tricks you guys use
so, i think its time we have a little small tricks up our sleeves thread going on. help each other out maybe?
this is like small stuff you guys (and gals) do to make life a bit easier to work on our 240's one i can think of now. old leather belt wrapped around an oil filter = easy way to get it off with nice grip |
my
when... putting on stock shocks unbolt the rear sway bar
installing kouki wings make a cardboard cut out of the base and then tape it on the trunk to drill your holes vice grips for removing fuel injectors on ka if flat head won't pop it out |
don't change your spark plugs when your engine is completely cold.. (like when your car has been sitting without a start up for a couple of hours).
i thought metal expands as temperature decreases, so i was thinking wrong when i changed mine LOL. this might be common sense, but not for everybody!
White '90 S13 Fastback (SOLD in '07) |
#10 | |
![]() Join Date: Aug 2004
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
if u try this use the big white ones not black
Red Rocket |
![]() Join Date: Aug 2009
Use a metal pipe to extend a breaker bar to generate more torque if you don't have a pneumatic impact wrench. My friend saved my ass with this when we used this method to remove the flywheel bolts.
#12 | |
![]() Join Date: Jul 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
- unbolt the battery when doing electrical work
![]() Join Date: Jan 2007
Whatever that thing is you were trying to avoid doing to get to a part (lifting the motor, taking out the dash, taking off the exhaust) just do that first.
It will save you like an hours worth of bruises and knuckle gashes.
#16 | |
![]() Join Date: Nov 2004
Jack it up from the crossmember, subframe, diff, or tow hook.
#17 | |
![]() Join Date: Nov 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
NO....do not try and lift car from the the lower Radiator support....it will bend....use cross member or tow hooks for the front....and diff for the rear.
#18 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
if you dont have an impact gun and need to remove a flywheel (whether motor is in or out of the car)
withe trans removed and clutch press plate removed...take an upper trans bolt and re install into blockon the side..reinstall on of the press plate bolts to the FW... jamb an extension bar or breaker bar (something long enough, strong enough, and thin enough) that can be jamb between the 2 bolts to keep the FW from freespinning...and break tension PB blaster of WD-40 ur shit prior... this method can work with either one person doing the work...but 2 is best...
![]() ![]() PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r ![]() |
#23 |
![]() Join Date: Dec 2003
Trader Rating: (22)
^This is pro, I use it all the time. Just don't do it with your pretty Snap-On's. reason 101 to keep around a good set of "China" box wrenches
WD-40 for removing sticker goo... Works like a champ.
#24 |
buy liquid wrench.
I used it on my suspension parts and it made a huge difference. I got it from the dollar store for 2.50 or something. just spray a little, let it soak in for a minute and start wrenching |
#25 | |
i like this thread
@UpshiftEngineering |
#27 |
Filling/bleeding radiator……this works great…esp if it is a PITA to jack up the front of your car…
Take a water bottle like a 20oz one….cut to bottom off…remove the cap and tape up the neck..(the area wit threads on it) with electric tape..just enough so that u can put it in the radiator and make a nice tight seal (very important). Use that to fill radiator…keep bottle half full of coolant/water….as long as u keep the bottle half full it will be the highest point in the system and will allow air to come out…plus u will see the bubbles and know when there is no more air in the system.
#30 | |
![]() Join Date: May 2010
i use a nickle to cover up my antenna hole on my coupe. doesnt leak either. |
