Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Advertiser Announcements and Feedback
Advertiser Announcements and Feedback This is where vendors can make announcements about upcoming promotions, events, items, etc. Vendors may also create threads here for the purpose of market research or other customer feedback.
Old 09-13-2010, 06:57 AM   #31
smbonn2005
smbonn2005 is an unknown quantity at this point
Very interested in a KA harness. Any idea when you will be done development on these?
smbonn2005 is offline
Old 09-14-2010, 12:52 PM   #32
Chase Bays
Chase Bays's Avatar
Chase Bays is an unknown quantity at this point
Thanks for the support guys.
We're getting pictures of the completed PS kits this week.
Brake lines, Brake Booster deletes, and Clutch lines are in stock.
Originally Posted by SAKURA View Post
is there anything else required for the brake booster delete?
there was a shaved engine bay thread on here somewhere, and someone said something about a different brake pedal setup for the delete.
also, does it matter if you are not running stock brakes?
It works with stock pedal. All you do is remove the OEM Booster and MC and replace it with our kit.
"Does it matter if you are not running stock brakes" Good question! With this setup the master cylinder size is based more upon weight of the car. The master cylinder we use on most 240 sized cars is a 7/8's. We've used 7/8's on a EVO7 rally car with 4 piston Brembo's and it was completely sufficient.
Originally Posted by nathanong87 View Post
chase dude, s14 sr into s14. GO
We're ALMOST done with KA stuff and then moving on to SR
We're about 2 weeks out on completion of the KA harnesses. SR is about 4 or 5 weeks out, and RB 25/26 will be done by the end of the year.
Chase Bays is offline
Old 09-14-2010, 02:38 PM   #33
GenPac
GenPac is an unknown quantity at this point
How about pedal travel? Does this change the pedal ratio from factory at all? What is the max. recommended piston surface area for use with a (short?) stroke 7/8" bore BMC?
Balancing adequate line pressure, comfortable pedal stroke and volume displacement with such a wide range of caliper sizes out there, a single size bore may not be ideal for every possible application.
GenPac is offline
Old 09-14-2010, 04:34 PM   #34
Chase Bays
Chase Bays's Avatar
I agree, I guess I should have elaborated more. One size does not fit all. However, with our testing the 7/8th's on a S chassis with OEM/Z/Most aftermarket brakes has proved itself to be best. If the customer feels as they need a bigger or smaller bore size, then we can discuss that when an order is being placed.
Just to give you guys more knowledge, we installed a 1 inch master cylinder on our booster delete kit and 300zx brakes onto a S13. Its hard to explain it but the pedal was significantly harder to press, and required a lot more leg pressure to get the car to stop. Overkill. We haven't tested it but, I am sure that a full weight EVO or STI (No ABS) would make that extra bore size usable, without giving you leg pains. Just trying to make an example that bigger isn't better in this case.
IMPROVING PERFORMANCE AND AESTHETICS WHILE SAVING WEIGHT AND SPACE
www.ChaseBays.com | [email protected] | (205)623-2188
Old 09-14-2010, 05:42 PM   #35
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
This is very tempting, but there is no way I would purchase it without trying it first. If anyone in Norcal buys a kit and lets me drive it I'll definitely write a review.
DJPimpFlex is offline
Old 09-15-2010, 12:15 PM   #36
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
We're offering it with a few options.
1) Adapting the OEM lines with tube nut/tube sleeve and a 37 degree flare OR an AN look hose clamp. The OEM lines are clamped on with lesser quality clamps than ours. Both as reliable from leaks as the other it completely up to you for what you want. See picture for reference...
2) New lines from the tank for an additional cost.
I sent you a PM about picking up some of your AN-Look hose clamps with some other questions and haven't gotten a response yet. Are these available for purchase through your website? I looked and couldn't find them.
thefro526 is offline
Old 09-16-2010, 02:06 PM   #37
VOoDOoGTX
VOoDOoGTX is an unknown quantity at this point
i have a 240 with a 2JZ swap if you wanted to get your hands on i could get some prices for shipping it down there. no current wiring has been done and the car is a shell at this point.
