Old 10-08-2010, 03:12 PM   #3031
fckillerbee
fckillerbee's Avatar
Originally Posted by Melo_speed View Post
I want to get 17x9 +0 and 17x10 +0 and want to get over fenders but im not sure if what i have in mind is to much.
I want 30mm front 50mm back will it be to much for it or should i go less also a beefy tire is a must in the back.
What would be a good combo for the wheel sizes i want?
It will be my dd/track car and love the wide stance on it.
Someone help me out please.
should be fine if you run a beefy tire like a 40-45 series sidewall, anything smaller, and a 30mm fender would be more than enough. just buy a 30mm and pinch it wider if need be. That's what I did, and i have more aggressive fitment. same sizing.
Old 10-08-2010, 03:14 PM   #3032
fckillerbee
Originally Posted by 7evil View Post
Stupid question: i want to put the 17 inch rims on my S14. I would like to have 9/9.5 front and 10/10.5 on the rear, without have too much camber and roll the fender. What is the right ET? I want a FLUSH style, not HELLAFLUSH!
read the "whole" wheel fitment thread. people have done it...just take your time, and look through it.
Old 10-08-2010, 04:28 PM   #3033
vboy720
vboy720 is an unknown quantity at this point
Send a message via AIM to vboy720
background: 95 S14, stock engine, welded diff, shocks and springs.
question: my car has a weird shaking that has gotten worse over time. It doesnt happen in 1-3 gear, but you feel it in 4th and 5th, so im guessing it has something to do with the speed im traveling. It only happens under acceleration, but if i either cruise at a constant speed or just decelerate it doesnt shake. The shaking feels like its coming from the rear of the car. any ideas?
vboy720 is offline   Reply With Quote
Old 10-08-2010, 04:32 PM   #3034
240sx123$
240sx123$ is an unknown quantity at this point
Subframe bushings.
240sx123$ is offline   Reply With Quote
Old 10-08-2010, 05:45 PM   #3035
titopr06
titopr06's Avatar
Trader Rating: (68)
titopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nicetitopr06 is just really nice
Feedback Score: 68 reviews
is there a difference in s13 and s14 ka24de a/c compressors? if so could you post any pics of them? thanks for any help.
titopr06 is offline   Reply With Quote
Old 10-08-2010, 05:50 PM   #3036
S14DB
AFC #1
S14DB's Avatar
Bolt patterns are different. S13 is in R-12 and R-134a. S14 is R134a only. Supposedly there are hose connection differences. But I have not seen that for myself.
Old 10-08-2010, 06:00 PM   #3037
titopr06
titopr06's Avatar
Trader Rating: (68)
thanks,
is there a difference in the ac lines? can i use s13 ac lines on s14 compressor or vice versa?
thanks
Old 10-08-2010, 06:18 PM   #3038
Wake
Wake's Avatar
He already answered your question.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 10-08-2010, 07:04 PM   #3039
Levan. B
Levan. B's Avatar
Levan. B is an unknown quantity at this point
So i need some help on tire sizing... im running a 225/45 on a 17x9.5 battle in the front of my stock fender s13, it is way too big. im not sure what size to get.. any suggestions?
Levan. B is offline   Reply With Quote
Old 10-08-2010, 07:16 PM   #3040
titopr06
titopr06's Avatar
Trader Rating: (68)
ok, since he has not seen that for himself can you assure me that there is not a difference in the lines?
thanks
Old 10-08-2010, 07:33 PM   #3041
S14DB
AFC #1
S14DB's Avatar
thanks
There is a difference in the location and size of the outlets. I just don't know the specifics.
Old 10-08-2010, 10:21 PM   #3042
vboy720
its that simple? just subframe bushings? guess i should just switch it up with solids with risers?
Old 10-08-2010, 11:38 PM   #3043
gerbil is sik
gerbil is sik is an unknown quantity at this point
There's a little chirping noise that's coming from my car, at first I thought it was the turbo but now I'm thinking it might be leaking somewhere since I'm not blowing any smoke and it doesn't smell like oil at all. Is this the turbo thats making the noise, an exhaust leak (some on youtube sound like this), manifold to turbine leak, or manifold to block? Or maybe something else?
http://www.youtube.com/watch?v=0YlA0bOLBHM
I made a small video, it's a little hard to hear. I'll probably make another one tomorrow, also my a/f according to my Turbo Timer is going nuts lol.
Thanks in advance.
gerbil is sik is offline   Reply With Quote
Old 10-09-2010, 01:06 AM   #3044
Ph0king
Ph0king's Avatar
Ph0king is an unknown quantity at this point
Will the s13 hood latch cable fit s14's? Thanks!
hello.
