Mid-Atlantic States DC, Delaware, Kentucky, Maryland, New Jersey, New York, Ohio, Pennsylvania, Virginia, and West Virginia. |
02-11-2009, 01:30 PM | #1 |
Zerolift - Cincy, Oh - Shop S13 Vert Build Up
Zerolift Autolab Drift S13 Vert Build Progress
Chassis : 1994 S13 Vert Fully Stripped Media Blasted Remove All Paint, Seam Sealer, etc ... Cut all Vert Top Mounts, Motors, Linkage Out of the Way Extend Front Frame rails Build Supports and Framework for V Mount Box in rear seat compartment and vert linkage area Box in Spare Tire / Floor, Build Box for Fuel Cell Roll Cage Fabricated Underbody Cage for Fuel Cell Stitch Welded Front End Tubbed Cage & Car Was Painted Stainless Hard Brake Lines were Fabricated using AN Fittings Engine : SR20det Motorset - 87MM Bore Lightened Rotating Assembly ... -10 lbs ! JE Pistons Manley Turbo Tuff Rods ACL Race Coated Bearings Port Flow Cylinder Head, Valve Job, Port, Polish, The works........ Supertech Springs & Retainers Kelford Camshafts Apexi Head Gasket Custom V Mounted Intercooler Custom C&R Radiator Custom Radiator Inlet/Outlet Flanges - AN Peak Boost Top Mount Manifold GT3076R Turbo Polished & V Band 44mm Tial Wastegate All Oil & Coolant AN Fittings & Stainless Braided Line Cryo2 Intercooler Coil Fuel System : ATL Fuel Cell Bosch High Pressure Fuel Pump Electronic Level Sender Stainless & AN Feed / Return Lines HKS 740cc Injectors Drivetrain : 5 Speed Sr20det Transmission Silvia C's Short Shifter Driveshaft Shop Aluminum Driveshaft Driveshaft Shop Axles - Stg1 OS Giken LSD Custom Cryo Treated Final Drive ACT Extreme Clutch Nismo Slave Custom Clutch line - AN & braided Suspension : Subframe Removed & Painted Solid Aluminum Subframe Bushings Installed IKEYA Formula Front and Rear Control Arms Peak Performance Suspension Linkage Function & Form Remote Reservoir Coilovers Carbing Front Strut Bar w/ Bmc Stopper Brakes : Wilwood 13" Big Brake Kit Wilwood Brake Lines Z32 Rear Brakes Hydraulic E-Brake - Stainless Hard Line w/ AN Z32 Brake Master Cylinder Exterior / Interior : JDM Front End Conversion Origin-Lab Aggressive 4pc Kit Origin-Lab Wide Front Fenders Origin-Lab Wide Rear Over Fenders - Flexed C-west Carbon Side Mirrors Seibon CF Hood - Cut for V mount Seibon CF Trunk Lid Seibon FRP Doors Seibon Carbon Kevlar Seats Custom hard mounted seat brackets Sparco Steering Wheel Sparco 3" Harnesses Custom Aluminum Battery Box DEFI > All Gauges incl Tach Defi Control Unit Custom Carbon Gauge Cluster Din w/ Defi Tach Wheels : Enkei RPF1 SBC Coated 18x9.5 & 18x10.5 SPONSORS : ACT Clutch ATL Fuel Cell SEIBON Origin-Lab ENKEI Wheels Function & Form Suspension Peak Performance Peak Boost Bobs Braided Lines International Engine Supply
Contact: Phone - 513-874-2508 AIM - ZLR0bert Email - [email protected] Zerolift facebook - http://www.facebook.com/Zerolift |
02-12-2009, 04:38 PM | #4 |
450whp easily - but more than likely will be tuned to about 400.
Race gas and 25-26lbs it should make over 500 without breaking a sweat.
02-27-2009, 11:52 AM | #6 | |
Trader Rating: (22)
Feedback Score: 22 reviews
lookin good, its about time
1997 Nissan 240sx SE(Rb25det+GT35r= 486whp on 93pump):http://zilvia.net/f/premium-member-b...oject-2-a.html Quote:
02-27-2009, 09:10 PM | #8 |
Really ? I was hoping for "Get em ricky bobby"
Thanks for all the positive feedback
06-16-2010, 06:58 PM | #10 |
