Group Buys Dedicated Forum for Group Buys. |
01-14-2010, 07:22 PM | #1 |
Skullworks - Evo/STi Brembo Caliper Brackets
WHAT:
-------------------------------------------------- Adapter brackets to install Evo 8/9 or STi Brembo calipers on your s-chassis. It's bee a while coming but they're finally here a fully R&D bracket that allows you to bolt the popular Brembo calipers to your 240. We obtained a set of Evo and a set of STi Brembo calipers took them completly appart and measured every conceivable feature on them to ensure proper upright location, pad placement and rotor offset. They're made here in the USA by us and test fitted on our cars. FEATURES: ------------------------------------------- - CNCd from 1018 Carbon Steel for strength - Zinc plated to withstand corrosion - 10.9 (Grade 8 equivalent) bolts and washers included for ease of installation We choose these features to ensure that the brackets will withstand the rigors of track use without compromise to safety. PRICE AND PAYMENT: ------------------------------------------------------ The price for these is $110 wich includes paypal and shipping fees. They will ship via US Priority Mail so it will take roughly 3-5 business days to get to you. paypal: stmaradona at yahoo dot com please include your username with your payment message. NOTES: ---------------------------------------------- As some of you may know, we started on these a few months back then stalled... and stalled... and stalled some more here's why: in order to clear the calipers back fins there needs to be a relief on the bracket around the upright threaded holes. Most of the existing brackets floating around do it this way. We weren't comfortable with this since we feel that by doing that the strength of the inner hole threads is compromised. This could be catastrophic to someone that heavily tracks his car. After much deliberating, we asked ourselves the question: What would we do if these were just for ourselves? We'd shave the back of the caliper and keep the threads on the bracket intact. So in a nutshell that's what we did. So you will need to shave your calipers down a bit (see pictures) to run our brackets. We are aware that some people will be turned off by this and will choose to go a different route. We're ok with that. The way we see it, at the end of the day it's about doing something right. Questions, concerns and comments are always welcomed. PICTURES: ---------------------------------------------- Amount of material shaved from calipers: Fitment: |
01-14-2010, 11:00 PM | #3 |
01-19-2010, 08:14 AM | #8 |
Z32 calipers are interchangeable with the s-chassis
so I would assume that they would however we haven't actually bolted and test fitted them on a z32 to confirm material for the STi brackets arrived we should be knocking those out this week |
01-19-2010, 12:12 PM | #9 |
Trader Rating: (130)
Feedback Score: 130 reviews
i'm very interested in a product like this, but i would like it to fit z33 track rotors.
iirc, the evo rotor is 12.65" and the z33 is 12.8" seems like it wouldn't take much to get .15" difference out of a similar design. heck, you could probably just take your brackets and flip em 180 so that the bent part faces up instead of down and have enough clearance. aaaaaanyways. i'm interested in that, thank you for making a cool product that many people have wanted for a long time. |
01-19-2010, 01:12 PM | #10 | |
anyhow, per racingbrake.com: Z33 Brembo 324x30mm - 12.8x1.2" Evo 8/9 320x32mm - 12.6x1.3" Evo X 350X32mm - 13.8x1.2" (for shits and giggles) so yes, the z33 rotors are marginally larger but also a different thickness that would require a redesign of the brackets not worth it but thanks for the interest |
01-22-2010, 01:02 AM | #11 |
how about a bracket to fit Z34 4 piston rotors up front and a bracket to fit
the Z34 2 piston rotors up in the back for the Z32 front/rear brakes? people are cheap they are not going to buy brembo calipers that's why I asked.
Nissan Japan: "road to happiness has many curves" Jdmlivin: "Jdm is dead, the yen is crazy" |
01-22-2010, 08:07 AM | #12 | |
we don't have any plans to make z34 brackets but if someone wanted them made and brought all the hardware - calipers, rotors, pads - it could happen |
01-22-2010, 07:33 PM | #13 |
Something like this?
Akebono Nissan 300ZX F&R 14 Inch Big Brake Kit w/ Stoptech Rotors, SS Lines, and Motul Fluid - Nissan performance parts Or brackets to run z32 calipers with z34 rotors? |
01-25-2010, 11:06 AM | #16 | ||
granted only for the fronts but still you could do an Evo front (and back if you do some work) for ~$1500 if you shop carefully and that's with 2 piece rotors. we haven't shipped any so I would be very surprised if someone was Quote:
we tried running the STi brackets this past weekend in a batch plate set up but the material proved too hard for the tooling so we have to take a different - longer - approach we're going to run them again in a few days after the oil blocks are done the same way we did the Evo ones then they all will go out to plating |
01-25-2010, 08:29 PM | #18 |
couple of weeks I recon
they don't really take that long to make it's just that 1018 destroys endmills so a careful approach is needed honestly we're more preoccupied with the oil blocks at the moment since people aren't knocking down our door for Brembo brackets |
01-26-2010, 11:19 PM | #21 |
i may have to get a set of these i already have the evo brembo brakes....hmmm ill take lots of pictures and be a sponsor(stick a sticker on my rear window) for a better price hahaha. =]
ill let you know im waiting on getting word from the machine shop on my build. |
02-01-2010, 01:05 AM | #24 |
are you guys ever going to make a secondary mount for the rear brakes? because that is pretty much what is holding me back from doing hydro ebrake because I would rather have a second caliper than T into the rear brake line. Also I am not cool enough to do hydro side brake anyways... But I will be pretending I'm awesome enough pretty soon soo... yeah
Drives a BRZ and is building a V6 S12 coupe. |
02-01-2010, 11:55 AM | #25 | |
02-06-2010, 12:20 PM | #26 |
Trader Rating: (29)
Feedback Score: 29 reviews
These brackets just mount the front calipers only, correct?
Any plans to fab brackets for the rear calipers as well? What brake lines would you use? - Custom/Stock Style/Z Conversion Lines |
02-07-2010, 12:44 AM | #27 |
How about the rears?????
I bought a set of SRT-8 rear calipers for front but no one is willing to measure them from center to center hole I'm 90% sure they are the same as the EVO/STI except they use a thinner rotor which a SVT Cobra has a similar offset.
With that being said I was under the impression that the STI fronts had the same bolt pattern as the Evo is that true? Also make some for the rear!!!! I bought a set for the rear but I didn't like the idea of drilling new holes where holes weren't before and tapping it. It doesn't appear safe to me. I'm thinking about trying to make them myself but heck if you guys are using carbon steel I'd rather buy it from you. I was just going to use mild. Also I'm new to this forum just joined today I'm actually have been part of Nico a few months though so I'm not a total (also usto do everything the hard way that is figuring it out myself so glad forums are around now) |
02-08-2010, 08:24 AM | #29 | ||||||
correct
to make one bracket work for both like we originally wanted to so my guess would the SRT calipers would need their own bracket made aswell Quote:
only way I can see us making brackets for the rears is if someone would be willing to bring us calipers and rotors to measure and test fit with we already spent a good chunk of money developing these brackets -3 sets or calipers, rotors, etc and frankly the interest isn't high enough for us to develop a rear solution since z32 rears work well as it is. Quote:
and you'll be fine ok |
02-09-2010, 08:27 PM | #30 |
Update:
we're done making the oil blocks for the other group buy and now our attention we'll be placed on getting these finished so expect them done and ready to ship in about a week's time we also decided to drop the price on these to $110 paypaled/shipped since it's been brought to our attention most of the 240 community isn't 5 lug. |
