12-24-2009, 01:56 PM | #33 | ||
Coolest things about all of this is: a) Aluminum is cheap b) CNC time is reasonably cheap c) heims/bearings are cheap d) Lots of engineers have S-chassis cars
Jordan Innovations has a new web site! www.JordanInnovations.com -- All your favorite FD Pro Drifters love it, trust me -- www.JordanInnovations.com |
12-24-2009, 02:04 PM | #34 | |
And I'm not convinced about the rear at all. Moving the rear pickup point doesn't put it out of sync with the rest, as they all move the same way. And the Parts Shop MAX car has used this method with success.
12-24-2009, 02:23 PM | #35 |
True.
The FLCAs do have enough flex in the inner bushing for it to be tilted forward and still work to a degree, but you'd sacrifice the range of motion that the ball joint or spherical bearing will have on the outer end due to the FLCAs now having a slanted angle. Even with Def's modified Godspeed FLCAs, his spherical bearings (that replaced the ball joints) only has 15 degrees of misalignment on it. While he will probably never use the full range of 15 degrees, if your arms are tilted down in the front due to the T/C rods not being relocated as well, then the misalignment angles decrease, and you might run into problems then. All hypothetical of course, but still, if I were to mess with the suspension, I'd rather do it right and make sure things aren't going to go out of whack, instead of just going by the "eh... it's good enough" approach. |
12-24-2009, 02:57 PM | #36 |
Yes, Matt's tension rods are pointing up, and if he raised his inner pickup point they would be even more deformed. The point is to get ALL suspension geometry correct while having the car retardedly low - at least that's the point I'm going for.
Its counter productive to do something that requires extra steps for no reason. Moving the inner point up 1" like Formula-D allows will not correct the roll center enough, so you'll still need to change the spindle or LCA.
Instagram - SJKnoop |
12-24-2009, 03:10 PM | #37 |
this thread is fucking legit
@UpshiftEngineering |
12-24-2009, 03:18 PM | #38 |
A set of knuckles wont be any help if you cannot correct the angle of the LCA at a given ride height. This means that the only solution to this would be a set of 2 piece spindles that can be taken apart to install a roll center spacer. One of the J-land companies has these.
1994 FD3S Drift // 945garage // sumospeed.com |
12-24-2009, 03:52 PM | #39 |
^^Or raising the pivot points on the crossmember, wont happen with stock control arms but if you are running heims there is room for moving the mounting hole up 15mm.
Edit: but now that I think about it the swing arc on the tension arms is still going to be messed up. I guess you could achive the same thing with adjustable ball joint studs but youre still left with the steering arms. Do the J-land spindles raise the roll without messing with the steering arms? |
12-24-2009, 05:17 PM | #40 |
The J-Land one is the GP Sports knuckles.
There are two versions. One version has a fixed 20mm or something adjustment plus added angle at full lock. The adjustable one can be spaced with spaces that will space both the tie rod end mounts and ball joint mounts together as one unit. |
12-24-2009, 06:04 PM | #41 |
Ideally you would have an adjustable LCA with a spindle that corrects geometry, so you can fine tune it with the LCA and the knuckles could adjust like 30mms or so.
A way to bypass the whole tension rod issue is to get rid of the 2 prong bolt on method and make a LCA with a bracket to allow a double heim joint tension rod. So you can weld it on however higher or lower depending on what you do with the inner LCA pick up point. Something similar to this: A company called SP-Tec in Japan makes these:
12-24-2009, 08:41 PM | #42 |
Nice thread.
What do you guys think about the new driftworks spindles?
instagram: madness_garages14 Last edited by mothon; 12-25-2009 at 01:26 AM.. |
12-24-2009, 09:16 PM | #43 | |
Correcting the front roll center brings the front tension rods to about the stock angle. Not sure why you guys are stressing out about the front tension rod, as any higher you make the front roll center.
S13 Hatch - Goes around tracks quickly DEFSPORT |
12-24-2009, 10:18 PM | #45 |
95KA-turbo, that tension rod setup makes sense! Thanks! It looks like the Ikeya Formula arms, just more basic. But you could definitely adjust tension rod position if you made them yourself.
