Old 01-18-2010, 08:54 AM   #331
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Originally Posted by variable View Post
I'm seeing the same problem. Anyone have any ideas?
Mode door motor is going bad. It is located under the dash on drivers side. often time the "linkage" can get stuck and it wont move. take a look at it have have someone change the "mode" (foot or face, or both) and see if it moves at all.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 01-18-2010, 10:30 AM   #332
variable
variable is an unknown quantity at this point
Thanks. I'll give it a look as soon as I can. Fixing this doesn't sound like it's going to be cheap (I wasn't expecting it to be).
variable is offline   Reply With Quote
Old 01-18-2010, 11:05 AM   #333
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
Originally Posted by KoukiMonsta View Post
my car wont start. kouki w/ redtop.
has spark, i smell fuel and hear pump. turns over just doesnt fire. sounds so close. but it seems like no spark symptoms. but there is spark. i check plugs (cas, maf, etc) disconnected battery and checked codes. nothing.
if anyone wants to help me trouble shoot or has info plz pm me
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 01-18-2010, 02:54 PM   #334
I LUV MY S13
I LUV MY S13's Avatar
vert wont start..ive checked fuses, grounding, battery is good...eveything powerson motor just wont turn over
-Jorge
I LUV MY S13 is offline   Reply With Quote
Old 01-18-2010, 05:20 PM   #335
Nidd
Nidd's Avatar
Nidd is an unknown quantity at this point
n00b question, just bought my s13 a month ago, fender is dented and i found a replacement fender for 75 bucks. is it a decent deal?
Nidd is offline   Reply With Quote
Old 01-18-2010, 07:32 PM   #336
mau5trap
mau5trap's Avatar
mau5trap is an unknown quantity at this point
Send a message via AIM to mau5trap
It will turn over, hesitate to start then not start. I can get it to start if I pull the fuel pump fuse, start the motor, let it die, then put the fuse back in and start it again. I just changed the plugs today thinking that that was the problem . Just took the car out for a drive. Started fine at my house 2-3 times. I get to where I was going to go, turn the car off come back 5 minutes later and try to start it and it happens again. I use the pull the fuse process and I drive home turn the car off and right back on a second later and it starts with the starter grinding. Once the motor starts it will run fine.
someone help me??? my sr won't start and this guy is having the same problem as me
mau5trap is offline   Reply With Quote
Old 01-18-2010, 07:35 PM   #337
I LUV MY S13
deadmouse is the shit
-Jorge
Old 01-18-2010, 09:10 PM   #338
allntrlundrgrnd
allntrlundrgrnd's Avatar
sr20 3 bolt exhaust gasket(between elbow/downpipe) is 2.75 inch correct? any local places carry these?
Old 01-18-2010, 09:37 PM   #339
phobs
Trader Rating: (60)
phobs is an unknown quantity at this point
Feedback Score: 60 reviews
What replaces the pop up light switch on JDM S13 Silvias?
phobs is offline   Reply With Quote
Old 01-19-2010, 06:23 AM   #340
Zenki_Kouki.5
Zenki_Kouki.5 is an unknown quantity at this point
city lights for the dual projectors. i think ahha
Zenki_Kouki.5 is offline   Reply With Quote
Old 01-19-2010, 06:54 AM   #341
Future240
Future Moderator
Future240's Avatar
I would say yes that is pretty decent. To be sure check to see what other people are selling fenders.
Originally Posted by ThatGuy
Old 01-19-2010, 08:18 PM   #342
mau5trap
mau5trap's Avatar
does anyone know where i can get that door window rubber trim?
drivers side is missing more than half and all that rain is going inside the door.
Old 01-19-2010, 11:44 PM   #343
hassanbakar123
hassanbakar123 is an unknown quantity at this point
95 s14 will 17x9.5 +12 clear the strut/spring
hassanbakar123 is offline   Reply With Quote
Old 01-19-2010, 11:54 PM   #344
ayuaddict
ayuaddict's Avatar
it will clear coilovers.
on shock/spring combo you need to measure the diameter.
Old 01-19-2010, 11:55 PM   #345
mau5trap
mau5trap's Avatar
anyone know where I can get cheap door window moulding?
Old 01-20-2010, 05:57 AM   #346
TurboSE
TurboSE's Avatar
TurboSE is an unknown quantity at this point
Greddy T78 and T88 water cooled?
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please.
TurboSE is offline   Reply With Quote
Old 01-20-2010, 06:24 AM   #347
sirfallsalot243
sirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enough
98 s14, 18x9.5 +24 all around
Will that clear a strut/spring setup up front?
