Group Buys Dedicated Forum for Group Buys. |
07-31-2009, 12:01 AM | #1 |
Trader Rating: (29)
Feedback Score: 29 reviews
(Feeler) Stealth-Custom-Fab S13 fender braces
Ok boys and girls...I am very close to the release of the S13 fender braces and I want to get a feel for how big they are going to be. I have a couple sets out as a pre-release/ R&D phase. So far the feedback has been great.
Here are a few pics. Price will be around $150.00 for a set plus shipping. Tell me what you guys think. Take care Jonnie |
07-31-2009, 12:41 PM | #2 |
Have you thought about triangulating the two bars?
What about picking up both the upper door hinge bolts instead of just one? The triangulation would add quite a bit of stiffness to the braces.
07-31-2009, 01:06 PM | #3 | |
EVERYTHING he said... triangulate the two and add the sencond bolt to the top brace and I will buy a set! Can we get a side shot to see the thinckness of the tube size? |
07-31-2009, 03:25 PM | #4 | |
Trader Rating: (31)
Feedback Score: 31 reviews
i'd be interested in a pair
Slip Gypsies Blog Quote:
07-31-2009, 06:25 PM | #5 | |
Trader Rating: (29)
As for the double bolts on the top, I did that on purpose so you would not have to take all four of the door bolts out to mount them. I will try to get some of the test pilots to chime in to let you guys know what they think. Thanks for the input Jonnie |
08-01-2009, 07:29 AM | #6 |
The bottom bar is in tension/bending, the top is in compression bending. Triangulating them keeps the bending component to a minimum.
What's the weight on the bars?
08-07-2009, 12:06 AM | #7 |
I'd take a pair. How far out are these?
I also need to get one of your front strut bars and your tension arm brace. BTW, you ever looked at doing a FSTB like rotorimp did where it braces against the firewall? I would love one like that + a master cylinder stopper if you can make one |
08-07-2009, 09:37 AM | #8 |
I didn't have any issues with taking all 4 of my door bolts off on my S14 when I installed my URAS fender braces. I just did two at a time, and you put them back in loose so you can move the brace enough to take out the other two. The doors stay put even with only a few threads on each of the 4 bolts, haha.
Just offering some suggestions.
Instagram - SJKnoop |
08-13-2009, 05:52 PM | #10 | |
Trader Rating: (40)
Feedback Score: 40 reviews
Only warning: for those w/ aftermarket fenders w/ those vents in the center, you will have to modify it accordingly because the bar will hit it; this is an issue with fender braces in general, not just Jonnie's.
bew bews! |
08-14-2009, 03:30 AM | #11 | |
Trader Rating: (36)
Feedback Score: 36 reviews
BTW, i think i saw you and your vert at UCI once by the engineering parking structure. You're ride is very nice!
08-14-2009, 03:39 PM | #12 | |
Trader Rating: (40)
You didn't see my post because it was in a Premium Member thread, so here it is copied out for you: Received one of Jonnie's (pre-release?) fender braces! Fits perfect chassis-wise. Even works for s13 convertible guys (we have a factory brace) w/ a lil hammering - will leave a small gap where it mounts toward the front, though (no clue if that really affects anything in the long run - a small flat flange or piece of metal should fix that right up). This setup worked great in combination w/ the other front reinforcement parts I got for the car - you can definitely feel it in the turns @ autox. Only bad thing at all is that aftermarket wide fenders w/ vents will not clear the brace. It looks like this is an issue with pretty much any triangular brace tho: These fenders were nearly flush before. I don't care much for these fenders anyway, so not a big deal - but others considering buying any kind of fender brace should take this into account.
bew bews! |
08-14-2009, 05:15 PM | #13 |
Trader Rating: (29)
Hey buddy thanks for posting up the install pics. I tottally spaced that these were going on a vert, with that extra brace, I could have sent you some spacers to kick them out a bit.
08-15-2009, 05:13 PM | #16 |
08-15-2009, 11:52 PM | #17 |
Trader Rating: (29)
Check out my web site...
Ask Luke how he likes his set. And as far as the tubing... it is the weirdest size I could find...lol. It is 1-1/4" by 1/2". This shit is tough...on the S13 braces there is a bend in the lower tube. On the prototypes I did not relief cut the tube. I had to get it red hot to make the bend even with my bender. |
08-16-2009, 12:29 AM | #19 |
I was about to say, give us premie's a discount, but its already a damn good deal. There isn't anything else to say. I'll be PMing you very very soon.
Next thing you should make are C-Pillar and Trunk braces!! GTSpec needs some competition. |
08-16-2009, 11:30 PM | #20 |
Put me down for a Pair. Def want to see the other bar in there too though. Keep up the good fab work!
There's not enough hours in the day. |
10-13-2009, 08:27 PM | #21 |
I'm down for a set since i do have all of your other pieces. Have been waiting for this one for a while now lmk
Signature image exceeds allowable size. |
10-26-2009, 09:15 PM | #24 |
I would definitely be in for a pair.
Actually I need to buy all of your braces. Had your tension brace on my first car and loved it.
10-26-2009, 09:48 PM | #25 | |||
Trader Rating: (29)
01-10-2010, 04:18 AM | #27 |
The point of the fender brace is simple. The S chassis have a problem with their lower "frame rails" These are unibody cars, and since the chassis is doesnt actually act as a frame, it relies on just the sheet metal for all the strength. The fender braces fix an issue that our cars have, the lower unibody frame rails end pretty much at the fire wall, and the top of the strut tower which has all the suspended weight is only supported by the upper rail. Which ends at the forward door bulkhead. By connecting the front upper rail and the door mounting points you eliminate a bunch of flex. I run Stealth Custom Fab front strut tower bars, and Fender Braces on my car. They make a huge difference. You would think this opinion is biased. But it is completely true. My car would actually get random understeer and other uncontrollable things before. Even when we ran advan slicks the car felt solid with them. I suggest you guys buy his products. Everything I made here in the USA, and he stands behind his work.
01-12-2010, 08:56 PM | #28 |
Listen to Luke, he knows what he is talking about!
Also you would think I am biased about Jonnie's parts, but they wouldn't be on my car or any other car for that matter if they didn't actually work. |
