09-05-2009, 05:02 AM | #2191 | |
its all about bling bling these days u need to stop caring about wat LOOKS good and start caring about wat performs better we dont use mild steel because its cheaper we use it because it handles heat better stainless doesnt handle heat as good when it gets hot it changes shape and all sorts of shit this is why u get alot of stainless manifolds failing and cracking and leaking at the flange plate we get alot of customers come into the workshop with HKS, TRUST manifolds which have cracked and they ask us to make copy's of them out of steam pipe this manifold cracked then we repaired it and added more bracing and it still cracked again then the owner went with a steam pipe manifold and its going strong we have been making steam pipe mild steel manifolds for around 10 years and we sell our manifolds with life time warranty and in that 10 years we have only had 1 come back due to a crack the joys of stainless manifolds the only stainless manifold i would ever use is full-race normal 316 grade stainless like HKS, TRUST manifolds are junk Last edited by STR8E180; 09-05-2009 at 06:20 AM.. |
09-05-2009, 09:42 AM | #2193 |
I can agree with you on one thing that cheap stainless manifolds crack. The reason for this hks, trust, megan all those manifold are built with thin wall weak ass material so they can produce more manifolds for cheaper and put more money in there pocket. Now for my manifolds im prob using the same pipe as you just in stainless. I have never never never had one of my manifolds come back for anything iv been doing this with my friend danny for over 5 years now never 1 problem. We had built manifolds from 300hp civics to supras that have made over 1500 whp never any problems with our stainless manifolds. Looks do count on cars now a days people dont want u to pop your hood and see some piece of shit. I dont want shit looking products on my car do you???
You say you would use a full race manifold?? You know full race manifolds are made from stainless right?? BTW my manifolds are full race copies so I use the SAME materials as full race I just sell my hundreds of dollars cheaper cause im not trying to rip ppl off and my welds are just as strong if not stronger. Just a quick search mild steel and stainless both have about the same melting point at around 2700 degrees. |
09-05-2009, 10:44 AM | #2195 | |
"we dont use mild steel because its cheaper we use it because it handles heat better" Stainless and mild steel have very similar coefficients of expansion. On average a turbo manifold will expand ~.010". Mild steel has a coefficient of 7.3e-6 in/F where as 3xxSS has an coefficient of ~8.0e-6 in/F. That means with a 1300F Difference in temperature the 3xxSS will only expand ~.0005" over mild steel. The difficulty with stainless manifolds is a lot of people don't really know how to weld them. I've seen lot of cheap chinese companies that didn't back purge the welds, thus causing crystalizing. Beyond that there are several other factors to consider. I've seen several tubular manifolds using 16Gage tube. Hang a 30lb turbo from that without any support and it will stress the manifold with heat cycling regardless of material. Gas pipe is thicker than most tube in tubular manifolds. For 6 cylinder motors I have used Sch10 (.109 wall) stainless piping. I've still not had one of these crack or any manifolds I've built out of .083 wall tube. Its not so much the metallurgy as much as it is the process of welding and the dimensions of the material. My last issue with gas pipe is that its not seamless, it is welded. For the same size tubing and same materials, seamless is usually stronger than welded. The other problem I have with welded tube is that it doesn't flow nearly as well as seamless. Granted this isn't really a big deal with most applications but I've designed manifolds to be extremely efficient with the least amount of tumbling and degression of velocity. Like I said at the beginning, your work is well done. But don't post misconstrued information about stainless being a poor choice of material for manifolds when there are many other factors to consider rather than the metal itself. S14_Kouki has built some phenomenal stainless manifolds on that note, too. Last edited by TIG; 09-05-2009 at 11:50 AM.. |
09-05-2009, 11:34 AM | #2196 | |
I'm assuming that's a typo? Back purging does NOT create crystallization. It prevents it. And S14_Kouki... You need to tighten up those TIG beads. The spacing between them is way to much. Unless you're doing a root pass and that's a cap. If that's the first and only pass, they need to be tighter. |
09-05-2009, 12:20 PM | #2198 |
^Good call!
