Old 09-19-2010, 10:29 PM   #1621
sydwyz95
sydwyz95 is an unknown quantity at this point
^^Did i get a chance to meet you?
sydwyz95 is offline   Reply With Quote
Old 09-20-2010, 01:55 PM   #1622
enigmadsm
enigmadsm is an unknown quantity at this point
yeah man, Same screenname on IMS..i was in the black shirt came and talked to you for a few minutes. i'm the guy in Kuna with the kouki
enigmadsm is offline   Reply With Quote
Old 09-20-2010, 11:19 PM   #1623
sydwyz95
Gotchya... kinda figured it was u but thought id make sure lol. Well have to chat a lil more at the next meet..
Old 09-21-2010, 11:41 AM   #1624
axiomatik
axiomatik's Avatar
looks great.
Old 09-24-2010, 04:46 AM   #1625
GRNxS14
GRNxS14 is an unknown quantity at this point
Originally Posted by michael200sx View Post
I can finally add my car as its nearly finished visually,
this thread was very helpful as inspiration
wheels are Meisters 18x8.5 front and 9.5 rear with 235 fronts and 285 rears, nothing real crazy but i'm happy with the stance.
Where did you find this lip??? I must have one!
GRNxS14 is offline   Reply With Quote
Old 09-25-2010, 03:00 PM   #1626
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
Looks like an SRB Power Lip.
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 09-25-2010, 09:06 PM   #1627
corbin
corbin is a well-known jackass
Negative.
That's Australian Spec OEM. Called Top Stage or "Luxury S14a lip." There is a recent thread about it on this very forum... I think it looks great and want one too, but good luck finding it.
corbin is offline   Reply With Quote
Old 09-25-2010, 09:08 PM   #1628
michael200sx
michael200sx is an unknown quantity at this point
The Lip is made by an Australian company, Top Stage.
There are a few threads on here about it,
those readers of speed hunters may remember a purple s14a with the same lip featured a month or two ago.
michael200sx is offline   Reply With Quote
Old 10-02-2010, 04:15 PM   #1629
cheeky14
cheeky14 is an unknown quantity at this point
i test fitted a 18x10 +50 offset BBS LM in the rear of my s14 with no tire the wheel clears all suspension components, the inner lip has about a pinky finger distance to coilover body as well as the threaded spring perch, i am going to try to get the seller, to allow me to test fit a tire & set it on the ground to see what clears & what does'nt etc.
I figured i'de ask if any one has fitted a high offset 10 inch wide rear & had any issues or suggestions
cheeky14 is offline   Reply With Quote
Old 10-02-2010, 04:21 PM   #1630
kyles1988
kyles1988's Avatar
kyles1988 is an unknown quantity at this point
I ahd 18X10 +44's on the rear of my S14. It hit my trailing arm
kyles1988 is offline   Reply With Quote
Old 10-02-2010, 04:26 PM   #1631
1sik240sx
1sik240sx's Avatar
1sik240sx is an unknown quantity at this point
Originally Posted by sydwyz95 View Post
Need to get some better pics taken but ill post my setup up!
Volk TA
front: 19x9.5 +22 w/5mm spacer for now rolled slight pull 245/30/19 3 degrees camber
rear: 19x10.5 +22 rolled and healthy pull 305/25/19 2.5 degrees camber
still tryin to dial in ride height just put the 305s on up from 275s and need to go to a 8 or 10mm spacer up front..
Hech yes Mitch! Idaho showing some rubber!
- Kyle
1sik240sx is offline   Reply With Quote
Old 10-02-2010, 04:27 PM   #1632
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
Yeah, like Kyle said, that +50 isn't going to work... without a 10mm spacer. You probably didn't know when you test fit because it's not going to rub until you put the car on the ground. Same way with my 18x11 +30 on my S13. Everything was cool in the air, but once I took the car off the jack stands and on it's own weight, the lower control arm rubbed on the inner lip of the wheel. So naturally I notched the control arm.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 10-02-2010, 04:45 PM   #1633
cheeky14
did you have the o.e. trailing arms?
i kinda figured it would'nt work, without doing some extra work ;i assumed i would need a 10-15mm. spacer & longer studs to make it work, i guess i'll play it safe & source BBS LM 18x9 20offset all around
thanks for the info
Old 10-02-2010, 05:33 PM   #1634
cheeky14
thanks for the info
Old 10-02-2010, 06:15 PM   #1635
kyles1988
kyles1988's Avatar
thanks for the info
Yes, OEM trailing arms. And like Toby said, it only rubbed on the ground, not in the air.
