Old 01-14-2010, 07:16 AM   #1291
TurboGoKart
TurboGoKart is an unknown quantity at this point
Has anyone put a 315 on a 10" rim? Can it be done? Will it be horrible? I have an S13, and I have yet to see a picture of the FN01R-c's in the +12 offset on an S13. I know there's much less room as opposed to an S14.
TurboGoKart is offline   Reply With Quote
Old 01-14-2010, 08:59 AM   #1292
longfellow
longfellow's Avatar
longfellow is an unknown quantity at this point
Why do you want to put a 315 on a 10" wheel? You're going to completely compromise the sidewall doing that.
I have FN01R-C's in the size your asking on the rear of my S14 with 255-40-17 NT-05's and it required a 3/4" pull.
So I wouldnt suggest it because your going to have to pull your rear fenders out about a mile.
longfellow is offline   Reply With Quote
Old 01-14-2010, 10:58 AM   #1293
TurboGoKart
Well that's what I'm trying to get at. I'm trying to figure out if I should just go ahead and get the Origin 50mm overfenders. Which I believe I will if you had to pull your fenders out that much on an S14.
And I didn't know about the tires....hence the reason I'm asking. How much does it compromise the sidewall? Or what's the widest tire you can put on a 10" rim?
Old 01-14-2010, 11:31 AM   #1294
longfellow
longfellow's Avatar
I wouldnt go over a 275-40-17 and the problem with that is its a tall ass tire. The problem with 17's is once you go over 255's tires become really tall because they dont make a 35 series.
Yes I would suggest getting over fenders on your car if you want do that set up and not have retarded pulled fenders and run lots of excessive camber.
What are you trying to do with the car? 255-40-17 NT05's have been working well on track day 240's with upwards of 340hp. You need to worry about what you can fit up front because running a huge stagger on these cars sucks.
In reality your best bet is an 18" wheel so you can run a 285-35-18 tire but thats an expensive option.
Old 01-14-2010, 11:54 AM   #1295
mr_eh
mr_eh's Avatar
mr_eh is an unknown quantity at this point
hmm, i have 275 on a 5zigen 10 inch +12, think a 30mm over fender will clear the tire with tein basics, not slammed but a moderate drop.... pulling the fenders is moot due to damage
mr_eh is offline   Reply With Quote
Old 01-14-2010, 12:10 PM   #1296
RAMM
RAMM is an unknown quantity at this point
I think you should be good with -1.5 to -2.0 degrees of camber out back w/ the 30mm overs
RAMM is offline   Reply With Quote
Old 01-14-2010, 12:18 PM   #1297
mr_eh
mr_eh's Avatar
eh, yeah. i dunno if i want to run any negative, cars gonna be making 500+ whp, i want as much contact with the pavement as possible
Old 01-14-2010, 12:21 PM   #1298
TurboGoKart
Well it's in the process of an LS1 swap, cammed, intake manifold, long tubes, cold air intake, exhaust, not sure about heads yet, but that's going to be well over 400whp with the 6sp. manual, and not too far behind on torque. I'm going to need some good tires behind that.
Mickey Thompson makes a 315/35/17 drag radial.
Mickey Thompson Performance Tires & Wheels
I have seen 315's on S13's before, it's all in the offset of the wheel. I was curious about the FN01R-c's specifically. But if it won't work on a 10" wheel, I'll either just get the 275's, or do the whole overfender thing and go with wider wheels.
Old 01-14-2010, 12:23 PM   #1299
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Originally Posted by fliprayzin240sx View Post
DAMN...so curious, what the hell did you use to pull the fenders that much? I'm about to do this shit the next couple of days...and this is what I'd have to deal with:
19x10 -3 with 275/30s
Why so much positive camber? No RUCA's? That looks terrible broski
I don't have good 'meat' shots
235 front 255 rear
I reallllly wish I had a 245 that would work nicely in the front, and a 265 in the rear, but that'll be till mid season when these wear out.
Old 01-14-2010, 01:08 PM   #1300
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
Your car looks great but I think visually it could use a little more rake.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 01-14-2010, 01:21 PM   #1301
longfellow
longfellow's Avatar
255-40-17 NT05's x4. Not insane but it works awesome
Old 01-14-2010, 01:25 PM   #1302
FusionR240sx
FusionR240sx's Avatar
FusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond reputeFusionR240sx has a reputation beyond repute
Send a message via AIM to FusionR240sx
yea bring that camber to like -1.5/-2
Originally Posted by Wreckless35 View Post
still be flush dropped on KYB AGX struts & s-tech springs
WUT?
FusionR240sx is offline   Reply With Quote
Old 01-14-2010, 03:38 PM   #1303
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
This thread needs some serious cleanup to get the retardation out.
"Let's keep this pure, people. NO 205s/215s/225s/235s. Everyone and their mother can rock those on an S13 with no fender modifications at all, and they all happen to be on the small side."
