04-24-2010, 10:20 AM | #1 |
S14 - STI Brembo Brake Upgrade
My car: 95 240SX SE non-abs (interested in a street/autocross setup)
I would appreciate some help finalizing a parts list for my choice of big brake upgrade. Please help me organize a good list for future forum-crawlers. Let me know if you see mistakes, have info or resources to add, and unresolved questions are highlighted in red. Thanks. Calipers: Front: STI (2004-07)(*note that the 2007 STI Special Edition is excluded) Rear: STI (2004-07)(*note that the 2007 STI Special Edition is excluded) Note that Brembo gold rotors can be touched up using Honda "Inca Pearl" paint code Y-61P. It is not a heat resistant paint though. Brembo calipers (Suburu) have a 2-step paint process: first a ceramic based paint and then the gold color. If your scratches/paint issues go through the ceramic coating this may only be a band-aid depending on the amount of heat that the particular area sees from brake use. Front Caliper Brackets: Necessary to fit STI Brembos on your S14. Sources: (1) florante rea on Zilvia.net forums (2) ManoNegra on Zilvia.net forums sells them (light grinding of calipers required). Refer to http://zilvia.net/f/group-buys/30040...-brackets.html Picture of grinding: http://img191.imageshack.us/img191/6...erground01.jpg Rear Caliper Shim: Should not be required if you choose Z32 rear rotors. Rotors: Since these are HUGE compared to stock, you will need to remove or trim the dust shields. Front: Evo 8/9 Rear: Z32 (1990-1996 300ZX) (note: Evo 8/9 rotors fit, but will not allow the Z32 parking brake assembly to fit) Brake Lines: Front: (1) Z32 "conversion" lines (Are these the same as stock Z32 lines or not?) (2) Stock or Stainless STI (2004-07) lines. (3) S15 Lines may work (anybody know for sure)(Nissan PN?) (4) R32 Lines may work (anybody know for sure)(Nissan PN?) (3) Other options? Rear: Same as front. Parking Brake: (1) R33 cables (necessary for Z32 e-brake assy)(PN KITR33PAIR from mynismo.com) (Nissan PN??) Parking Brake Assembly: (1) Z32 UNISA JECS on zilvi.net sells used assemblies. Refer to http://zilvia.net/f/sale-items/16670...-complete.html (2) Make a bracket to run a Wilwood mechanical parking brake like Ferrari (fabrication/welding required). Picture: http://www.jegs.com/images/photos/950202280.jpg (3) Run without it (park it in gear). (4) Read the $100 hydro e-brake how-to : http://www.zilvia.net/f/tech-talk/93...tml#post842628 Master Cylinder: Needed if you don't want pedal feel to SUCK. Note that some bending of stock brake lines may be necessary. (1) Plug&Play from FRSport: DIF Tokico Nissan Z32 300ZX Brake Master Cylinder Upgrade for 240SX (2) Z32 (many choices)(for street/autocross my choice is a 1") Refer to The Definitive 300ZX Brake Swap! 46010-30P01 Manufacture date 2/89 – 7/90 (17/16" NA Tokico) 46010-30P02 Manufacture date 7/89 – 7/90 (17/16" TT Tokico) 46010-30P02 Manufacture date 7/90 – 2/91 (17/16" NA & TT Tokico) 46010-30P10 Manufacture date 2/89 – 7/90 (15/16" NA Nabco non-ABS) 46010-30P21 Manufacture date 2/89 – 7/90 (17/16" NA Nabco) 46010-30P22 Manufacture date 7/89 – 7/90 (17/16" TT Nabco) 46010-30P22 Manufacture date 7/90 – 2/91 (17/16" NA & TT Nabco) 46010-45P00 Manufacture date 9/91 – 9/93 (1" NA TT Tokico) 46010-45P00 Manufacture date 2/91 – 9/91 (1" NA & TT Tokico) 46010-45P20 Manufacture date 9/91 – 9/93 (1" NA & TT Nabco) 46010-45P20 Manufacture date 9/93 – Up (1" NA & TT Nabco) Dual Diaphram Brake Booster: Not necessary, but can improve/change pedal feel/effort required. (1) S14 with ABS (Nissan PN?) (2) Z32 (ABS?)(Nissan PN?) Pads: Evo 8/9 pads are required because STI pads are too thick. (1) Porterfield R4-S (2) EBC Greenstuff (3) Ferodo ds2500?? (4) Hawk HPS Fluid: Dot 4 only!!! Dot 5 is for racecars. (1) Motul RBF600 Last edited by Midnight Turbo; 06-19-2011 at 09:33 PM.. Reason: Updated information |
05-13-2010, 05:01 PM | #4 |
s14 w/abs p/n #: 471072f96
z32 p/n#: 4721030p06/7/0 For some reason the z32 came up with three different numbers, maybe it comes with the master cylinder? And both the s14 and z32 boosters are dual diaphragm. |
05-13-2010, 07:02 PM | #5 | |
Brake Lines:
You need to use the banjo style lines like OEM calipers since the Brembors we've seen don't have the 'nipple' in the hole the z32 caliper has also quote from another post: Quote:
you could leave the caliper alone buy you may end up with uneven pad wear |
05-14-2010, 12:23 AM | #6 |
Well I guess you could call this a place holder post for me. This is what my setup is going to be as of next week (S14A).