Old 10-03-2010, 04:50 PM   #1636
cheeky14
did you end up keeping them or run spacers to clear; what size if you kept them
Old 10-03-2010, 07:00 PM   #1637
kyles1988
kyles1988's Avatar
kept them for a little bit. They only rubbed the trailing arm when my suspension was really articulated, so like coming into a crappy drivewway. Therefore I didn't run spacers.
Old 10-21-2010, 06:22 PM   #1638
NBKouki
NBKouki's Avatar
NBKouki is an unknown quantity at this point
285's in the rear
255's up front
NBKouki is offline   Reply With Quote
Old 10-23-2010, 07:39 AM   #1639
ReaperBJJ
ReaperBJJ's Avatar
ReaperBJJ is an unknown quantity at this point
^ I've always got a chubby for those Z wheels and that tire fitment makes it even better, I think I want a set for my s13 now please....
ReaperBJJ is offline   Reply With Quote
Old 10-23-2010, 06:58 PM   #1640
Dazzla
Dazzla is an unknown quantity at this point
^ If only they were easy to find!!
Dazzla is offline   Reply With Quote
Old 10-23-2010, 07:39 PM   #1641
kyles1988
kyles1988's Avatar
Aren't they 19's? At least in the rear right?
Old 10-24-2010, 07:19 AM   #1642
ReaperBJJ
ReaperBJJ's Avatar
18x9 F and 19x10 R I believe..
Old 10-24-2010, 01:03 PM   #1643
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
Does any one have the offsets on those?
I would consider running four of the fronts on my fastback if they have the right offset.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 10-24-2010, 01:43 PM   #1644
ReaperBJJ
ReaperBJJ's Avatar
+30 both front and rear
Old 10-28-2010, 08:26 PM   #1645
ej2civic
ej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the roughej2civic is a jewel in the rough
update of my pics.
Volk GT-N
Front 17x8 +10 with 235/40-17 stock fenders rolled
Rear 17x9 +24 with 255/40-17 rolled with slight pull
I know its not the MAXIMUM fit but I do what i can with the wheel size i have, haha.
ej2civic is offline   Reply With Quote
Old 11-17-2010, 01:11 PM   #1646
NewYorkCoupe
NewYorkCoupe's Avatar
NewYorkCoupe is an unknown quantity at this point
Send a message via AIM to NewYorkCoupe
Alright so I need some help guys. I came into possession of some Volk Racing EMU wheels in 17x8 +35 / 17x9 +40. If I run 20mm spacers what size tire would you recommend for mainly street and about 5 autox days per year? s13 coupe.
What brand tire do you guys prefer the most?
NewYorkCoupe is offline   Reply With Quote
Old 11-17-2010, 01:20 PM   #1647
TheRealSy90
TheRealSy90's Avatar
Dunlop Direzza Star Specs.
Such a good signature.
Old 11-17-2010, 01:21 PM   #1648
kyles1988
kyles1988's Avatar
Nitto NT05
Old 11-17-2010, 02:08 PM   #1649
longfellow
longfellow's Avatar
longfellow is an unknown quantity at this point
Nitto NTO5, Hankook RS-3, Kumho XS, Dunlop Z1 Star Spec
Those are the only tires worth looking into.
longfellow is offline   Reply With Quote
Old 11-17-2010, 11:11 PM   #1650
greddy2die
greddy2die's Avatar
greddy2die is an unknown quantity at this point
Send a message via AIM to greddy2die
I have Hankook RS-3's on my car. 255/40/17's on my 9" wide advans. I really like them, im putting down about 390whp - 37x tq or so with my ls1 and ive got pretty good traction considering.
Although, ive never had any of the other tires listed so i cant really compare them to the others.
greddy2die is offline   Reply With Quote
