Old 01-26-2010, 01:23 PM   #421
TurboSE
TurboSE's Avatar
TurboSE is an unknown quantity at this point
Originally Posted by Slammed180 View Post
I need those as well, thank you, but there are white ones on the firewall that hold 3 or 4 lines that I also need...thanks for the good start though!
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please.
TurboSE is offline   Reply With Quote
Old 01-26-2010, 02:43 PM   #422
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
Originally Posted by udon! View Post
what is the point of frame rails besides using them to lift a car.
your not suppose to lift the car
on the frame rails lol.
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline   Reply With Quote
Old 01-26-2010, 02:46 PM   #423
NeedCAforS13
NeedCAforS13's Avatar
NeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura aboutNeedCAforS13 has a spectacular aura about
Send a message via AIM to NeedCAforS13
Courtesy Nissan has the brackets you're looking for...
462 Brake Piping & Control :: Brake :: Genuine Nissan Parts :: 240SX Parts (S13) 1989-1994 :: Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
NeedCAforS13 is offline   Reply With Quote
Old 01-26-2010, 02:47 PM   #424
sonomadrifter
sonomadrifter's Avatar
sonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the rough
Can s14 front studs be changed to 60mm extendeds without pulling the hub?
sonomadrifter is offline   Reply With Quote
Old 01-26-2010, 02:50 PM   #425
Iron_Zenki
Iron_Zenki's Avatar
Iron_Zenki is an unknown quantity at this point
With a welded diff will i get unusual tire wear?
Originally Posted by handinpants View Post
anyways,watch out for stupid people driving hondas
Iron_Zenki is offline   Reply With Quote
Old 01-26-2010, 02:55 PM   #426
NeedCAforS13
I've changed out stock studs before, so I can't see why you wouldn't be able to do 60mm extended studs.
But honestly, pulling the front hub isn't THAT hard if you can't get them in for whatever reason.
And YES. Welded diff's fuck up your tires fast. I had quite a few sets chunk up when I had a welded diff.
Old 01-26-2010, 03:07 PM   #427
TurboSE
TurboSE's Avatar
thanks for the hook-up, unfortunately, according to the site, most of them are no longer available...
Old 01-26-2010, 03:26 PM   #428
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
yepp i just did it last night
cheers mate
los_inc is offline   Reply With Quote
Old 01-26-2010, 03:33 PM   #429
NeedCAforS13
Oh shit, good catch, didn't even notice that. Damn.
Well if they don't have it, I doubt you'll find it at other dealerships.
Check out the S14 brake lines, they might be interchangeable,and they still have some of those brackets.
Old 01-27-2010, 02:57 AM   #430
TurboSE
TurboSE's Avatar
some of the S14 clips look similar, but from those pics I can't tell. I'm just gonna modify some of the ones posted by Slammed180, thanks for all the help guys, much appreciated!
Old 01-27-2010, 03:44 AM   #431
Nidd
Nidd's Avatar
Nidd is an unknown quantity at this point
can any one explain the difference between clutches or point me in the direction to find out? i can't seem to find what the difference between 4 pad, 6 pad and clutches that have an entire circle around them is.
Nidd is offline   Reply With Quote
Old 01-27-2010, 05:10 AM   #432
ayuaddict
ayuaddict's Avatar
as far as i know there are different friction materials ranging from organic to metallic compounds.
there are also sprung and unsprung clutches, the springs smooth out the drivetrain shock when engaging the clutch, and a unsprung clutch will put more stress on your trasmission.
typically more "grabby" compounds will be used on clutches that dont have full surface area (the 4 and 6 puck clutches you mentioned).
obviously the more grabby the material (metallic) the less the life of the flywheel, clutch and pressure plate.
Old 01-27-2010, 06:49 AM   #433
XnTroubleX
XnTroubleX's Avatar
XnTroubleX is an unknown quantity at this point
I have a guy wanting to buy my manifold
http://zilvia.net/f/sale-items/30258...light=topmount
but his turbo is internally wastegated and was wanting to know if their was a place that sales blockoff plates for where the external wastegate would normally bolt to.
XnTroubleX is offline   Reply With Quote
Old 01-27-2010, 07:49 AM   #434
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
frsport is just one of many....and they are a sponsor.
