08-22-2010, 02:34 PM | #1 |
DIY:NX1600 Digital into S13 (240sx)
CAR = 92 240sx Vert Stock ka24de 5speed
Donor Car = 91 Nx1600 5speed google pic but same car Cluster First you need 1. NX1600 Digital cluster with PIG TAILS 2. NX1600 Digital Speed Sensor or maybe sohc ka24e speed sensor 3. NX1600 Temp Sensor or sohc s13 temp maybe 4. 240sx DOHC Cluster Harness or SOHC Cluster Harness 5. Tape or shrink tubing 6. Wire cutters 7. 10mm 12mm for temp and speed sensor Wiring S13 dohc harness and nx pig tails Far Left White plug s13 ~~~~ nx Red/blk ~ green/White 2wire white plug yellow/purple? ~ yellow/blk yellow plug yellow/white ~ yellow/green white plug yellow/green ~ yellow white plug white/red ~ yellow/red yellow plug green ~ blue and yellow wire from blk plug and yellow plug red/white ~ red/white yellow plug blk ~ blk blk plug blue/blk ~ yellow/green blk plug center white plug s13 s13 ~ nx green/yellow ~ green/yellow yellow plug red/green ~ blk white plug green/blk ~ green/blk white plug blk ~ blk yellow plug white/ blk ~ red/blk white plug yellow/red ~ blue/blk blk plug blue ~ red/yellow blk plug yellow/blk ~ red blk plug black s13 plug right side s13 ~ NX red ~ orng/blk white plug yellow/blue ~ green blk plug red/blk ~ red/blk white plug yellow/green ~ yellow/green blk plug red/yellow ~ red/blue go into blk and yellow plug green/ blue ~ green/blue blk plug anything anyone feel is wrong lmk asap and i fix it for Mounting into dash linked here Thanks to HellsDrifter 666 http://zilvia.net/f/tech-talk/337755...zenki-s13.html any one who has done this pm me and i add info
Ripping up the Highway since 03 Last edited by nurvcom; 08-22-2010 at 05:01 PM.. |
08-22-2010, 04:17 PM | #2 |
S13 speed sensor
here is a picture of a s13 speed sensor
I have the set up too I just need help doing the wiring. I already mounter my nx cluster in my s13. =D it is awesome that you are finally going to help out do this conversion. |
08-22-2010, 04:28 PM | #4 |
I followed this link on how to mount it. All you do is cut the upper retaining plastic bracket and then the whole cluster slides in. Then you use 2 self tapping screws to mount the left and right holes of the cluster. Then, everything should fall in in place =D. now how did you do the wiring hehe I am in very need of your help.
http://zilvia.net/f/tech-talk/337755...zenki-s13.html |
08-22-2010, 08:44 PM | #10 |
I know both the de and sr have been covered, and I know this is almost completely custom, but would it be able to adapt to the ka-e? That has to be one of the best looking clusters Ive seen. great job and great write up.
08-22-2010, 10:26 PM | #13 | |
if some get a cluster and harness and s14 cluster harness yes i would do one i did one for a guy for had s13 for 80
Ripping up the Highway since 03 |
08-22-2010, 10:28 PM | #14 | |
we could try anyone got a s13 sohc ka24e so i can test in Sacramento ca
08-24-2010, 11:24 PM | #15 |
I used a KA24E digital dash sub-harness to splice it into the NX one, it worked perfectly, so I don't see why not. I have a twin cam in my car, it used to be a single cam, but the speed sensor from a single cam tranny will make the speed read properly, and I did not have any problems using the twin cam temp sensor either.
08-26-2010, 12:49 AM | #16 |
Trader Rating: (26)
Feedback Score: 26 reviews
Since this works with KA24DE and SR20, I assume the tachometer will not work with a KA24E. Am I right? Has anyone installed this on a KA24E?
Nice write up! |
08-28-2010, 11:11 PM | #17 |
Your getting the tach signal from the dash wiring and the signal is not much different between the two so I assume it will work on both E and DE signal. My car was a E originally so all my wiring is single cam dash wiring. It should work.
08-31-2010, 11:42 AM | #18 |
hey
so now that I got the NX cluster hooked up in my car I am now going to try to wire up the HUD so it can work with the nx cluster. how to start. I saw that there are 3 wires that the hud uses. one gorund, one power and one signal from the mph gauge. I will try to hook it up this weekend and see if it worked.
08-31-2010, 01:26 PM | #19 | ||
Trader Rating: (26)
08-31-2010, 01:29 PM | #20 | |
Trader Rating: (26)
Maybe this will help make the NX1600 cluster work for SOHC KA24
09-11-2010, 07:11 PM | #21 |
Tried this out using your write up and it didn't work. The two wire white plug green/white and red/black. The green is hooked up but where does the red/black one go? Also on the black nx plug it has two yellow/green wires and both are used so which goes where?
09-11-2010, 11:40 PM | #22 |
Depends on the year of the NX you got the cluster out of, you need to check on the back of the cluster where each pin goes because almost all of them are labeled on the printed board/flat wire on the back of the cluster. I think after 91 they are slightly different in the pin out.
09-12-2010, 03:14 PM | #24 | |
Your retarded and should stop posting. Not much? Signal from wiring? Assume? You do not get your signal from wiring... try again. |
10-03-2010, 11:01 PM | #29 |
My bad, I could have worded that a bit better, I meant to say distributor wiring. But I do think your being a bit too harsh. Would you like to give us some insight on how to make it work for a singe cam?
