Old 01-07-2010, 06:54 PM   #1
S13 curtis
S13 curtis's Avatar
S13 curtis is an unknown quantity at this point
Thumbs up Journey to hit 430+whp with a T28...Lets find out.
OK guys whats up as you know ive been working with my 240 for a while now since i was 17. Im currently serving the US Army and im stationed in Korea, 31B Military Police, but my car car is being put togeather as we speak and i wanted to let you guys in on the progress i would like to get your input good or bad it dosent matter to me i take those and make things better.I wanted to be a little different and go a different route than most ppl and i will be the first on here to push the "Special GT25 EWG V44 turbine housing" to the limit. We will see what it take to break way over 400whp on a GT2871r, it to easy to go past 400 with a GT30r. enough talking lets get down to business,enjoy!!!
Mod list to make this happen:
Powerplant:SR20DET Red Top
-Stock Internals
-ARP Head Studs
-Apex 1.1mm metal Head Gasket
-Built head, BC springs and retainers,BC Valves.
-Tomei ProCam 270 duration
-Tomei RAS
-Cusco Motor Mounts
-Greddy oil catch tank
-NO A/C or P/S
Hotside:GT2871R .72
-Copper Exhaust manifold gasket
-Megan racing Exhaust manifold
-Megan racing Elbow
-Megan racing Down pipe and test pipe
-Apexi N1 Cat back exhaust
-Jegs 3' Eletric Cutout
-ATP Special T25 EWG .72 A/R Turbine housing
-Tial V44mm wastegate
ColdSide:GT3071R 4'inch inlet T04E Compressor housing (56 trim GT2871r's can only use this as a upgrade) flows 50lbs a min.
-Ebay 32X12X3 FMIC (works great BTW never gave me problems)
-2.5inch intercooler pipeing (debateing on going 3'inch)<-- needs your input.
-Greddy Intake manifold
Fuel Delivery:Walbro 255lph
-Precision 1000cc injectors
-Aeromotive Fuel Pressure Regulater (not purchased yet)
-Z32 Fuel Filter
-FUEL:-----> E-85<----- FTMFW
Engine Management:AEM EMS w/all the goodies listed below
-AEM 5.0 bar map sensor
-AEM Boost control solenoid = Baller
-Tuned by ???
Drivetrain:Stock SR tranny
-Drive Shaft shop 1 peice drive shaft
-Helical LSD
-Act 6 puck clutch (brand new getting installed)
-F1 13lbs Light weight Flywheel ( ive seen these work fine, its getting installed)
-Pressure plate (need a new one tell me what u think of my old one)
Most of the parts are already on the car i can count on 1 hand for the parts i dont have.
This will not be babied at 18 lbs of BOOST, it will be 22+PSI
I will be getting the full potential of the T2 based GT2871r.
here are the pics of the new parts so far and the progress on the turbo.
More pics will come your way soon!!!
The Tomei Cams,RAS,and ACT 6 puck Total $638 after shipping
Turbo Parts that Arrived!!!!!!!!! Total $581 from ATP Turbo after shipping
plus comparison
GT3071r Compressor housing installed after some hard work and elbow grease.
The Snap Ring on the CHRA will piss you OFF, i repeat it will piss you off.
Aftermath:
Mission Complete:
Well i had the tranny pull and this is what i found not bad jus showing pics.
Seems to have over heated pretty bad.
the old exedy clutch
the old flywheel
Here is a really old motor shot.
thats all the pics for now and i will come up to post alot more later. and thanks for looking and dont forget to leave your feedback.
S13 curtis is offline   Reply With Quote
Old 01-07-2010, 07:09 PM   #2
S14_Kouki
S14_Kouki's Avatar
S14_Kouki can only hope to improve
You will do 426whp
S14_Kouki is offline   Reply With Quote
Old 01-07-2010, 09:01 PM   #3
bl3ujay07
bl3ujay07's Avatar
bl3ujay07 is an unknown quantity at this point
damn...cant wait to see it finished.
bl3ujay07 is offline   Reply With Quote
Old 01-07-2010, 09:17 PM   #4
smelly240
smelly240's Avatar
look how little the turbine wheel is - so weird lookin.
mix and match til it works tho - might take more than one try - but it can happen if u try hard enough...
