Old 06-19-2010, 02:59 PM   #1
xs042lol
xs042lol is an unknown quantity at this point
tricks you guys use
so, i think its time we have a little small tricks up our sleeves thread going on. help each other out maybe?
this is like small stuff you guys (and gals) do to make life a bit easier to work on our 240's
one i can think of now. old leather belt wrapped around an oil filter = easy way to get it off with nice grip
xs042lol is offline   Reply With Quote
Old 06-19-2010, 03:11 PM   #2
saleaf
saleaf's Avatar
saleaf is an unknown quantity at this point
my ... since im cheep. i dont have a low profile jack or low profile ramps. i built a ramp out of 2x6 pieces of wood to get my car up about 6 in. easier access..
saleaf is offline   Reply With Quote
Old 06-19-2010, 03:13 PM   #3
lflkajfj12123
when... putting on stock shocks unbolt the rear sway bar
installing kouki wings make a cardboard cut out of the base and then tape it on the trunk to drill your holes
vice grips for removing fuel injectors on ka if flat head won't pop it out
Old 06-19-2010, 03:55 PM   #4
TheRealSy90
TheRealSy90's Avatar
Great thread idea, i'm eager to see some posts in here. Unfortunately I don't have any tricks yet.
Such a good signature.
Old 06-19-2010, 04:18 PM   #5
gerson408
gerson408's Avatar
gerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymoregerson408 is not welcome here anymore
i go over a small brick so i can fit a jack under.
gerson408 is offline   Reply With Quote
Old 06-19-2010, 10:30 PM   #6
The Hamsterball
The Hamsterball's Avatar
The Hamsterball is making a name for him/her selfThe Hamsterball is making a name for him/her self
don't change your spark plugs when your engine is completely cold.. (like when your car has been sitting without a start up for a couple of hours).
i thought metal expands as temperature decreases, so i was thinking wrong when i changed mine LOL.
this might be common sense, but not for everybody!
White '90 S13 Fastback (SOLD in '07)
The Hamsterball is offline   Reply With Quote
Old 06-20-2010, 04:37 AM   #7
Renelovesnike
Renelovesnike's Avatar
Trader Rating: (30)
Renelovesnike is an unknown quantity at this point
Feedback Score: 30 reviews
floor jack bar as a breaker bar... IT DOES WONDERS!!!
Renelovesnike is offline   Reply With Quote
Old 06-20-2010, 09:44 PM   #8
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
Zip ties to replace every bolt holding your Fenders, bumper and any other exterior pieces...
PeaceOnesxWai is offline   Reply With Quote
Old 06-20-2010, 11:40 PM   #9
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Also works great for rolling/pulling fenders.
Old 06-21-2010, 03:23 AM   #10
apex
apex's Avatar
Trader Rating: (44)
apex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfectionapex is close to perfection
Feedback Score: 44 reviews
this=stupid, zip ties get brittle in the sun esp. black ones so when ur on the freeway and a hard wind hits oh later bumper seeya fender
if u try this use the big white ones not black
Red Rocket
apex is offline   Reply With Quote
Old 06-21-2010, 04:22 AM   #11
J3123MY
J3123MY is an unknown quantity at this point
Use a metal pipe to extend a breaker bar to generate more torque if you don't have a pneumatic impact wrench. My friend saved my ass with this when we used this method to remove the flywheel bolts.
J3123MY is offline   Reply With Quote
Old 06-21-2010, 06:50 AM   #12
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
- unbolt the battery when doing electrical work
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 06-21-2010, 07:01 AM   #13
murda-c
murda-c's Avatar
Whatever that thing is you were trying to avoid doing to get to a part (lifting the motor, taking out the dash, taking off the exhaust) just do that first.
It will save you like an hours worth of bruises and knuckle gashes.
Old 06-21-2010, 09:47 AM   #14
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
^^YESSS because in the end, you're going to take that shit out anyways.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 06-21-2010, 10:28 AM   #15
Sterlz
Sterlz's Avatar
Sterlz is an unknown quantity at this point
if you have an s13 try not to jack it from the jack points, try a corner of a subframe or rad support
Sterlz is offline   Reply With Quote
Old 06-21-2010, 10:38 AM   #16
!Zar!