VOoDOoGTX is offline
Old 09-18-2010, 01:36 PM   #38
Chase Bays
Chase Bays's Avatar
Replied to all PMs
I would be 100% down. Still on the look out for a 2JZ mockup car.
PM me, our zipcode is 35173
Old 09-19-2010, 08:01 PM   #39
drivnovrdaedge
drivnovrdaedge is an unknown quantity at this point
pm sent about doing a harness for 1jz into a bmw e30 ...let me know if we can work something out
drivnovrdaedge is offline
Old 09-19-2010, 08:08 PM   #40
smbonn2005
Are you going to have the harness go right through the firewall like stock or is it going to have a connector right outside the firewall as I have seen some companies do?
Old 09-19-2010, 08:43 PM   #41
bboyoracle
bboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to beholdbboyoracle is a splendid one to behold
Send a message via AIM to bboyoracle
Our specialty is custom engine harnesses and A.N. fittings. Our wiring harnesses are made brand new from pin to pin, using the highest quality wire, sleeving, and heat shrink. We offer many options such as Military Spec connectors for the firewall (used as a quick disconnect for the entire engine harness) Raychem DR-25 heat shrink, yellow sensor labels, etc. Race, Street, and Show cars can benefit from our wiring harnesses. Nissan market wise we make or will be making KA, SR, RB, VQ, LS1, 2JZ harnesses that are plug and play into the S chassis.
bboyoracle is offline
Old 09-19-2010, 08:47 PM   #42
smbonn2005
Reading > Me
lol thanks for pointin that out
Old 09-23-2010, 01:31 PM   #43
Chase Bays
Chase Bays's Avatar
Thanks for the support guys, replied to all PMs.
Also, some pictures of our pending KA24 harness
Old 09-23-2010, 02:50 PM   #44
hOngsterr
Bandwagon.
hOngsterr's Avatar
Trader Rating: (73)
hOngsterr is an unknown quantity at this point
Feedback Score: 73 reviews
Send a message via AIM to hOngsterr
aww man, that looks sexy,
arent the single and dual cam wire harnesses different?
- Hong
OCD isn't so bad just means you'll spend more money then most people, but you'll have a quality car not a POS put together with POS parts.
hOngsterr is offline
Old 09-23-2010, 02:59 PM   #45
surge s14
surge s14's Avatar
surge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymore
want to see more of the ls1 harness
surge s14 is offline
Old 11-05-2010, 02:20 AM   #46
smbonn2005
Sent you a PM a little while ago about the KA harness and never got a response....
Old 11-06-2010, 03:43 PM   #47
Chase Bays
Chase Bays's Avatar
Yes. We wont be making Single cam harnesses sorry.
Old 11-06-2010, 03:44 PM   #48
Chase Bays
Chase Bays's Avatar
Doing a few final tests and R&D will be complete. Expect to see and thread on here and a new store item for the LS1 harness in a week.
I looked back and couldn't find it. Can you send it again? Sorry about that.
Old 11-06-2010, 06:22 PM   #49
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
OMG mah hero
can't wait to see it
dudermagee is offline
Old 11-27-2010, 11:50 PM   #50
caglej
caglej is an unknown quantity at this point
Are y'all doing any Cyber Monday or X-mas sales?
caglej is offline
Old 12-15-2010, 10:06 AM   #51
Chase Bays
Chase Bays's Avatar
Originally Posted by dudermagee View Post
OMG mah hero
http://zilvia.net/f/electronics/3575...e-harness.html
http://zilvia.net/f/advertiser-annou...-december.html
Old 01-01-2011, 05:41 AM   #52
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Any word on the SR harnesses?
Driftphreak87
Okinawandrifter87 is offline