Tire size recommendations? Im thinking 255/40? out back.. and 235 up front?
sirfallsalot243 is offline   Reply With Quote
Old 01-20-2010, 08:21 AM   #348
nathanong87
nathanong87's Avatar
do u mean oem struts and springs? i know that sizing will clear stance coilovers at least.
natelife.tumblr.com
Old 01-20-2010, 08:21 AM   #349
Future240
Future Moderator
Future240's Avatar
After searching the googles, seems your best bet for that is to pony up and go to Nissan.
Old 01-20-2010, 10:33 AM   #350
mau5trap
mau5trap's Avatar
damn, so expensive. but Imma go and get a price estimate.
thanks for the help.
Old 01-20-2010, 10:41 AM   #351
coww-cho!!!!!
coww-cho!!!!!'s Avatar
coww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the rough
Send a message via AIM to coww-cho!!!!!
if not maybe take a look at it and find something similar at a lowes/homedepot. if you're really worried about it maybe use black silicone that comes in a squeezable tube. it bonds to metal and is flexible but its just a quick fix that might not last long just an idea
**CoUpe LOve** #3
coww-cho!!!!! is offline   Reply With Quote
Old 01-20-2010, 10:57 AM   #352
mau5trap
mau5trap's Avatar
its not only that. the drivers window is wopply cuz is doesnt have the molding.
I'm just gonna take it to the dealership and see whats up.
I also have to do the front window redone or get it sealed properly lol.
bad time of the month to rain in cali haha. I was driving home in my 240sx when it started pouring, fucking water started leaking through the front window -___-.
its kewl tho. I still love her hehe.
Old 01-20-2010, 11:06 AM   #353
coww-cho!!!!!
The driver/passenger window slides up and down on two rails. one of the rails is motorized and the other just guides it up. The window has two metal plates that bolt onto the rails. and the rails are bolted to the door.in the picture below you can see the two plates that secure the window that are next to the railings. one is at the top left and the other is next to one of the gears. if you say its wobbly then it may be loose
and as for your windshield i got mine installed at a junkyard and the molding later crapped on me so i used the black silicone from a squeezable tube and
it bonded well enough for rain not get in.
**CoUpe LOve** #3
Old 01-20-2010, 11:18 AM   #354
drftkng951
drftkng951's Avatar
drftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond reputedrftkng951 has a reputation beyond repute
anybody have a link on how to tell if your heater /climate control works?
mine is stuck on vent and its been raining lol
J.SUN
drftkng951 is offline   Reply With Quote
Old 01-20-2010, 11:24 AM   #355
mau5trap
mau5trap's Avatar
can I get to those plates by removing the door panel?
Old 01-20-2010, 11:34 AM   #356
coww-cho!!!!!
yessssir you know how?
oh and before doing this either make your window go all the way down to reach the bolts , or if you want to pull off whole assembly for inspection (i would recommend if you got some spare time)then leave it all the way up
take off door panel by unsrewing your door handle, gently pry off switches/control panel and take off harness, pry off door lever, pry off the tabs that cover the screws on the door panel and everything else i can't remember
take off door panel, once it is off you'll notice a protective film, peel that off
the window sits on two rails (one which is powered to move the window up and down)
------if you want to pull the whole window assembly
take off the metal trim outside of door on top of door where the window is that can be removed by taken off a screw or two i believe and prying that off as well to give you a good clearance for what comes next
unbolt the two rails and basically have someone help you wiggle/pull it out and watch for the window's round metal stoppers
then set it somewhere clean (i.e. cardboard) as there is grease along side the rails and you can reset the height of the window for your needs and just work in reverse order afterward
**CoUpe LOve** #3
Old 01-20-2010, 11:36 AM   #357
mau5trap
mau5trap's Avatar
kinda, saw a instruction on how to do it on nico haha.
but I'm not sure which plates to tighten. can u circle it in the pic, that would be really great.
but thanks for the help so far.
Old 01-20-2010, 11:37 AM   #358
nathanong87
small question: do all gauge sensors/senders have the same threading? IE for my greddy oil pan, can i buy defi, stri, greddy, blitz gauges and have them all work the same without needing adapters?
natelife.tumblr.com
Old 01-20-2010, 11:46 AM   #359
coww-cho!!!!!
have you tried pulling your dash out to check it?
if you dont know how we can roll to jedis13 house to pull it off quick (he's done it countless times) and see how it reacts when you use your climate control
i've got nothing to do today haha
**CoUpe LOve** #3
Old 01-20-2010, 12:10 PM   #360
drftkng951
drftkng951's Avatar
i would be down but, my only door key is breaking and i can't get my door to unlock.
i took out my climate control already is there anything i should look for? or do i have to pull the dash out
J.SUN
