Old 01-28-2010, 06:48 AM   #8341
Ktown_drifter
Ktown_drifter's Avatar
Ktown_drifter is an unknown quantity at this point
Originally Posted by fliprayzin240sx View Post
Looking sick RAY.. wanna trade for your old rims????????????/ lol
613driftwerks.ca
Ktown_drifter is offline   Reply With Quote
Old 01-28-2010, 07:50 AM   #8342
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Haha...Work Equips for knock off Work Equips. Shit, I wouldnt mind rocking 10/11j again.
CLICK HERE!!!
Old 01-28-2010, 08:33 AM   #8343
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
Originally Posted by Geezy View Post
i didn't know they made TE-37s with concave and lipped like that.
found this on rimtuck.
19 x 9.5 +12
215 / 35
19 x 10.5 +12
235 / 35
only the 19" TE's come with lip like that
that car also belongs to VAs13 on here. i think.
its also been posted in this thread quite a few times, but this car never gets old
ILoveJDM is offline   Reply With Quote
Old 01-28-2010, 08:54 AM   #8344
Ktown_drifter
boo didnt know they were knock offs...
613driftwerks.ca
Old 01-28-2010, 09:33 AM   #8345
Geezy
Geezy's Avatar
Geezy is an unknown quantity at this point
^^ Bro! ur like a year late..... this car belongs to fellow zilvian! where were u???
playin in the devil's sand box, kid. just starting to catch up with the game.
"VIP BALLER TE-37s".
Geezy is offline   Reply With Quote
Old 01-28-2010, 09:48 AM   #8346
Geezy
Geezy's Avatar
Jesus, how do you drive that?!?!?!
Old 01-28-2010, 11:47 AM   #8347
joshls2
joshls2's Avatar
joshls2 is a well-known jackass
^^^ Geezy, uuhhh.. you're late on that one as well, lol. why not just post your own pics?
joshls2 is offline   Reply With Quote
Old 01-28-2010, 12:21 PM   #8348
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
I want to run my future setup past you guys for some advice. Here is where I left off last fall:
F: 17x9 +12 225/45/17 Yokohama S-Drive (-2 camber)
R: 17x9 +12 245/40/17 Yokohama S-Drive (-2 camber)
Wheel specs were good, but ride height and tire sizing was off. I picked up Johnny's CR Kais and they are being repainted right now. I want to order new tires that fit better and go lower this spring with the full kouki aero. Here is what I am thinking:
F: 17x9 +17 215/45/17 (or 215/40?)
R: 17x9 +12 (5mm spacer) 225/45/17
Interested to see what you guys think. I know it won't be super cambered/aggressive, but I want to keep it semi-streetable with some grip out back. Power is going to be going from about 220whp to 290whp in the spring as well. I think those sizes should fit pretty well from what I have seen in this thread.
CamryOnBronze.com
CamryOnBronze is online now   Reply With Quote
Old 01-28-2010, 12:35 PM   #8349
InlandCarParts
InlandCarParts is an unknown quantity at this point
Send a message via AIM to InlandCarParts
19 x 9.5 +12
215 / 35
19 x 10.5 +12
235 / 35
Because there Not Real TE-37.
InlandCarParts is offline   Reply With Quote
Old 01-28-2010, 12:38 PM   #8350
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
LMAO.
You're fucking retarded.
Old 01-28-2010, 01:02 PM   #8351
kouki fanatic
kouki fanatic's Avatar
kouki fanatic is an unknown quantity at this point
Originally Posted by inlandcarparts View Post
because there not real te-37.
good lookin out you retard
kouki fanatic is offline   Reply With Quote
Old 01-28-2010, 01:15 PM   #8352
PoorMans180SX
PoorMans180SX's Avatar
Well first off, if you have the same size and offset, and a smaller tire, you realize it's not going to be as flush, right?
I would recommend 215/40 in the front and 225/40. 45-series sidewall looks goofy if you're going to want to go low. You might need bigger spacers though, depending on what camber you run. You're going to need at least a 5mm spacer in the front and a 10mm in the rear to make up for the thinner tire if you're wanting to rock the same camber specs/same tire flushness.
Or you could just rock a 225/40 up front and a 235/40 in the rear, which would give you a little more grip and less space to fill up with spacers.
Probably what you're going to want to do is just fit the tires and wheels with no spacers, adjust to your lowness and camber specs, and then figure out which spacers to run.
Old 01-28-2010, 01:24 PM   #8353
CamryOnBronze
Good info, thanks man. And yes, I realize a smaller tire will be less flush. I would be fine with running a bit less camber than the -2 degrees I was running. My rear tires got smoked in about 7k miles, but I must have gotten a bad alignment. I wouldn't expect -2 camber to eat a set of tires that fast without the toe or something being off.
CamryOnBronze.com
Old 01-28-2010, 01:32 PM   #8354
PoorMans180SX
Yeah they definitely shouldn't go away that fast. That's near stock alignment specs on some cars, the tires should last close to their rated length.