Also those knuckles look crazy similar to the Driftworks ones. Right down to the bushings, haha. So here's a thought; Say you have PSM knuckles, which already correct for bump steer. Then you get SPL tie rod ends, which have spacers to correct for bumpsteer. Third, you move the inner pivot point of the control arm up and install SPL's spacers to space the tie rod down even farther. Wouldn't this make the tie rods parallel to the new control arm location? I know it's kind of a drastic amount of adjustment, but it should work. I wanted to draw this in paint, but I can't find a good picture to do it with. You can move the tension rods up a little bit, seeing as with decently high spring rates they don't move up and down a whole lot. Also, what about mounting the tension rod to the bottom of the control arm instead of the top? And no one has any idea of where you actually want your roll center? To me, stock makes sense. All of my ideas won't really matter if it's ideal to have your roll center farther down than stock, as you won't need such drastic adjustment, hahaha. BTW, thanks for all the input and compliments guys, I'm really enjoying this thread!
12-24-2009, 11:03 PM | #46 |
You can get the roll center up close to your CG without moving the inner pivot of the FLCA, so no idea why you'd consider that.
You don't really want your roll center right at your CG height either, as it can create weird handling as it moves from very close to your CG to far away upon corner entry.
12-25-2009, 12:51 AM | #47 |
AH! This makes sense. I'm guessing the center of gravity in the 240SX is farily low? Say, just about seat (butt) level?
I knew there must be some reason no one was doing those kind of crazy modifications.
12-25-2009, 12:59 PM | #48 |
Keep this thread going, shit is great.
I have the SPL tie rod ends and it lowers the tie rods a BUNCH. but i feel like the control arms need to be moved still.. This is kind of irrelevant but, when i reverse out of say a parking spot and i hit full lock, i cant turn the wheel the opposite way right away, its ilke completely locked until it moves forward a bit. I dont have this problem while drifting or any other type of driving, only when reversing. I know this shouldnt be happening... |
12-25-2009, 07:28 PM | #49 |
Front CG in ours cars is probably just above the crank centerline, give or take a couple of inches. It doesn't take too much outside pivot lowering to at least get close to there.
12-25-2009, 08:26 PM | #50 | ||
12-27-2009, 11:45 AM | #52 |
I never quite understood adjusting squat/anti-squat. I know you can angle the rear subframe and/or lower control arm, but which way to reduce anti-squat?
And i've heard good things about doing that in S13 drifting applications, is it really that noticeable/wanted of a change? People aren't very specific when it comes to talking about the after-effects. |
12-27-2009, 01:16 PM | #53 | |
Basically it gives you more weight transfer to the rear, more "squat", and better traction when accelerating hard. This really helps for higher-powered cars that have problems putting the power down.
12-28-2009, 08:37 AM | #56 |
what would be a good daily and track suspension set up...im currently running apexi n1 coilovers but i may sale and buy dmax coils lmk
12-28-2009, 08:51 AM | #57 |
This is not really the thread for that...there were like 6 threads made in the past month about coilover choices in general discussion. I personally love the Fortune Auto coilovers on my car though.
12-28-2009, 01:44 PM | #58 |
Yeah, let's try to keep it on topic people.
No coilover talk please.
12-28-2009, 02:16 PM | #59 |
Just to add some FYI stuff, I'm running the GP Sports Hyper Knuckle (Adjustable). I originally had a 20mm spacer in there in additional to the 15mm? that the knuckle added and it was a bit TOO much roll center adjustment causing major understeering issues. This is due to the front vs rear roll center, or in other words the front roll center was far too high compared to the rear, which doesn't allow the car to rotate. So without much, or any rear roll center adjustment, adding a crap load of front roll center adjustment will hurt performance. So if you're interested the GP Sports knuckle, or any sort of front roll center adjustment is fine. Ultimately, there needs to be an effective rear roll center adjustment to balance the car. The Driftworks option posted on page one looks like the best option, though I'd like to know if it can be used with a z32 brake setup.
.25 till 3 |
12-28-2009, 02:31 PM | #60 |
My next question......
Could we technically split in half a set of knuckles and build the bottom half out of 6160 aluminum? I have been wanting to do this for a while now. I threw this idea around the shop and Im gonna talk to my machine shop to see what he can come up with.
Tags |
anti-squat, best thread ever, kpi, roll center, steering angle, suspension |
