Old 08-03-2009, 03:23 PM   #1
Nibras
Nibras's Avatar
Nibras is an unknown quantity at this point
Send a message via AIM to Nibras
s14 bolt
problem found thanks!
Nibras is offline   Reply With Quote
Old 08-03-2009, 03:29 PM   #2
SHARKERIOcoupe
SHARKERIOcoupe's Avatar
SHARKERIOcoupe is just really niceSHARKERIOcoupe is just really niceSHARKERIOcoupe is just really niceSHARKERIOcoupe is just really niceSHARKERIOcoupe is just really niceSHARKERIOcoupe is just really niceSHARKERIOcoupe is just really niceSHARKERIOcoupe is just really nice
Send a message via AIM to SHARKERIOcoupe
autozone?
the junk yard?
...the junk yard... free.99
Yeah.. Umm no.... Rules Violation
SHARKERIOcoupe is offline   Reply With Quote
Old 08-03-2009, 03:34 PM   #3
Nibras
Nibras's Avatar
Originally Posted by SHARKERIOcoupe View Post
autozone?
the junk yard?
wait so does it have a hole in the screw or nottttt
Old 08-03-2009, 09:09 PM   #4
g6civcx
g6civcx's Avatar
It looks like you're missing the bleeder bolt for the clutch slave cylinder.
You can get a replacement one from just about any auto parts store.
It's the same size as your brake bleeder bolts.
Old 08-04-2009, 08:05 AM   #5
projectRDM
projectRDM's Avatar
You've lost us.
The slave cylinder has both a banjo bolt and a bleeder bolt. You must have both, not using a bleeder bolt, all the fluid will leak out. Not using a banjo bolt, the fluid can't even get in.
FORMERLY R240NA
Old 08-04-2009, 08:35 AM   #6
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
i don't even see any copper washers either.
also just from the pics, that doesn't even look like the proper banjo bolt lol
clark is offline   Reply With Quote
Old 08-04-2009, 09:02 AM   #7
tunersedge
tunersedge is making a name for him/her selftunersedge is making a name for him/her self
2x yes this is most definitely not the proper bolt.
tunersedge is offline   Reply With Quote
Old 08-04-2009, 09:49 AM   #8
Driftastic
Driftastic's Avatar
Driftastic is an unknown quantity at this point
the bolt holding the fluid line on is called a banjo bolt. It should have a hole in it to allow fluid to travel through it, just like a brake line. then you should also have a seperate bleeder which is basically a bolt with a passageway all the way down the shaft that will allow you to bleed it, also just like brakes.
do yourself a favor and before doing anything more to your swap or more mechanical work go get yourself a book on the subject and sit down and read it.
Driftastic is offline   Reply With Quote
Old 08-04-2009, 10:23 AM   #9
Row
Row is an unknown quantity at this point
your missing the bleeder screw valvle.
Row is offline   Reply With Quote
Old 08-04-2009, 11:06 AM   #10
BustedS13
BustedS13's Avatar
god knows what happened to that thing. just go ahead and buy a new one at autozone. they're like 20 bucks.
Old 08-04-2009, 12:55 PM   #11
Nibras
Nibras's Avatar
i just bought a new hydraulic hose
240sx, bolt, clutch
