Parts Shop MAX ~High Mount Intercooler Kit~ Real time quotes and ordering in thread!
*****UPDATE*****
We have a Greddy Intake Manifold cold pipe solution finalized and it has been added to the shopping cart as an HMIC kit option! ![]() ![]() ![]() ![]() ![]() PURCHASES AND SHIPPING QUOTES DIRECTLY FROM THIS THREAD! SIMPLY CLICK THE BLUE ADD TO CART LINK VIEW CART We have been doing custom drift spec intercoolers for a long time with fantastic results: ![]() NOW: Parts Shop MAX is proud to bring you the first drift specific bolt on high mount intercooler in kit for SR and KA-T with T25 & T28 Bottom mounted turbos. This complete track proven HMIC kit delivers turbo response and reduction in temps that is second to none. MAX S13-S14 SR & KA High Mount Intercooler for T25 & T28 Turbos $380 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock date is 4-23 Intercooler sold by itself for $250 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock date is 4-23 Key features of our drift specific High Mount Intercooler Kit: ~Mounts in front of the radiator, under the core support. Inlet and outlet shoot past the sides of the radiator. ~2.5"inlet and 2.75"outlet maintain proper velocity (3" pipes are too big for stock turbos) ~3.25" thick, extra wide core gives proper volume to the short height design ~Specifically designed for the bottom mount t25&t28 nissan turbos ~Extra short pipes for best response ~No BOV flange (we dont run them on our cars...TIG your choice of flange is optional) ~Allows better water cooling because it blocks less air from the radiator ~Mounts as far as possible away from front crash zone...and thieves...and cops *Not compatible with pop up headlight motors and AC condenser *Radiator support must be cut as shown in install photos -Reinforced silicone couplers are available in Orange or Black. S13 kit will have: 8x Stainless T-bolt clamps 2x 2.75" straight couplers 1x 2.5" straight coupler 1x 2"-2.5" step 90* coupler ![]() S14 kit will have: 8x Stainless T-bolt clamps 2x 2.75" straight couplers 1x 2.5" straight coupler 1x 2"-2.5" step 45* coupler ![]() ![]() ![]() ![]() ![]() MAX S14 High Mount Inter Cooler Kit $380 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock date is 4-23 Intercooler sold by itself for $250 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock date is 4-23 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Track tested, seeing dramatically lower water temps, and instant boost response! MAX S13 High Mount Inter Cooler Kit $380 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock date is 4-23 Intercooler sold by itself for $250 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock date is 4-23 Picture of the S13 complete kit: ![]() ![]() installed ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() All intercooler kit options are available upon adding to cart for $380 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINEin stock date is 4-23 Intercooler sold by itself for$250 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock date is 4-23 THE FOLLOWING ITEMS ARE SOLD SEPARATELY FROM THE HMIC KIT (although they are a match made in heaven!) I now have turbo inlets in stock for S15 T28 turbo ~ bottom mount ~ with Stock MAF or Z32 mass air flow meter Only $60! Features: ~ 3 layer reinforced silicone couplers ~ Color choice of Black or Orange ~ Bead rolled Aluminum tube ~ Stainless steel hose clamps ~ Matches the Parts Shop MAX High Mount Intercooler (HMIC kit) perfectly! Inlet pipe for T28 turbo with stock MAF available in black or orange: $60 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock now! ![]() ![]() Inlet pipe for T28 Turbo with Z32 MAF available in black or orange: $60 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock now! ![]() ![]() Install pictures ![]() ![]() ![]() ![]() ![]() ![]() *****UPDATE***** Inlet pipe for S13 T25 turbo is here !!! Two versions are available, straight ($70) and curved ($80) TIG welded and bead rolled aluminum tube with crank case breather fitting and 4 hose clamps Comes with your choice of black or orange silicone couplers Inlet pipe for T25 turbo with stock MAF available in black or orange and in two shapes: $70-$80 CLICK HERE TO ADD TO CART FOR AN INSTANT QUOTE OR TO ORDER ONLINE in stock now! ![]() The curved tube is a little more expensive, and is designed to work with front mount intercooler pipe routing and curves around the OEM power steering reservoir rubber hose. ![]() this version is a bit cleaner and a little cheaper than the bent aluminum tube inlet but requires our HMIC kit because the pipe routing of most FMIC kits interfere where this straight inlet puts the filter. Also the straight one requires you to lengthen the rubber hose on the bottom of the the power steering fluid reservoir. ![]() installed pic on S13 ![]() get rid of all this crap! ![]() VIEW CART
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! Last edited by DC Dan MAX USA; 05-13-2010 at 07:14 PM.. |
assuming s13 and s14 have different mount points which one would be for a s14 with a s13 sr20 ?
There is 26 variations of this kit selectable in cart based on:
Coupler Color Preference, Vehicle Body, Engine and Turbo It dont matter which "kit" you click on because they are all adjustable (once you are in the shopping cart) to your scenario and 2 options of intercooler only - S13 or S14/15
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
not right now, but they will be here very soon
$20 - send us the flange and we'll take care if it...
...although the kit does not come with any BOV port for a reason ~ you dont want to blow off while modulating the throttle for a drift. And they can leak. No one in this shop has ran a BOV for years now.
#13 | |
it touches the hose. (see customer pic) ![]()
#15 |
yes, you would just reroute the hotpipe
#16 |
ok I am not trying to be dumb or flame in any kind of way because i have been in awe since you debuted your parts. i DD my car and slide it and I am Sr and I have a hks ssqv because I was told I need a BOV. wouldnt if I ran without a BOV everyday my lil t25 would blow and so my motor wouldn't like it either right?
#17 |
I have never experienced anyone blowing their turbo due to lack of BOV, you certainly dont need it for drift but if you feel better with one on there for your daily by all means add a flange and enjoy.
#20 |
pms answered
#22 |
the core is 688x190x86mm
#24 |
yes indeed
#25 |
were almost out of these, I have 3 left and then there will be a wait till the next shipment.
#27 |
never planned on selling pipes alone since it is made specifically for our completely custom intercooler
#30 | |
And for your other question, Dan will have to answer that one.
