 |
Wheel height
Do I need to change from the stock struts to put taller tires on the S13? The stock strut seems to have an inch of clearance with a 15" 50 series tire.
