03-31-2010, 08:10 PM | #1441 |
ok guys i need tire recommendations and sizes for 17x9.5s. its a set of cheap camaro wheels im picking up until i can get something else. I dont really want too much of a bulge and i would like to run the same size tires all around for rotation. im thinking 265/35s all around, but what are some tire recommendations for good side wall sizing?
04-01-2010, 07:58 AM | #1444 | ||
18x9 et+26 255/35 18x10.5 et+27 275/35
Quote of the year? Last edited by bshotts; 04-01-2010 at 02:04 PM.. Reason: wheel/tire specs |
04-01-2010, 03:39 PM | #1445 |
Yeah, I've been watching craigslist for some cheap mustang wheels. Haven't found any yet, but I was pretty sure the Camaro setup was different!
I would really like to pick up a set of those Mustang bullet wheels in 18's with the black face and polished lip.
LSX Kouki Project, swap completed in Dec 09 |
04-03-2010, 07:54 AM | #1449 |
Ya my bad guys, i thought the maros were 114.3 also. damn, looks like ill be pickin up some craigslist stangers. any tire suggestions for the 94-98 cobra wheels... the 17x9 i believe?
04-03-2010, 08:10 PM | #1450 | |
AV: 15X10,5 225/50 ET-12 AR: 15X10,5 265/50 ET-12 he needs to run those 265 at front...but not 50 lol... pleaseeeeeeeeee its hurting
TRUE thing: True ////OFFSET\\\\ is acheived without spacers Running on E85 570whp Precision 5862....laggy as fuck. hate it |
04-06-2010, 04:35 AM | #1451 | |
Smaller sidewalls in 15" in wide sizes are so hard to find that I had to stretch 225s on front. 265/50 for rears finally doesn't hurt too much. The 255/45 do exist (for fronts) but are ridiculously expensive and hard to find. And for rears I could run 285/40 but it's about the same problem. |
04-06-2010, 08:54 AM | #1452 |
wheel fitment
I am looking at running a new setup on my S14.
Would 18x9 +24 in Front, 18x10 +22 in Rear sit flush under a stock body? Im somewhat familiar with fitment but looking for a little help on this. Thanks! |
04-06-2010, 07:28 PM | #1456 |
As usual, depends on tire size and coilover/caliper clearance. Because of the sizes you are asking about, I'm assuming you are going with a Mustang rep setup, possibly Bullitts, and if so, you will need a 5mm spacer to clear the coil springs/lower collar. Brake caliper clearance will be fine, and with those sizes, a 235/255 stagger would sit flush with rolled fenders.
04-07-2010, 05:16 AM | #1457 | |
This is what Im running now: |
04-10-2010, 02:43 PM | #1459 |
MAX tires
I am trying to see if 17x9 +15 with 245/40/17 front and 17x10 +25 with 275/40/17 will fit stock s13 coupe without fender modification. (I am aiming for tires flush with fender, not tucked and zero camber due to daily driving.)
Is anyone running this? I've looked around here and found a someone running 17x10 +35 with 275/40/17. post #1412 here: http://zilvia.net/f/chat/166563-maxi...thread-16.html I have not found any 245/40/17 with 17x9 +15 wheels though. |
04-10-2010, 07:00 PM | #1460 | |
04-10-2010, 10:26 PM | #1461 |
Those Gt wheels don't look to shabby. Aren't they 17 X 8's?? Do you know if they happen to clear 300zx calipers?
04-11-2010, 01:23 AM | #1462 | |
calling for s13 with 17x9 wheels? What is the largest tire w/out fender modification?
I appreciate the feedback 1wheelwonder. Thanks so far... |
04-11-2010, 09:11 AM | #1463 | |
but your fitment would have to be so perfect, and you would need camber, so it wouldnt be worth the effort just go with a 255
2004 Nissan 350z 2002 Nissan Silvia |
04-11-2010, 11:06 PM | #1466 |
04-12-2010, 04:26 AM | #1467 |
Thanks, its a LS1 with a 4l60e. silviav8forums.com :: View topic - Randall's S14 video pg. 3&4.
04-16-2010, 08:53 AM | #1468 |
quick question. im sick to death of blowing my tires off every time i touch the gas pedal. i cant afford to have "sick fitment" or any of that shit, i just need some tire. i am in desperate need of rear tires, and am currently on 17x8" wheels, running a 225/45 on it. im very close to buying some 275/40 ecsta XS's from tirerack. any input? i am to the point where i dont care how it looks, i just want to go somewhere when i hit the gas. took this the other day with the boost controller turned off:
YouTube - just a quick 1-2 pull from the passengers POV. it was fun at first, but now it's annoying.
-Dane |
04-16-2010, 09:29 AM | #1469 |
Too many cars that could be fitment whores... I thought this was the maximum tire thread!?.. a 245 or a 225 is not a max tire on a 10" rim... BLAH...
chinastangs 17x10.5R 275 40 17X9F 225 45 Waiting on overs so I can run some beefy 305s...mmmm... |