1: 04 STi Brembos 1.5: Skullworks STi adapters (revised) 2: FTP Z32 conversion lines w/ banjo bolts to fit onto STi Calipers 3: Stoptech Evo 8/9 front rotors 4: Centric 93 300ZX Turbo BMC 1" I want to see how this works for the time being, so for the rear im just going with stock S14 rear rotors and stoptech pads. The brake bias might be slightly off, but I can always put on the rear STi calipers later. I will update this as soon as I put everything on. |
05-15-2010, 03:55 PM | #7 |
im doing the evo 8 brembo on my front of my s14
you need the front s14 braided lines to work on the front calipers and i beleive you need the same on the rear. the z32 lines dont use a banjo fitting |
07-28-2010, 08:12 PM | #8 |
brembo upgrade
I am in the process of doing this conversion on my S14 as well, however I am using an EVO front and STI rear. The last components I need to buy are the brake lines, and I am still uncertain as to what is the best to use. As far as I can see, a stock line will work in the rear. The banjo fitting fits within the guides, and the inside diameter are both 10mm. I am assuming that the length will be okay, as the caliper position is only slightly different.
I will not use a Z32 conversion lines in the front, so I need to find out if the stock front lines will work for the front.......help Stock rear lines (left) vs Stock STI line (right) Stock line on caliper |
08-30-2010, 11:11 PM | #9 |
from what i hear the sti brembos work with the stock rear line
i had a quick question also, the 04-07 sti rear bremos are a perfect bolt on fit with the evo rear rotors (with a 3mm spacer on the calipers) anyone know what year rotor to get from the evo? also does anyone know if the z32 rotor he plans on using is going to have the same fitment as the evo rotor? im not worried about the ebrake situation atm, i plan on running a line lock for now lol
Friends don't let friends build SR20's. Have faith in your KA!! |
09-05-2010, 06:52 PM | #10 |
Don't forget, you'll need bolts that are compatible with the calipers to count them, and for the brake line mounting.
I dint know if the Nissan bolts will work with brembos (thread pitch, etc) |
09-05-2010, 08:12 PM | #11 | |
09-11-2010, 10:46 AM | #12 | |
What year evo for rear rotors?? I think you should look for whatever is compatible with a 2005 evo. Does that sound right guys?? |
09-11-2010, 11:17 AM | #13 |
09-15-2011, 12:27 PM | #16 |
For once and for all:
Brembos (Evo and STi) use a banjo style type of line OEM lines will work if you're strapped for cash or buy any oem type ss line (like SPLs) |
03-03-2013, 06:06 PM | #21 |
I got my hands on a full set of 2011 STI brembos. I was only going to use the fronts as the rears have different mounting when compared to the 07 and prior. The front of the 08+ STI brembos use the same mounting holes as the 07 and earlier but someone who makes the brackets said they bolt spacing on the EVO is a little closer than the STI caliper, has anyone ran into this?
09-02-2016, 02:51 PM | #23 |
Trader Rating: (28)
Feedback Score: 28 reviews
Bump. Any others running a full 04-07 STI brembo setup on an s-chassis? Just wanted to see what parts you ended up using to make the front calipers work? (Brackets, brake lines, and rotors)
09-02-2016, 07:49 PM | #24 |
http://zilvia.net/f/showthread.php?t=300408
get rotors for an sti, not the evo and associated brake lines and be wary of bumping topics from the grave
Mad Moody Science LLC In house is the best way. |
