#31 | |
cONtRol FReAkS |
#32 |
![]() Join Date: May 2006
It means this connects to an ignition-switched power source.
#33 | |
![]() Join Date: Aug 2008
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 5 reviews
this is a noob question but how do i hook up the wire for the light on an after market boost gauge?
#34 |
Not a noob question at all ~ you want the light to come on with the marker/parking lights as well as the headlights, so you just need to tee or splice into the green/red wire coming out of the S13/S14 turn signal harness. Double check as I haven't messed with gauge wiring for about a year, but that should give you +12V with the lights switch on the 'first' or 'second' click, and no volts on 'off'.
#35 | |
![]() Join Date: Apr 2004
If you're just pulling a small bulb, then you can piggyback on the illumination circuit, like the radio illumination wire. If you're looking to pull big power, like big strobe lights or other audio equipment, then run the illumination power to a relay and pull power from the battery with the relay. |
#36 | |
there is a green/red wire and a red/green wire lol. i'm looking through the wiring diagrams now but holy shit
*edit use the red w/ green stripe wire. only comes on when lights are fully on the green w/ red stripe wire is hot all the time, even with the keys out and lights off
#37 |
just a quick question... the yellow/red wire thats in pin #3 of the main ecu harness, the one the is labled "Tachometer Signal Output" what exactly does that connect to in the engine bay? the reason i ask is that im not getting a tach signal in the Haltech software and cant seem to find what component it goes to in the fsm. someone should have an answer on this. thanks in advance
mike |
#38 | |
#39 |
was this in reply to my question? it doesnt seem like it. anyway, my tach has always worked since i did the sr swap years ago. now that i have the haltech though its not seeing a tach signal. does the cas send tach pulses to the ecu?
#40 | |
In response to your question, no the CAS does not send tach signals to the ECU, the ECU sends tach signals to the Tach. If you can't get a tach output from the Haltech, there are many tach adapters on the market you can use.
#41 | |
#42 | |
#43 | |
#45 |
ok you guys seem like you know what your talking about so i have a question i have a s13 black top engine but it runs on a redtop pfc it runs fine except the o2 sensor dose not read. When you look at o2 on the pfc it shows nothing. I was wondering if the o2 sensors are diff from a s13 red top to a s13 black top and maybe i need to switch some pins on the o2 or maybe switch some pins at the ecu. Every thing else runs fine i can see all my sensors except for my o2 any help would be great.
#46 |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
don't the blacktop's run the fatter O2 sensor like S14's?
i believe that the skinny O2 meant for the redtop puts out a different voltage signal. whether or not that would cause the problem im not sure. hopefully someone else can chime in. |
#48 |
They do, but the signals are very similar as I recall. I ran a blacktop (fat) o2 sensor in my redtop for years, always ran the same. I don't think that's the problem.
#50 |
#51 |
i have a blacktop that im wiring up right now. not sure if this is discussed but i have (or what appears to be) multiple brown wires on the power interface side of the harness. the original plugs were cut off all the way down to where the harness branches off to the maf and powersteering switch etc. no tach check or coil #1 check. are all these brown wires wired together and then to 12v switched?
#53 |
well i traced the wires back and 2 of the 3 brown wires go to the boost control solenoid and the other valve thing on the ignitor chip bracket. the other brown wire goes to the o2 sensor im assuming cuz it branches off into that direction
#56 |
very helpful......thanks
#57 |
![]() Join Date: Nov 2010
i have a replacement harness for my sr sr20det, it has the Black/Purple wires for the fuelpump.. And the car will not start, im having this problem:
http://zilvia.net/f/tech-talk/368662...p-problem.html |
#58 |
can someone please hook me uup with a s13 hatch dash harness diagram? The guy before me had ripped apart the ignition wiring for a push button start and i bought a OEM harness and have no idea what goes where. Thanks!
#60 |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
Switched power means that when you turn your key to different "switched" settings, it should get power.
Like On/Accessory/Start on your ignition switch.
