#33 |
how do these compare to say stance or KTS ? Im looking to buy a pair of coils within the week. And what your telling me is if a coil goes bad we can replace it for a brand new coil for 100$?
And also youve never had a coil go bad with track or daily use? Minus accidents? |
#34 |
If you have to have them within a week, then its going to be one of those brands because ours are going to arrive in 2 weeks (plus shipping time to you).
If I told you ours are the best then you may just think I am biased, If I were you I would ask people who own each type to tell you how they like it, and better yet get a ride in each car to see how you like it. Our coilovers have a reputation for being stiff without being bouncy and are known for going very low. We use 10/8kg springs coupled with a low compression damping, high rebound damping shock that is adjustable in 8 clicks instead of some rediculous number. One of the most unique features is pillowball rear upper with top spring perch whereas most others have rear springs right against the upper mounting plate. Not the entire coilover, its nearly impossible for the mounts and the spring, collars etc to go bad ~ the 100% new damper/shock is the wear and tear item and is $100 to replace. We debuted this design over 2 years ago here on zilvia and no one has contacted me for replacements without a crash story. You wont need replacement dampers in the forseeable future unless you abuse them. When you do need a damper you will not have down time because you are not waiting for a rebuild.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 08-13-2009 at 02:57 PM.. |
#35 |
![]() Join Date: Feb 2009
I ordered mine from you guys and recieved tham right when you said I would.
I opened the box to see one of the best sights in the world. Quality control is amazing. I haven't installed them yet, because it'll be a hot second before the car's done(debating on 2jz or not). But I can honestly say that from all the coilovers I have dealt with over the years that these are by far the cleanest, most high quality coilovers I have laid my eyes on. My mom described them as "jewelry for my car." lol |
#36 |
In time-out for misbehaving.
How many degrees of camber do the front coils allow? I have 2 friends one is running PBM coils and the other is running JIC coils and it seems that the jic's allow for much more camber.
#41 | |
if your mildly lowered you can get 3.5 out of it. $1760 CASH (+paypal if you wanna go that route) $1073.00 shipped $1060.00 shipped $1153.00 shipped, and They will be in stock friday or monday.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 08-27-2009 at 04:06 PM.. |
#43 |
$1055 shipped
$$$$$$$$$$$$$$$$$$$$$$$$$ IN STOCK TODAY ! $$$$$$$$$$$$$$$$$$$$$$$$$
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
#44 |
New shipment pix
S13 ![]() Jzz31,Jza80 ![]() S14 ![]() FC ![]() R32 ![]() adjuster,pillowball ![]() bottom brackets ![]() spring, locking collars ![]() replacement damper $100ea ![]() replcement springs now available in super short 10kg-135mm and 8kg-200mm $60/pair ![]()
#46 |
yes sir they do
#48 |
yes sir $1080
#50 |
superstylin! thanks = )
#52 | |
#54 |
...but we do know that they are arriving for customs inspection friday!
#56 |
thanks for putting in the good word Rob
***S13 sold out, all other types are still in stock***
#58 |
yes we do!
#60 |
$1067 shipped to you