Make sure they dial in zero toe this time.
Old 01-28-2010, 02:06 PM   #8355
Z33dori
Z33dori's Avatar
ppl need to stop suggesting 225/40/17s
b/c there is only 1 company who sells them and they are sub par tires.
Old 01-28-2010, 02:09 PM   #8356
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
215/40 fronts, 225/45 rears.
Done and done.
-Jspec-
Instagram/CrimsonRockett
Old 01-28-2010, 02:32 PM   #8357
eds13
eds13's Avatar
eds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfectioneds13 is close to perfection
Send a message via AIM to eds13
i really liked my nittos when i had them, good tire, lasted a while and was decently grippy.
Done and done.
225/45 looks like balls imo, i'm going to be running that on a 9 just because i got a pair for $40.
i'd go with a 215/45 front and rear, so at least you can rotate them if you burn the rears down too much...
225/40's on 17x8+8
eds13 is offline   Reply With Quote
Old 01-28-2010, 02:59 PM   #8358
Ktown_drifter
Camryonbronze Id say go 215/45 17 up front the 215 40 17 in honda sizing.. and looks way too small
613driftwerks.ca
Old 01-28-2010, 08:04 PM   #8359
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
I would personally suggest 215/45s up front and 235/40s out back because they're almost exactly the same tire height.
OR do what Ed said and run 215/45s all around...but since your rear is already set up to accept a 245/40 I would say run the 235/40.
-2 shouldn't kill your tires in 7K either. I am pretty sure AP2 S2000s run -2.5 factory.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 01-29-2010, 01:01 AM   #8360
ILoveMyRHS13
Trader Rating: (25)
Nitto NT555s are subpar tires?
Old 01-29-2010, 01:15 AM   #8361
whiterps13
whiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to behold
For the price, yes.
whiterps13 is offline   Reply With Quote
Old 01-29-2010, 01:25 AM   #8362
ILoveMyRHS13
Trader Rating: (25)
Of course they're expensive, they're not common at all.
Old 01-29-2010, 01:25 AM   #8363
Z33dori
Z33dori's Avatar
for what you pay for them... if i found some for cheap i'd prolly grab them but... other than that i will never run them. But i'll be honest this opinion is based of driving turbo FWD cars with them... so yea... maybe its a lil biased .. idk give me some maybe ill change my opinions
im still in never ending debat my self of what to run on the front with my 17x9.5s... everyone keeps saying 215/40 or 235/40(replaces 225/45 i have on them)
Old 01-29-2010, 01:36 AM   #8364
franklin93zx
franklin93zx is an unknown quantity at this point
Someone didn't notice that they aren't on nico anymore....
franklin93zx is offline   Reply With Quote
Old 01-29-2010, 04:14 AM   #8365
Geezy
Geezy's Avatar
Originally Posted by l20bdime View Post
F: 18x9.5 -10 225/40R18 federal -4 degrees camber
R: 18x12 -14 245/40R18 federal -1.5 degrees camber
The front fenders are resting on the tires and it drift just fine like that.
front and rear fenders are Bmagic 30mm front and 50mm rear bowed
out.
And the reason for the big gaps betreen the bumper/fenders/hood is because with the increased angle from modded knuckles i was rubbing on the frame rails so i spaced my fronts out 15mm and my tires are litterally pushing my fenders out.
lol, how does that "drift just fine??"
RULES:
Old 01-29-2010, 04:51 AM   #8366
nathanong87
nathanong87's Avatar
what don't you understand....
natelife.tumblr.com
Old 01-29-2010, 05:08 AM   #8367
ThatGuy
Admin Asshole
ThatGuy's Avatar
Geezy, stop posting. If you have questions about someones car, then PM them, but stop cluttering this thread with your ignorance.
Old 01-29-2010, 10:52 AM   #8368
tokyo_black_uk
tokyo_black_uk is an unknown quantity at this point
F: 17" 9J +17
R: 18" 10.5j +5
Final pic has my revised suspension settings:
Front: -2.5 deg
Rear: -3 deg
Needs some thinner tyres next time I replace them..
tokyo_black_uk is offline   Reply With Quote
Old 01-29-2010, 11:42 AM   #8369
Nizzan4u2nv
Nizzan4u2nv's Avatar
Nizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura aboutNizzan4u2nv has a spectacular aura about
Send a message via AIM to Nizzan4u2nv
That car was in formula d/d1 from what I remember. So, id say it drifts more then just fine.
Dont think ive put this pic in here before. I still miss this car.
Nizzan4u2nv is offline   Reply With Quote
Old 01-29-2010, 01:33 PM   #8370
cemtoes
cemtoes's Avatar
cemtoes is an unknown quantity at this point
are you questioning tommy roberts drifting ability? lololol
get chill.
cemtoes is offline   Reply With Quote
