#2102 |
hand tight, then another half turn
#2105 |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
do you guys have any tricks to keep your license plates from getting stolen from your S13? I just got mine stolen today and I was to keep from it happening again. Please and thanks.
#2106 | |
![]() Join Date: Dec 2005
Is is starting to slip or is it fairly new? The more info the better Sent from my iPhone using Tapatalk
E92 M3 19" wheels for sale///JWT Cams and Springs +30whp for sale... cheap. |
#2107 |
My hatch has a weird ticking coming from the middle to rear end. I haven't been able to pin point it; but it only ticks when moving and ticks faster as speed increases and at 17mph i get a shake in the rear end. Any ideas what could be wrong?
#2108 |
I recently installed my bn sports hatch. when I removed the stock hatch, I cut the wires coming from the chassis ( for the defroster and 3rd brake light I assume) . Well the 15a fuse (stop lamp) blew. I replaced it and then when I stepped on the brakes, it blew immediately. So I'm assuming its because theres an exposed wire in the circuit. So how do I get it to where that fuse stops blowing? Do I need to cap off that wire?
#2111 |
nuub questions help
ok i have the ka24de its makeing the rattling sound, im assuming it the timeing chain guide from what i read
1. before i remove my valve cover do i have to drain my oil? 2.can i just leave to motor like that with guides broken and makeing the rattleing noise?can any problems accur? 3.to get the bottom guide off do i have to remove the front cover 4 and if i just wait and get a time chain kit ,can it be done with out removeing the engine out the bay? |
#2112 | |
![]() Join Date: May 2006
![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
2. Just take out the guide. It's super easy. With the chain grinding away on the guide, there'll be small metal particles in your oil. I haven't heard of anyone having trouble with that yet, but I'd prefer to have fresh clean oil in my engine. 3. Yes 4. Yes |
#2113 | |
does noise only come from the top guides or the bottom as well? and im thinking no ,but can i reuse the valve cover gasket |
#2114 |
also
ok so my window hasnt worked since i got the car a few months ago,the amp clicks so i thought it was the motor,took the motor out cleaned alittle bit,tried it and it worked for a sec after jiggleing the plug to the amp,then stoped .so then i took the motor and pluged it to the passenger side and it works fine. so my question is if the amp clicks is it bad?? and if my amp is bad can i bypass it or do i need the amp?? o yeah i have a 95 s14 |
#2115 |
will a 17x10 zero offset wheel fit on a s13 without hitting the coilovers? i know its gonna poke out but i need to know... thanks in advance.
JS4HATERS |
#2116 | |
my question, who steals plates? |
#2117 | |
on board diagnostics, obd. obd1(01 lol) obd1 started in like 88 to 94-95 i believe. not sure on the start date really. all it had was pretty much check engine light codes, all of it was manufacture specific, so nissan obd plugs wont be the same as toyota obd plugs. really no performance gain other than you can do much more with the engine without throwing codes, like turbo and what not. obd2, you have much more communication with the engine. Any little issue that can occur will be stored on the diagnostics log and you can check it with a scanner, most plugs are also universal. Only problem, it communicated with alot of stuff in your engine so you cant really remove stuff without getting codes, like emissions stuff and shit. Modifications are easier with obd0/1 engines, cause it isnt really informative or controlling, but obd2 makes it easier to troubleshoot your engine in the event of a problem |
#2118 |
may be an axle, worn rotor, or gear. my brake pad slipped off the shim and wore into my rotor. creating a tick that eventually grew into a whine. check everything in your back end
#2119 | |||
Any one please help |
#2122 | |
Trader Rating: (38)
& to answer your question, I don't even know, man. I drove my dad to Costco to go get some groceries and when we came back to my car, someone stole my rear license plate. Maybe they wanted to take my tags, idk. But whatever it's all said and done. |
#2123 | |
i honestly dont even know if its legal, but it shows and i have a front plate. so they can suck my nuts, its a loop hole pretty much, as long as it shows. just like how some people stuff it behind their bumper ziptied to the radiator/support, same concept but different area i would rather have a ticket for like obstructed view of license plate or some bullshit than no plate at all, you know? |
#2125 |
my side markers on the driver side dont light up, but my passenger side does. this is for the front and back
is there a separate fuse for each, or something i should look at? i find it wierd that only one side works, since they should all have 4 separate connections... you know what i iz sayn |
#2128 | |
Nothing says racecar like a stock car with no interior. |
#2129 | |
they are on la Brea and Adams in los angeles, just exit the 10fwy and take la Brea south and turn right on Adams blvd, they are located right after the autozone on the corner. I am assuming those are special gapping spark plugs? I got mine there no one else had them. they ordered them and had them by the afternoon.
#2130 | |
![]() Join Date: Jun 2010
I found a spot in garden groove california that had ngk bkr8 and 9's great price also
