Old 05-07-2010, 01:12 PM   #1
iTUNE504
iTUNE504 is an unknown quantity at this point
can someone
point me into the right direction please through threads or first hand people
my car is actin up i have sr20det it doesnt start now ran good last night killed aheading into 5th gear all of a sudden pulled over and the intercooler pipe was off easy fix took off from shoulder of interstate and boosted clean all 3 gears till my exit and kills again (pissed by now) check it again but the pipe is still connect but now doesnt turn over doesnt seems to be getting gas im thinking TPS for sure and since i was running rich throughout the night anyways i think the MAF crapped out on me
and my little bro thinks i jumped timing and if so what is the worst case scenario of jumping time
iTUNE504 is offline   Reply With Quote
Old 05-07-2010, 01:28 PM   #2
keiglo
keiglo's Avatar
keiglo is on the path to ruinkeiglo is on the path to ruin
If your timing is messed up, you can cause a lot of damage to the motor. bent valves would probably be the most common.
as for everything else, im not sure since im not too familiar with turbo'd engines.
keiglo is offline   Reply With Quote
Old 05-07-2010, 01:35 PM   #3
iTUNE504
i was thinking the timing was messed up but was sure cause the car pulled all three gears then would back fire in 4th and 5th
Old 05-07-2010, 01:39 PM   #4
Darren
Darren's Avatar
Darren is an unknown quantity at this point
You might want to tell us what kind of car, what motor, what the setup is, etc.
Most cars have their own unique quirks and knowledge of the setup is crucial to diagnose anything
So if you really want the guys who know what they're talking about to help you, include this stuff...
edit: just noticed the motor is listed, but nothing about the setup....
Darren is offline   Reply With Quote
Old 05-07-2010, 01:44 PM   #5
keiglo
keiglo's Avatar
^ this. other people will be able to help you much more than i can.
i doubt your timing is off then. the timing affects all gears, and if you were able to go through gears 1, 2, and 3 with no problems, then i would look elsewhere for the problem, unless it the timing jumped right at the end. double check your timing just in case. not hard at all.
Old 05-07-2010, 02:13 PM   #6
iTUNE504
this guys doesnt read that well i did type what motor i have and its losing a tad bit of oil but thats not 100% my problem i put some in and holds but when on is when i lose oil but its getting the car to start
Old 05-07-2010, 02:18 PM   #7
iTUNE504
everything is stock but coilovers and aftermarket t25 turbo i just got the car dont know to much about the car problem wise im really new at trying to find out whats wrong with it its a s13 sr20det
Old 05-12-2010, 02:45 PM   #8
ajbrain
ajbrain's Avatar
ajbrain is an unknown quantity at this point
what kind of intercooler you have? mine is from ebay and its piping was off twice on freeway like your experience lol. i couldn't start the engine so i push the gas pedal all the way down and twist the key. then got it started. good luck bro.
ajbrain is offline   Reply With Quote