On a side note... I think I'm gonna cave and buy a stupid MIG welder.... Tired of doing EVERY FUCKING THING with a TIG... It's becoming a pain in the ass... especially body work. It doesn't like the TIG... |
09-05-2009, 12:25 PM | #2199 |
its some thing we wont see eye to eye on
ill always chose mild steel steam pipe over stainless bends for exhaust manifolds even if its thick walled stainless ill still pick mild steel steam pipe |
09-05-2009, 12:37 PM | #2200 |
TIG
Thank u for the complement atutt Yes, the beads were to far apart and they were fixed and I feel you on getting a mig I would love one as well for mocking up exhaust, dp's, ect ect STR8E180 We will not see eye to eye on this. But theres alot of things ppl dont agree on so you have your mild steal and ill have my stainless the fab work on the car is good tho I really like the intake manifold. |
09-05-2009, 12:50 PM | #2201 | |
I just need a MIG for body work mostly. TIG warps the fuck out of sheet metal, haha |
09-05-2009, 01:08 PM | #2202 |
I started tig welding first then went from there and leard stick and mig. Its so so much easier tacking exhaust under a car laying down with a mig then tig. Yes tig is not the thing to do sheet metal with. But I will pick up a tig welder over and mig welder anyday
09-05-2009, 04:56 PM | #2205 | |
From an 'engineering' perspective, seamless SS is definitely a great choice for auto manifolds, but from what I've seen the fact that mild steel is easier to weld perfectly is the reason it's the material of choice in other parts of the world. Welding SS perfectly isn't just a skill, it's an art lol.
09-05-2009, 06:24 PM | #2206 |
09-05-2009, 08:56 PM | #2207 | |
Lol... Maybe if I buy a new Dynasty 350! I beg to differ on the second part. I believe it's easier to weld SS perfectly as opposed to MS. Reason. Mild steel if FULL of iron and other impurities. Making it harder to achieve a high quality weld (in terms of an x-ray test) and a high quality looking weld. good quality SS doesn't have many (it shouldn't have any to be honest) impurities and iron in it. Thus, making it easier to get a good looking weld while maintaining high weld quality. Just my opinion. |
09-06-2009, 12:33 PM | #2209 | |
09-06-2009, 05:22 PM | #2211 | |
i had a GT3076R .78 twinscoll B4 this but sold it for the GT-K 500 its being built as a circuit car so i didnt want some thing to big wats the specs of the one ur building? |
09-06-2009, 05:47 PM | #2212 | |
09-07-2009, 02:10 AM | #2214 |
09-07-2009, 10:21 PM | #2215 |
^thank you ^
heres some of our other work since this is the fab section These are all supra manifolds we made Some collectors for the manifolds Some honda collectors Some random welding This is a 650-700whp ka-t we build intake, IC piping, manifold, DP, exhaust ect ect 1500whp supra manifold evo engine in a AWD civic making 650whp |
09-07-2009, 11:27 PM | #2216 |
looks like u guys push out alot of manifolds
its hard pushing out products like that here in australia alot of people use those cheap shit manifolds of ebay only the full serious performance freaks spend money on custom manifolds ill throw up some photos as well these are just random happy snaps taken from the workshop R33 GTR twin GT35 hypertune plenum BIG POWER! this is an RX8 running a custom V mount with GT-K 650 |
09-08-2009, 11:50 AM | #2217 |
Yea alot over a period of time lol we actully need alot more work things are slowing down.
Thats a awesome set up on the skyline good job. Pretty much we built everything on all these cars IC piping, IC end tanks, Manifolds, DP, exhaust, what ever needs fab work we did, Here is a 500hp k20 sidewinder one of our projects The fucking crazy teg doing like around 670whp We did everything IC end tanks, IC piping, manifold, DP ect ect The srt4 we are finishing up now this is going to be around 650whp And our friends fully Stock LS putting down alittle over 300 whp With everything built by use. |
09-09-2009, 10:05 AM | #2220 | |