KA24DESOneThree is offline   Reply With Quote
Old 01-14-2010, 03:53 PM   #1304
sr.nic93
sr.nic93's Avatar
sr.nic93 is an unknown quantity at this point
anyone have xxr 962 set up
sr.nic93 is offline   Reply With Quote
Old 01-14-2010, 04:30 PM   #1305
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
235 front 255 rear
Car looks great Cody for a nice simple build. Definately could use some more rear rim and tire though. Looking a little skinny for 400whp. Looking a tad sunk there with the skinny rear tire on the high offset wheel. Nothing a small spacer couldnt cure though.
SuicidnS13 is offline   Reply With Quote
Old 01-14-2010, 05:49 PM   #1306
Firestorm
Firestorm's Avatar
Firestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond reputeFirestorm has a reputation beyond repute
Send a message via ICQ to Firestorm
hey guys!
so i'm thinking of getting a new wheel/tire/body combo for my 180sx. i used to run 235s up front and 255s in the rear. but i don't like the feel of the whole stagger thing so i'm thinking of going 245 or even 255 all around on 17x9".
so i was wondering if i could make that fit on the front without rubbing anywhere on full lock (stock steering angle). i was planning of running 20mm overfenders up front, depending on the offset of the wheels maybe even 40mm. i don't care if i need fender tubs, i just want to know if it is actually possible or not.
Firestorm is offline   Reply With Quote
Old 01-14-2010, 06:03 PM   #1307
longfellow
longfellow's Avatar
You can fit 245's under stock fenders depending on how low your car is. If its not super slammed you shouldnt have to much of an issue.
Old 01-15-2010, 02:20 PM   #1308
RAMM
Stock Metal
275/40-17 R888 in the rear
245/45-17 up front
Origin Overs for next year, going to test fit my 275's up front to see how they fit.
Old 01-15-2010, 02:31 PM   #1309
s.steven18
s.steven18 is an unknown quantity at this point
curious to know how you acheived that pull as well flip? that shits siickk
s.steven18 is offline   Reply With Quote
Old 01-15-2010, 02:36 PM   #1310
longfellow
longfellow's Avatar
Originally Posted by RAMM View Post
Stock Metal
245/45-17 up front
What size/offset wheels? I'm working on OEM metal wide fenders for my car, I'm sick of rubbing and I want 10's in the front.
Old 01-15-2010, 02:51 PM   #1311
RAMM
17x9.5 +18 all around
I used to run 255/40-17's all around in 2008 with a 17x9 +22 setup w/ a 8mm spacer up front to clear the perch on the coilover...fit the tire under the fender no problem
even though this years setup was a little smaller in tire width(245), the added offset and wheel width along(9.5 +18) with the 8mm spacer caused it to max out the fender.
Also ran -3.4 degrees of camber up front both seasons
Hope this gives you an idea
Old 01-15-2010, 03:07 PM   #1312
longfellow
longfellow's Avatar
I only run -2.5 up front with 255's on a 9"+15 wheel. My fender is right on top of my wheel so everytime I turn the wheel in a corner they meet, its getting old.
Old 01-15-2010, 08:31 PM   #1313
cdlong
can you post some tire bulge pictures? and by "stock metal" do you mean no over fenders, no pull, or no roll?
cdlong is offline   Reply With Quote
Old 01-16-2010, 06:43 AM   #1314
david.drftr13
david.drftr13 is an unknown quantity at this point
Send a message via AIM to david.drftr13
this thread is full of win!
david.drftr13 is offline   Reply With Quote
Old 01-16-2010, 07:55 AM   #1315
RAMM
roll and slight pull in the rear, no overfenders.
Next year im giong with Origin front 20mm overs and Origin Type 2 50mm rear overs
Old 01-16-2010, 10:42 AM   #1316
1wheelwonder
1wheelwonder is an unknown quantity at this point
What's everyones opinion on Federal brand tires, specifically the SS595? I plan on running a 255F/275R setup on my S13 and mainly want a tire that wont blow off when I open the ole V8 (VH) up.
Comments or suggestion would be awesome?
1wheelwonder is offline   Reply With Quote
Old 01-16-2010, 11:04 AM   #1317
SuicidnS13
SuicidnS13's Avatar
Pics of a 315/30 on an 18 x 10.5 or atleast a 305? When I go wide body I'm stepping up my game.
Old 01-19-2010, 02:07 PM   #1318
RAMM
Look for a tire with a utqg rating of about 220 or less. It really depends on whether you care for dry or wet traction too. Check out the Kumho XS's for dry traction.
Old 01-19-2010, 02:13 PM   #1319
longfellow
longfellow's Avatar
Or NT05's, They're about the same price, very close in dry grip but are much better in the rain imo.
Old 01-20-2010, 01:22 AM   #1320
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
255s
Drifting-pedobear is offline   Reply With Quote