FRS Steel External Wastegate Block-Off Flange Deltagate/Tial 35mm 38mm
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 01-27-2010, 10:04 AM   #435
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
They have the single pipe clips on that site as well, so you could just drill another hole and use both the single, and double pipe clips.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 01-27-2010, 11:01 AM   #436
blacknblue
blacknblue is an unknown quantity at this point
I was looking for a s14 5-speed drive shaft and someone is trying to give me one from an s15 saying that it will fit. Can anyone confirm this?
blacknblue is offline   Reply With Quote
Old 01-27-2010, 11:38 AM   #437
NeedCAforS13
Maybe one of the 5 speed S15 driveshaft's, but the 6 speed uses a different shaft for sure.
Old 01-27-2010, 11:49 AM   #438
allntrlundrgrnd
allntrlundrgrnd's Avatar
Whats a good ignition source to wire an electric fan control relay to in the engine bay?
Old 01-27-2010, 02:31 PM   #439
stinky_180
stinky_180's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
Any differences between SOHC/DOHC KA24 rear crankshaft main seals? (interchangeable?)
WheelsDirty
Old 01-27-2010, 03:01 PM   #440
Wabash9000
Wabash9000 has a little shameless behavior in the past
can I use a 350z track edition rotor with 300zx caliper fit under the base 17" 350z 7 spoke wheels? I know that non track edition cars came with the track brakes, but I don't know if the calipers are the same size or if any of them came with 17" wheels over the track brakes.
Wabash9000 is offline   Reply With Quote
Old 01-27-2010, 03:26 PM   #441
Tom25666
Tom25666's Avatar
Tom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choicesTom25666 has made poor choices
what all do you need to upgrade a redtop with a t25 to a disco potato setup? just some 550's and a z32 maf? it would need a good tune as well, yes?
I have 1000 hp. This thread is dumb.
Tom25666 is offline   Reply With Quote
Old 01-27-2010, 05:16 PM   #442
My$800S14
My$800S14's Avatar
My$800S14 is an unknown quantity at this point
SOHC Transmission?
Does the SOHC Transmission have shorter gears than the DOHC Transmission on a 240sx? and also, will a SOHC transmission bolt up to a DOHC block, or DOHC bell housing? what would need to be done to do this, obviously it would only be worth it if the gear ratio inside of the transmission was different.
My$800S14 is offline   Reply With Quote
Old 01-27-2010, 08:11 PM   #443
kalypso123
(ノಠ益ಠ)ノ彡
no because you have to push the studs in, and hammer them down.
but removing the hub isnt difficult you can do each side in 20 mins if you have the tools ready.
Old 01-27-2010, 08:15 PM   #444
kalypso123
(ノಠ益ಠ)ノ彡
yup... that basically all you need.
Nismo FPR helps.
oil / coolant lines.
downpipe & manifold.
IC piping if necessary.
Old 01-28-2010, 06:50 AM   #445
NeedCAforS13
If you have air tools you just impact a lug nut on... no need to pull the hub to change out studs.
Nismo FPR helps.
It's hard to tell what you're saying, but YES he needs a tune with 550's and a Z32 MAF. He also needs an oil feed line with the built in restrictor for the ball bearing CHRA. I would get a set of stainless lines for ease of installation.
Old 01-28-2010, 09:30 AM   #446
dg_htx
dg_htx is an unknown quantity at this point
New member here. Just wondering if you guys got a sticky for what to look out for when purchasing a 240sx. Thinking of picking one up.... is there anything that I should be aware of?
Thanks
dg_htx is offline   Reply With Quote
Old 01-28-2010, 10:21 AM   #447
Slammed180
Thanks
Be aware it's a 240sx.
Blow me, bitches.
Old 01-28-2010, 11:34 AM   #448
WISH ONE
Why dont we have a HOUSING/ROOMATES thread??? or do we? I searched and found nothing.
Old 01-28-2010, 11:59 AM   #449
coww-cho!!!!!
coww-cho!!!!!'s Avatar
coww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the roughcoww-cho!!!!! is a jewel in the rough
Send a message via AIM to coww-cho!!!!!
Thanks
ya there was one last year when some one posted what to look for when purchasing a 240sx
you might be able to find it under the search button
and 240sxtech.com is your friend for "know how to stuff"
**CoUpe LOve** #3
coww-cho!!!!! is offline   Reply With Quote
Old 01-28-2010, 02:33 PM   #450
stinky_180
stinky_180's Avatar
Trader Rating: (26)
KA The Small Questions, that NEVER GET ANSWERED, Thread
hrmm so nobody knows huh?????????
WheelsDirty
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki
