Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 09-21-2010, 01:27 AM   #1
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
Parts Shop MAX ~Coilovers~ IN STOCK NOW WITH FREE SHIPPING order directly from thread
Huge shipment just arrived, Zilvia exclusive - FREE USPS Priority Mail Shipping - for a limited time on Coilovers or any other purchase of $1000 from Parts Shop MAX! Just use the code ZILVIA1 in the shopping cart then click the apply coupon button.
*Ends 11-1-2010
*Lower 48 states only
You can buy stuff and get live shipping quotes right here in this thread!
Simply click the blue add to cart link to check it out.
VIEW CART
You may have noticed we get coilovers in only a few times a year, and because these parts are so rare and sought after, they are always sold out with pre-orders before the parts arrive. This has left the more spontaneous customers in the dust and reserved parts only go to the most patient customers.
however
Just arrived is an order 10x larger than my normal order to make sure I have stock for all of you who want it and want it NOW. And to say sorry for anyone who was forced to make compromises because we were sold out, I am selling this shipment with the shipping on us! That gets MAX coilovers to your door in 1-3 days an $80 value for free = )
Heres the details:
With a lifetime of tuning experience and a passion for drifting competition, Kawamori Eisuke proudly debut'd his signature MAX line of drift and custom parts three years ago & our USA customers have been beating them down every day since then proving their strength and longevity. The MAX competition coilovers are thoughtfully designed by Shizuoka’s premier tuner so that you may enjoy superior competitive performance without depending on traditionally overpriced or not so conveniently serviceable parts offered by corporate performance suppliers.
COMPETITION SUSPENSION coilover key features:
  • Light weight and strength are combined in our many aluminum components
  • Full tap independent adjustments
  • Aggressive damping range with fast adjust
  • Allows you to do 32 clicks of damping change in just 10 clicks!
  • Pillow ball upper mount on front AND REAR!
  • Replaceable shock & customizable spring
  • Super low ride height ability
  • Billet T6061 lightweight aluminum Lower mount with urethane bushing
  • All aluminum components are hard anodized
  • High rigidity/High precision piston rod design exceeds racing standards
  • Adjustable to super low ride height
  • Full thread tap piston and locking collar allows vehicle height to be adjusted independent of the spring preload
  • 2 collar wrenches are included
  • Light weight T6061 aluminum spring perch and locking collar designed to bear the weight of vehicle
  • Unique use of spring upper perch front and rear provides independance between the spring and the pillowball on all 4 corners
  • Racing spring available to special order in custom Kg (even numbers only)
Shock Dyno stats:
Front shock at maximum damping setting: Damping test at 229rpm (.6M/sec) Tension = 748.8KG Compression = 94.8KG
Front shock at minimum damping setting: Damping test at 229rpm (.6M/sec) Tension = 625.7KG Compression = 92.9KG
Rear shock at maximum damping setting: Damping test at 191rpm (.5M/sec) Tension = 642.6KG Compression = 99.5KG
Rear shock at minimum damping setting: Damping test at 191rpm (.5M/sec) Tension = 591.8KG Compression = 94.4KG
MAX S13 Competition Coilovers $1000
CLICK HERE TO ADD TO CART & ORDER ONLINE
MAX S14 Competition Coilovers $1000
MAX JZZ&JZA Competition Coilovers $1000
MAX FC Competition Coilovers $1000
MAX R32 Competition Coilovers $1000
adjuster,pillowball
bottom brackets
spring, locking collars
replacement damper $100ea+sh
MAX Replacement Damper S-chassis Front
MAX Replacement Damper S-chassis Rear
Are your butt cheeks sore from daily driving? We sell 6KG springs to soften things a bit. MAX s chassis coilovers come with 10KG front & 8KG rear springs so if you wnat to run 8KG front, and 6KG rear, just take the 8KG off the rear and put them on the front, and then run the new 6KG pair in the back. 6kg-200mm $60/pair+sh
MAX 6 KG Springs for Competition Coilovers
VIEW CART
Article in Drift tengoku this January 2010 features Parts Shop MAX coilovers!
Basically this whole issue is dedicated to people who had their drift car for a while and is looking into changing their tired old suspension.
Question is should you save some money or get the best of the best?
Drift Tengoku has seen alot of companies offereing new suspensions for less and so they decided to do a test.
This was a test of 3 Competitors:
DMAX recommended from Nakamura from Burst $1350
Parts Shop MAX recommended from Yokoi from Mind Control $1000
HKS Hypermax-D NOB spec recommended from Taniguchi $2400
Racing gear was the old worn out coilovers on "Funky's" car who works for dtift tengoku
His car is a S13 with TD06 turbo making 350PS with roll cage, GP sports knuckles 4* front camber 1* rear camber zero toe front and rear.
Testing time was 12 minutes each at mobara twin circuit
tires were new 235 40 17 federal ss595 3kg/m2 pressure rear
This was a blind test meaning the driver did not know which ones he was testing till later.
MAX
located in fujieda city
Yokoi from mind control recommends this because he's been doing good in D1SL with it
Normally they come with 10 - 8 but since Yokoi runs 8/6 thats how they tested it.
side note 6 kg is only in black
A very unique thing about these is that the pillowball upper mounts for both front and rear both have a spring top hat that allows unrestricted pillowball movement.
They liked how most of the construction is aluminum so the whole set weighs 19 kg which is the lightest of all types tested. This is a good mix of Japanese and overseas parts to give you a great suspension for $1000
(they started out on click 4 front and 4 rear out of 8 )
First impression is that it felt stiff and they wonder why because the spring rate is lower than the standard rates. They noticed that the front end of the car feels amazing, and responsive so he could see the difference between this one and his previous suspension. He likes the way it feels when the car gets up on the track curb. The rear felt bouncy so they put the rear on full soft and afterwards it felt better. Funky says with this change the rear feels good and the front has massive traction so when you kick the back out hard, the car has a feeling of control. One important thing to know about how Parts Shop MAX is different from other stiff coilovers is that typically when a car is set up really stiff, its usually it is prone to spinouts, but the opposite was true of p.s.MAX - it had great control.
Racing gear JTC/N1
This suspension was on the car for the last three years but the shock was not blown. The bottom mount bushing was worn. The spring was switched to Eiback 8KG in the front and swift 6KG in the rear. The tester knew right away it was his suspension. He knows this suspension really well, it is easy to kick out the tail but once it starts sliding its hard to stop. Single runs he can drive this suspension bcause he knows it, but the rear is too unpredictable to follow someone well or get consistancy in back to back runs.
They talk about how it comes with many tools for special adjustments. The front has a 2 way adjuster for camber and caster. Rear has a helper spring. Super high quality and beautiful. Has a 1 year warranty. They say it felt great just driving down the paddock, soft. There is no special characteristics to the drift feeling, it was just straight forward feeling, so they tried to see how it feels by clicking the damping one click and that is impossible, it just feels the same, they had to click it 14 times just to tell the difference. There is no extreme characteristics, so it hay be good for a beginner, but for the drivers taste he would prefer something more "edgy".
D-MAX
The tester was really interested in finding out about this suspension because the D1SL was won three times on it. Quality is good, and comes with all the little accessories so thay are impressed with what you get for the price. Started out with 16 out of 32 clicks. He likes this the best for overall balance. This suspension matches the S13 well. Trying the rear softer, there is major understeer so he was like OH Shit and so he tried front and rear full soft and didnt like it either so he put it back to where it was before. Says it is good because the adjustments actually work for dialing in you type of car.
Summary:
Best Cost effectiveness - DMAX
Best Comfort - HKS
Best Purchase ability and steering response - Parts Shop MAX
Unique things about each one:
Dmax has a slotted lower for more camber and a fitting so it wont come loose
Hypermax-D the most positive camber setting could only get it to negative three, so this in in line with more modern camber settigs used with knuckle mods.
Parts Shop MAX - The huge difference in weight of the aluminum brackets - the coarse thread makes it easy to adjust - the issue with the rear balance that they did not have time to fine tune could be dialed in on your car to get the perfect balance with the fantastic front feeling during testing. Being the cheapest is a real plus too!
~~Our thoughts~~
After reading the article, I am thankful that they chose to feature us and that they touched on some things that were important to us like giving you alot of coilover for a little money, but I am a little bummed that they did not touch on some other factors that make our suspension great for alot of people like its low ride height ability so I would have liked to see a compairo of a company with a more similar goals to ours like 326 power (cover cars of this issue) which has spring rates of 14/12 KG. Its necessary to have higher spring rates and proper alignment settings such as a traction rod lengthened for a super low car (and the higher rates dont feel as high as you would imagine when all of the settings are in harmony) Clearly Funky at DT has a preference for softer rates whereas our prefernece is for the 10/8 in cars setup for maximum style and performance. Also the overall conclusion was that DMAX was #1, and thats a little weird since the car testing this stuff has DMAX stickers all over it. Is Funky partial to a certain advertiser in his mag with a multi page ad every month?
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 09-21-2010, 11:48 AM   #2
vboy720
vboy720 is an unknown quantity at this point
Send a message via AIM to vboy720
haha thanks for the coupon! putting my order in on thursday!
vboy720 is offline   Reply With Quote
Old 09-21-2010, 11:59 AM   #3
ALEXTHESUS*PECT
ALEXTHESUS*PECT's Avatar
hey dan did you guys ever go through with producing some y33 tophats?
TEAM SUS*PECT
Old 09-21-2010, 12:20 PM   #4
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Are these available with z32 rear forks?
Black R is offline   Reply With Quote
Old 09-21-2010, 01:01 PM   #5
DC Dan MAX USA
Trader Rating: (79)
Yes we actually are producing the complete coilover system, should be available to the public in 2 months.
No
Old 09-22-2010, 12:27 AM   #6
ken.bryle21
ken.bryle21's Avatar
ken.bryle21 is an unknown quantity at this point
no free shipping in canada? LOL
ken.bryle21 is offline   Reply With Quote
Old 09-22-2010, 03:25 PM   #7
DC Dan MAX USA
Trader Rating: (79)
I love canada too so......I'll split the shipping with you. Email me after your order with your Zilvia screen name and I will paypal you.
Old 09-22-2010, 03:56 PM   #8
flybye
flybye's Avatar
flybye is an unknown quantity at this point
Now that is good customer service!
flybye is offline   Reply With Quote
Old 09-24-2010, 03:40 PM   #9
chiboy002
chiboy002 is an unknown quantity at this point
Dan... would it be wrong of me to tell you i loved you? February 14th, ill be sendind roses to you.
Too bad i felt like supporting a local shop and bought stances.... and they don't do their job.... for the same price >.>
street dancer.
GLEAM
Old 09-24-2010, 06:44 PM   #10
PomiDori
PomiDori is an unknown quantity at this point
coupon code didn't work for me)
entered coupon code zilvia1 and shipping was 0.00,but when I'm trying pay with paypall it still wants me to pay 1080 somthing bucks.
PomiDori is offline   Reply With Quote
Old 09-24-2010, 07:10 PM   #11
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
What's wrong with Stance?
I love PBM and Stance all the same. If I was looking for coils right now though, PBM would be first on the list because of price.
Irresistible is offline   Reply With Quote
Old 09-25-2010, 06:54 AM   #12
BTplaya
BTplaya's Avatar
BTplaya is an unknown quantity at this point
Sent you a PM.
