Old 07-27-2010, 09:18 PM   #61
DJDANGER24
DJDANGER24's Avatar
Just curious, when were you in Oki ?
DJDANGER24 is offline
Old 07-27-2010, 09:43 PM   #62
Sileighty_85
Sileighty_85's Avatar
04 to 07
meslgth
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Sileighty_85 is offline
Old 07-28-2010, 06:11 AM   #63
bb4_96
bb4_96 is an unknown quantity at this point
marines?....
bb4_96 is offline
Old 07-28-2010, 07:54 AM   #64
Sileighty_85
nah Air Force
後輪駆動車1番
1986 SR86 - 200ish
Old 07-28-2010, 05:07 PM   #65
SinGarage
SinGarage's Avatar
SinGarage is an unknown quantity at this point
Very nice write up and very informative. I am in the same boat as you S14 with series 2 RB25 swap. I just need wiring, clutch pedal install, fuel pump, custom DP and misc. things installed. Let me know who will you use for the wiring job or who you would recommend.
SinGarage is offline
Old 07-28-2010, 06:37 PM   #66
Sileighty_85
Wiring Specialties Replacement Harnesses
Yury does good work, i had him do my SR harness 3 years ago. Never had an Issue
And hes making new premade harness's, which is what ill be getting when they are completed
後輪駆動車1番
1986 SR86 - 200ish
Old 07-28-2010, 06:41 PM   #67
GSXRJJordan
GSXRJJordan's Avatar
I've done tons and tons of RB wiring conversions, from mild (basic inspection, power and dash harness conversions) to wild (my Mil-spec tucked/loomed RB25 harness with Mil-spec circular connectors).
I've heard good things about his work, and he's been around forever, but heard that the wait times get ridiculous. Never used him myself (obviously).
GSXRJJordan is offline
Old 07-28-2010, 09:16 PM   #68
Om1kron
Om1kron's Avatar
haha I feel sorry for you, you will become the online authority on who to ask for free about rb swaps.
Wayne Edwards
https://om1kron.blogspot.com
Om1kron is offline
Old 07-29-2010, 10:58 AM   #69
Sileighty_85
Yeah i know im already starting to get alot of PM's maybe I should charge ppl for PM's haha
後輪駆動車1番
1986 SR86 - 200ish
Old 07-29-2010, 11:02 AM   #70
roboticnissan
roboticnissan's Avatar
roboticnissan is making a name for him/her selfroboticnissan is making a name for him/her selfroboticnissan is making a name for him/her self
haha yah im just thinking of questions to ask you, havnt come up with any yet tho
roboticnissan is offline
Old 07-29-2010, 05:53 PM   #71
SinGarage
SinGarage's Avatar
I have contacted Yuri already and he is very helpful. Currently he does not have a plug and play option at the moment for my swap. I will buy one later when it's available.
You've got a PM.
Old 07-30-2010, 12:53 AM   #72
40cal
40cal is an unknown quantity at this point
wow, i think i read every single post here.
good job!
40cal is offline
Old 07-30-2010, 10:13 AM   #73
BlueSi4
BlueSi4 is an unknown quantity at this point
This is a sick build, props for taking the time to document everything the way you're doing it!
BlueSi4 is offline
Old 07-30-2010, 10:26 AM   #74
stockbee
stockbee's Avatar
stockbee is an unknown quantity at this point
Send a message via AIM to stockbee
subscribed. haha, love the fact that in one of those pictures the motor is about the same size as your wife haha. keep up the good work!
stockbee is offline
Old 08-03-2010, 04:56 PM   #75
Sileighty_85
Thanks guys for the comments.
Before I start I know i could get some Mishimoto single fans and mount them but i want the FAL's since they cover more surface area and the RB's need the cooling systems kept in check.
So I got in my new condenser today, I figured Id replace it since I'll be reclaiming the freon and pulling it to install the the FAL's
Plus seeing that 12 years of elemental damage isnt helping the cooling capacity
Current condenser, doesnt look bad but the fins are worn pretty thin in the bottom plus the design is 12 years old
New design more fins= more cooling
So here is gonna be the tricky part, making the FAL's, condenser, and Koyo Rad fit up front without cutting the core support or anything drastic. Im not gonna lie when it comes to me fabricating its not pretty, but damn it, it will work haha.
so from the bottom of the lower core support lip to the Koyo I have about 6.5cm (2.5 in)
the New condenser is a little bit thicker Pretty much what im gonna do is mount the FAL's to the condenser and reloacate the condenser closer to the Koyo (these are Pusher fans)
here is a side measurement (unsprung) looks like I have plenty of room but the bottom the FAL covers have a .5 mil lip
there is a .5cm lip that is where the Lower core support lip will hit, Which makes it sit at about 6.0cm, I guess i could shave it down if needed
But when mounted and pressure applied I can get it back down to 5.5 CM which will give me just enough maybe
I know you need a little bit of space inbetween the condenser and Radiator but I think running a pusher I wont have to worry about it. But there will be about a 1cm space due to this outlet tube.
hopefully I can start the swap next month if Jeff Jordan can do my wiring Harness (my harness is pretty fucked up)
後輪駆動車1番
1986 SR86 - 200ish
Old 08-09-2010, 05:41 AM   #76
Swamped13
Swamped13 is an unknown quantity at this point
great build.