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 01-07-2010, 09:30 PM   #5
RurouniMidnight
RurouniMidnight's Avatar
RurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to allRurouniMidnight is a name known to all
looks like an interesting journey. Wonder what the actual numbers are going to be
-I would use a s15 multi layer gasket
http://nightparade.wordpress.com/
Join in on instagram @nightparade
RurouniMidnight is offline   Reply With Quote
Old 01-07-2010, 09:32 PM   #6
S13 curtis
S13 curtis's Avatar
thanks, and yea i was thinking the same thing about the turbine wheel tiny little thing. it will be tuned on E-85 + a decent amount of timing so we'll see.
Old 01-08-2010, 03:10 AM   #7
SpdElemts
SpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of lightSpdElemts is a glorious beacon of light
Nice parts...i cant wait to see the turbo mounted with the special exhaust housing. Thinking about using the same housing. Please post some pictures of how close the wastegate is to the shock tower.
-Jeff Wolfson
SpdElemts is offline   Reply With Quote
Old 01-08-2010, 06:04 AM   #8
Psycho 240 Freak
Psycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-knownPsycho 240 Freak is making his/her stupidity well-known
Good looking build so far. I can't wait to see how this turbo will do. Where you at in Korea and how much longer do you have?
Psycho 240 Freak is offline   Reply With Quote
Old 01-08-2010, 06:17 AM   #9
ross.cottrill
ross.cottrill's Avatar
ross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant future
im interested to see the outcome of this...
" NEO VVL BABY FTMFW!"
Originally Posted by shagspeed
Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines
ross.cottrill is offline   Reply With Quote
Old 01-08-2010, 06:58 AM   #10
BiG MiKE86
BiG MiKE86's Avatar
BiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really niceBiG MiKE86 is just really nice
Send a message via AIM to BiG MiKE86
post ur findings of that exhaust housing please!
BiG MiKE86 is offline   Reply With Quote
Old 01-08-2010, 07:59 AM   #11
smelly240
smelly240's Avatar
i think to make that housing work - u have to run a pipe off the turbine to move the wastegate.
those housings arent something new they've been out quite a while. - atp turbo sells them - I seen them used on a honda - with the gate sticking upward and the housing horizontal.
Old 01-08-2010, 11:56 AM   #12
Def
Why not go with a T2 flanged turbo that has a bigger turbine wheel if you really want to make more power.
I might have just gone GT2876R as well, since IIRC it flows a bit more up top than even the big E cover on the 56 trim 71mm wheel.
DEFSPORT
Old 01-08-2010, 03:02 PM   #13
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
Wouldn't a GT2871r w/ a GT3071r compressor wheel be the same as a GT2876r? Which I heard is a poor match because the compressor wheel is too big for the turbine. (I'm not 100% sure on this, but just throwing it out there)
guitaraholic is offline   Reply With Quote
Old 01-08-2010, 03:20 PM   #14
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
i stopped reading your mod list after i got to stock internals....
good luck with that.....hopefully it lasts longer than a couple dyno pulls
not trying to be the token pessimistic dickhead of the thread but i am skeptical of the longevity.
you're stationed in Korea making buku $$ can't spend your money...for God sakes man build the bottom end and give yourself some piece of mind. i understand racer x on forum xyz made 24320482084 horsepower for 3 years on stock bottom end without problems.....good for him, but i wouldn't waste 10 grand of my money because of that.
i would have forgone the head work if it was between that or the bottom end, but i know money's not a problem with you since you're military so i am venting strongly my opinion/suggestion that you build the bottom end.
e85 is cheap race gas and will help the stock bottom end last longer...but also e85 varies from batch to batch even at the same pump...therefore care must be taken to make sure your fuel is consistent to the tune, however duly note that even with a perfect tune....the laws of physics still apply and if that bottom end can't take it, it won't hold.
once you reach the limits of that bottom end..it's too late..
best of luck and thank you for your services
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 01-08-2010, 03:59 PM   #15
S13 curtis
S13 curtis's Avatar
Im here until october then i will come back to the states. Im in daegu Area 4. the car shouls be ready to hit the dyno as soon as i can find a new pressure plate. as for my intercooler pipeing im thinking about going 2.5 on the hot side a 3 inch on the cold side along with the SSQV mounted beforethe throttle plate.