95' S14 w/ SR20DET - 412hp
BTplaya is offline   Reply With Quote
Old 09-25-2010, 07:16 PM   #13
caglej
caglej is an unknown quantity at this point
When I go to check out it says zilvia1 is invalid for my area. Roanoke, TX 76262 Any reason why?
tried using a few different addresses of friends/family and still cant get the shipping thing figured out.
caglej is offline   Reply With Quote
Old 09-26-2010, 06:06 PM   #14
matts13vert
matts13vert's Avatar
Trader Rating: (31)
matts13vert is an unknown quantity at this point
Feedback Score: 31 reviews
do you also have the z32 rear bottom mounts to add in a set for an s13?
matts13vert is offline   Reply With Quote
Old 09-27-2010, 12:27 PM   #15
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
time to upgrade.. ill be giving you guys a ring. im tired of riding on my bump stops on these megans.. lol
HS13KLS is offline   Reply With Quote
Old 09-27-2010, 02:39 PM   #16
DC Dan MAX USA
Trader Rating: (79)
Originally Posted by BTplaya View Post
Sent you a PM.
replied
not sure why the coupon system is giving troubles, I'll try to fix it but in the mean time...process the order, email me with your zilvia screen name and your real name and paypal address, and I'll paypal you money to refund the shipping.
no
Old 09-29-2010, 09:07 PM   #17
Mr. 25/8
Mr. 25/8's Avatar
Mr. 25/8 is an unknown quantity at this point
Sent you a pm. Having trouble with the coupon...
Mr. 25/8 is offline   Reply With Quote
Old 09-30-2010, 09:29 AM   #18
Datenshi
Datenshi is an unknown quantity at this point
I placed my order a few days ago for S13 coilovers. These guys have been great, answered a lot of my questions and great customer service. Can't wait to get them! Thanks!
Datenshi is offline   Reply With Quote
Old 10-01-2010, 04:30 PM   #19
DC Dan MAX USA
Trader Rating: (79)
resolved, thanks~!
thanks for your business!
Old 10-01-2010, 06:44 PM   #20
ZachTriggs
ZachTriggs is an unknown quantity at this point
Just ordered, thanks guys! Coupon wouldn't work for me but I just sent the email.
ZachTriggs is offline   Reply With Quote
Old 10-01-2010, 07:57 PM   #21
lkristoefur
lkristoefur is an unknown quantity at this point
can the 6kg springs go on the front and the rear?
lkristoefur is offline   Reply With Quote
Old 10-01-2010, 08:56 PM   #22
vegasS12
vegasS12 is an unknown quantity at this point
The spring is interchangeable you can put it in the front or rear
vegasS12 is offline   Reply With Quote
Old 10-04-2010, 12:28 PM   #23
DC Dan MAX USA
Trader Rating: (79)
thanks! I think I just fixed the coupon, someone try it now and report back to me if you have success checking out with free USPS priority shipping.
correct.
Old 10-11-2010, 05:05 PM   #24
Dittoz7
Dittoz7's Avatar
Dittoz7 is making a name for him/her selfDittoz7 is making a name for him/her self
Send a message via AIM to Dittoz7
Coupon still good? *crosses fingers*
oops nvm saw the expiration date.
Dittoz7 is offline   Reply With Quote
Old 10-15-2010, 07:24 AM   #25
c-los13
c-los13's Avatar
c-los13 is an unknown quantity at this point
i gotta buy these!!!!!!!!!!!!!!!!!!!!!!!!!
c-los13 is offline   Reply With Quote
Old 10-15-2010, 11:28 AM   #26
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
dan, if you somehow come across with some random collars laying around, give me a pm!!!
instagram
1on1 is offline   Reply With Quote
Old 10-15-2010, 12:37 PM   #27
jdm2191
jdm2191's Avatar
Trader Rating: (79)
Still have a set for s13's in stock?
jdm2191 is offline   Reply With Quote
Old 10-17-2010, 03:14 PM   #28
alindeman1989
alindeman1989's Avatar
alindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to all
Send a message via AIM to alindeman1989
how do these do in grip driving also?
tofu man: Don't be cheap, and buy shitty high offset rims
alindeman1989 is offline   Reply With Quote
Old 10-18-2010, 02:15 PM   #29
DC Dan MAX USA
Trader Rating: (79)
yes sir
I would say that the difference between drift and grip would be more in the alignment settings than the coilover choice, so you can grip drive these. They are stiff so I would probably set them to a softer setting and run nothing stiffer than OEM sway bars too.
Old 10-18-2010, 09:53 PM   #30
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
Waiting for 350z coils...Thanks!
rancid240 is offline   Reply With Quote