!Zar!'s Avatar
Don't jack a car up from the radiator support.
Jack it up from the crossmember, subframe, diff, or tow hook.
Old 06-21-2010, 10:39 AM   #17
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
NO....do not try and lift car from the the lower Radiator support....it will bend....use cross member or tow hooks for the front....and diff for the rear.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 06-21-2010, 10:44 AM   #18
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
if you dont have an impact gun and need to remove a flywheel (whether motor is in or out of the car)
withe trans removed and clutch press plate removed...take an upper trans bolt and re install into blockon the side..reinstall on of the press plate bolts to the FW...
jamb an extension bar or breaker bar (something long enough, strong enough, and thin enough) that can be jamb between the 2 bolts to keep the FW from freespinning...and break tension
PB blaster of WD-40 ur shit prior...
this method can work with either one person doing the work...but 2 is best...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 06-21-2010, 10:59 AM   #19
240sxvaj
Trader Rating: (38)
240sxvaj is an unknown quantity at this point
Feedback Score: 38 reviews
Have an extra person with you at all times no matter what your doing even if its under the hood only because the hood might just fall on you lol!
240sxvaj is offline   Reply With Quote
Old 06-21-2010, 11:33 AM   #20
94spitfire91
94spitfire91's Avatar
94spitfire91 is an unknown quantity at this point
Have the scissor jack that came with the car handy.. it just barely fits under the car while my other jacks do not because of how low the coilovers keep my car at.
94spitfire91 is offline   Reply With Quote
Old 06-21-2010, 11:39 AM   #21
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
Double box end breaker....
DJPimpFlex is offline   Reply With Quote
Old 06-21-2010, 11:58 AM   #22
Psychomoongoose
Psychomoongoose's Avatar
Psychomoongoose is an unknown quantity at this point
eeeewww is that a booger?
Psychomoongoose is offline   Reply With Quote
Old 06-21-2010, 12:05 PM   #23
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
^This is pro, I use it all the time. Just don't do it with your pretty Snap-On's. reason 101 to keep around a good set of "China" box wrenches
WD-40 for removing sticker goo... Works like a champ.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 06-21-2010, 12:43 PM   #24
bllabong89
bllabong89 is an unknown quantity at this point
buy liquid wrench.
I used it on my suspension parts and it made a huge difference. I got it from the dollar store for 2.50 or something. just spray a little, let it soak in for a minute and start wrenching
bllabong89 is offline   Reply With Quote
Old 06-21-2010, 01:04 PM   #25
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
Originally Posted by bllabong89 View Post
buy liquid wrench.
PB Blaster is the shit for this. break anything loose....almost
i like this thread
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 06-21-2010, 01:11 PM   #26
murda-c
murda-c's Avatar
Anti seize everything!
Old 06-21-2010, 01:55 PM   #27
japslapsilvia
Filling/bleeding radiator……this works great…esp if it is a PITA to jack up the front of your car…
Take a water bottle like a 20oz one….cut to bottom off…remove the cap and tape up the neck..(the area wit threads on it) with electric tape..just enough so that u can put it in the radiator and make a nice tight seal (very important). Use that to fill radiator…keep bottle half full of coolant/water….as long as u keep the bottle half full it will be the highest point in the system and will allow air to come out…plus u will see the bubbles and know when there is no more air in the system.
Old 06-21-2010, 08:55 PM   #28
heavenboundkevin
heavenboundkevin's Avatar
heavenboundkevin is an unknown quantity at this point
dont waste money on a spark plug removing socket. use the wire/boot. i thought i was SOL cause i didnt have one and my dad schooled me by saying that.
Originally Posted by rat240 View Post
sick bro .... hella jdm foshow i love haters
heavenboundkevin is offline   Reply With Quote
Old 06-21-2010, 09:05 PM   #29
E-Warrior
E-Warrior is an unknown quantity at this point
I laughed.
E-Warrior is offline   Reply With Quote
Old 06-22-2010, 12:26 AM   #30
XxCAPTAINxX
XxCAPTAINxX's Avatar
XxCAPTAINxX is an unknown quantity at this point
damn thats a good one i'll remember that.
i use a nickle to cover up my antenna hole on my coupe. doesnt leak either.
XxCAPTAINxX is offline   Reply With Quote