In for how to do all the a/c work.
Swamped13 is offline
Old 08-13-2010, 04:58 PM   #77
fender-startocaster
fender-startocaster's Avatar
fender-startocaster is an unknown quantity at this point
this is great! really puts how much work and money will go into swapping an rb.
fender-startocaster is offline
Old 08-28-2010, 08:24 AM   #78
aardvark
Trader Rating: (22)
aardvark is an unknown quantity at this point
Feedback Score: 22 reviews
planning the same swap. curious about using the a/c and the cooling issues with this swap tho.
aardvark is offline
Old 09-01-2010, 11:12 PM   #79
Sileighty_85
An Unrelated RB Update
Got a whole Z32 Brake Setup for $43 from a Junk yard in AL!!
Cleaned them up and painted them Red
Cleaned the Lettering
My Agency Steel Braided lines will be here tomorrow, so if the weathers good then i can install them
後輪駆動車1番
1986 SR86 - 200ish
Old 09-02-2010, 12:21 AM   #80
buentellomma
buentellomma's Avatar
buentellomma is an unknown quantity at this point
wow what a deal, if you dont mind me asking, which junk yard? im from alabama and in need of some z brakes
buentellomma is offline
Old 09-02-2010, 12:48 AM   #81
Sileighty_85
It was in Mobile, It was the Only Z32 in the Yard
Hell if there was more for the same price I would have taken them all haha
後輪駆動車1番
1986 SR86 - 200ish
Old 09-02-2010, 01:36 AM   #82
buentellomma
man that was such a good deal, those guys must not have known how much they go for... i got a deal like that a few weeks ago on two diffs i picked up from craigslist for 100$. one had a tomei 2 way and the other was a vlsd
Old 09-04-2010, 01:23 PM   #83
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
awesome thread and thanks fo the info about the HG I was gonna do a rb swap thread but i would be lying if it didnt turn out like yours.
redline racer510 is offline
Old 09-04-2010, 01:28 PM   #84
I LUV MY S13
I LUV MY S13's Avatar
$43??? you bastard
-Jorge
I LUV MY S13 is offline
Old 09-04-2010, 01:36 PM   #85
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
If you do not end up keeping your clutch fan, I would like to purchase it from you.
Matej is offline
Old 09-04-2010, 02:42 PM   #86
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
Dam what a clean thread you got going here!! Keep up the great work! And even killer deal on that junk-yard special, can't really beat that unless they're free lol..
S14Serge is offline
Old 09-04-2010, 07:27 PM   #87
Sileighty_85
Originally Posted by I LUV MY S13 View Post
$43??? you bastard
Haha yeah i basically stole it
I guess your referring to the RB one? Sorry though, im like Pack Rat when it come to SR and RB parts haha
Thanks guys for compliments
Right now im currently ATTEMPTING to wire my own Harness up, Since im tired of waiting on a damn harness. I really dont want to do this, since I hate wiring so well see how it works out.
working on the M63 plug right now.
Picked up a M63 plug from a Zenki (hopefully the pinout is the same as a Kouki) the straight wires are supposedly the only wires needed for the M63 Plug
Heres the BS i gotta work with THANKS JDMONLINE.COM You Lying Bastards
後輪駆動車1番
1986 SR86 - 200ish
Old 09-04-2010, 09:18 PM   #88
GSXRJJordan
If you have any direct questions, I can try to help. I'm just slammed with the end of Formula D season and getting everyone ready for SEMA. Sorry Pat!
Old 09-04-2010, 10:36 PM   #89
RussellM
RussellM's Avatar
Trader Rating: (57)
RussellM is an unknown quantity at this point
Feedback Score: 57 reviews
Best of luck with the wiring Patrick. You have been waiting for wiring for a long while eh?! I thought I was slow sometimes.
Keep it up!
RussellM is offline
Old 09-05-2010, 01:29 AM   #90
Sileighty_85
Cool, Thanks Jeff.
Its cool man I understand.
Keep it up!
Thanks Russell, Yeah been waiting a while and getting impatient.
haha nah man your good
Thanks
Ugggghhhh I hate wiring, soo fucking tedious, Especially when all I have to go off of is wire colors instead of colors and pin location.
My M63 plug is a little short so I had to use some extra wires and make them longer
What i gotta work with.... I need a ESD Table
FYI, I did not use Butt Connectors, Its soldered The red is just the heat shrink
Pretty much done with it,
I got 5 extra wires though, Im not sure what they are, I'll have to do some tracing tomorrow
I think im missing a ground too according to my chart
next will be the MAFS section.....sighhhh Fuck you JDMONLINE.COM.......
後輪駆動車1番
1986 SR86 - 200ish
rb25 install, rb25 rebuild, rb25 s14, rb25 swap