Will do as soon as it gets mounted up.
Nope, It dosent turn it into a GT2876r, its still a GT2871r, GT3071r and GT2871r have the same exact compressor wheel.
I decided to just work with what i had and just upgrade the 2871R, my origional plans were to do a .63 T3 backside and have it top mounted but i changed plans jus to make it easier for my buddy working on it.
Old 01-09-2010, 12:38 AM   #16
guitaraholic
Well, I can't wait to see it on the dyno. It would be nice to see a decent spooling turbo that makes pretty good power
Old 01-09-2010, 01:32 AM   #17
S13 curtis
S13 curtis's Avatar
Little update and i ran into a little problem check it out:
the compressor housing is touching the exhaust manifold.
here are the solutions to the problem:
1. Use the stock SR exhaust manifold Extrude and Swained because there is no way in hell im putting a stock restrictive manifold back on.
OR
2.Purchase a T2 Flange and use it as a spacer between the turbo and the manifold.
Opinions Please.
Old 01-09-2010, 01:39 AM   #18
guitaraholic
I've heard the Stock manifold flows pretty good once its been extrude honed. Besides Then you can sell me the manifold...lol J/K
Old 01-09-2010, 01:43 AM   #19
HPballer76
HPballer76's Avatar
HPballer76 is an unknown quantity at this point
what about going top mount t2? if thats not an option then the extrude honed stock many gets my vote.
HPballer76 is offline   Reply With Quote
Old 01-09-2010, 04:58 AM   #20
juggernaut1
juggernaut1 is an unknown quantity at this point
OR
Opinions Please.
Is it possible to clock the comp housing slightly to gain a little clearance?
Sidenote: its a pity they didn't develope the ex housing to suit the more compact Tial MVS gate.
juggernaut1 is offline   Reply With Quote
Old 01-09-2010, 05:26 AM   #21
S13 curtis
S13 curtis's Avatar
yea, it should Clear i will take a pic of the mock up as soon as i get this turbo on the manifold. it was clocked a couple times and still wont clear enough because of runner #1. i will most likely go the extrude and swained route
Old 01-09-2010, 12:16 PM   #22
Gorilla Unit 33
Gorilla Unit 33 is an unknown quantity at this point
Why not just go top mount?
Gorilla Unit 33 is offline   Reply With Quote
Old 01-09-2010, 07:02 PM   #23
juggernaut1
Just tap the comp housing outlet a couple of times with a soft mallet or the wooden handle of a hammer in the direction you need - it will rotate into position - you don't need to undo the bolts each time.
Good luck
Old 01-09-2010, 07:24 PM   #24
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
Too much work + hes already got these parts haha
om3ga is offline   Reply With Quote
Old 01-09-2010, 07:35 PM   #25
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
Yea, i had a tubular mani. Shit broke, so now i use a stock one and im fine with it. Stock unit will never break and it flows fine. It doesn't look very cool but if you get it powder coated it doesn't look bad.Spacers work too just keep in mind cast iron is tuff stuff.
ps-for any asshat that wants to make a comment, it was an HKS mani. 1/2 inch flange and it still cracked.
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 01-09-2010, 07:41 PM   #26
Dee
Dee's Avatar
Dee is an unknown quantity at this point
Subbed, interested to see how close you get to your mark. Godspeed bruh
'78 280Z-LSx|76mm turbo|1840cam|8.8 Diff
Dee is offline   Reply With Quote
Old 01-09-2010, 10:28 PM   #27
S13 curtis
S13 curtis's Avatar
I would not waste my time with a T2 topmount. if i was going topmount i wouldve bought a .63 T3 housing.I would have to get a custom down pipe new ssbraided lines etc, too much of a headache for me.
You read my mind.
Old 01-09-2010, 10:42 PM   #28
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
in for the support i'd like to see how this turns out man, good luck
Slip Gypsies Blog
not sure if you realize this
Old 01-13-2010, 02:35 PM   #29
BiG MiKE86
BiG MiKE86's Avatar
any updates? really interested to see some clearances on the ex. housing with the wastegate installed
Old 01-13-2010, 07:14 PM   #30
S13 curtis
S13 curtis's Avatar
waiting on my friend to bring me a stock exhaust manifold so i could get it ported out. then i will post more pics.