Ph0king is offline   Reply With Quote
Old 10-09-2010, 05:44 AM   #3045
enigmadsm
enigmadsm is an unknown quantity at this point
Originally Posted by fckillerbee View Post
have you put the wheel on your car yet? just put it on, and if you want more poke, measure how much you want, and put that spacer on it. pretty simple.
different between two wheels with the same offset is half an inch. offset is measured by the mounting point compared to the middle of the rim. if the rim is an inch wider, that would leave half an inch on each side of the mounting point....if that at all makes sense...it does in my head....should be right.
i have but its tough to judge without tires mounted...and it appears we have the same theory on the 1/2" difference if all other measurements are the same lol.
I'm sure i'll figure it out though this thread helped quite a bit
enigmadsm is offline   Reply With Quote
Old 10-09-2010, 11:32 AM   #3046
240Z28
240Z28's Avatar
240Z28 is an unknown quantity at this point
just to verify.. when swapping from a ka-e to ka-de all i need is ecu, power steering pump anl lines, throttle and cruise cable, and maf?
SPEED KILLS!!
Drive a Honda and live forever!!
240Z28 is offline   Reply With Quote
Old 10-09-2010, 11:47 AM   #3047
fckillerbee
Thanks in advance.
I hear a bird everytime you shift. is that what you are talking about?
Old 10-09-2010, 12:46 PM   #3048
240sx123$
Its a pretty involved job, but yeah, thats what you need. You described the exact symptoms of bad subframe bushings. While youre in there, check the bushings on the rear arms as well. I need to do my subframe bushings, and was quote $260 for labor to have a shop do it, and I think thats the route im going to go. For reference- Im swapping my SR in but dont want the task of doing subframe bushings. Its just a bitch without a lift.
Old 10-09-2010, 01:51 PM   #3049
gerbil is sik
lol, no I'm not talking about the bov. You can barely hear the chirping in the beginning of the video, I guess I can try to make a new one. Car chirps whenever I accelerate, I figured something was wrong with my turbo. Like it might be scraping or something, but then I read up on leaks and how they sound similar. Thanks for the help, I'll post another video tonight.
Old 10-09-2010, 05:17 PM   #3050
XxHybridx
XxHybridx's Avatar
XxHybridx is an unknown quantity at this point
Rear breaks make a sound whenever I break while going in reverse.
I do need to replace my pads pretty soon, but would that be that problem?
since it only does the sound when im reversing?
XxHybridx is offline   Reply With Quote
Old 10-09-2010, 07:17 PM   #3051
Wake
Wake's Avatar
I assume you mean in addition to a KADE engine harness?
S.P.P.S. Member #00
Old 10-09-2010, 08:33 PM   #3052
vboy720
dayum, $260 in labor. it sucks but i guess theres no way around it. the rattling while i drive is a bitch.
Old 10-09-2010, 10:22 PM   #3053
KoukiDrifter240
KoukiDrifter240's Avatar
KoukiDrifter240 is an unknown quantity at this point
just wondering has any one had smoke come out of exhaust and also pcv ( my pcv and breather vents into the air only, not intake and not a filter or catch can) same time. I think valve seals but its a lot of smoke and i wanted to know if anyone has had or heard of this. its a shit load of smoke by the way and there is no loss of power so i no think its head gasket but i will check compression:bash :
farewell kouki!
KoukiDrifter240 is offline   Reply With Quote
Old 10-09-2010, 10:40 PM   #3054
blake110491
blake110491 is an unknown quantity at this point
I plan on stripping a lot of the interior,doing some re-wiring and removing some stuff.Just curious what all you have to have to pass inspection.Double checking my self on what i have to have.
blake110491 is offline   Reply With Quote
Old 10-09-2010, 10:41 PM   #3055
S14kouki_10
S14kouki_10's Avatar
S14kouki_10 is an unknown quantity at this point
Mine does the same thing too, and sometimes when im driving; then it goes away.
Im getting my disks resurfaced and new pads, see if it stops.
S14kouki_10 is offline   Reply With Quote
Old 10-09-2010, 11:03 PM   #3056
blake110491
I have to get mine resurfaced after they completely locked up one night then magically fixed itself
Old 10-10-2010, 01:07 AM   #3057
240Z28
240Z28's Avatar
yea in addition to the harness
SPEED KILLS!!
Old 10-10-2010, 05:57 PM   #3058
ChiSleepyEyes
ChiSleepyEyes's Avatar
ChiSleepyEyes is an unknown quantity at this point
Send a message via AIM to ChiSleepyEyes
cant get a straight answer just from searching. I'm looking to buy a new spring/shock combo for my DD, but problem is i do not know which to buy. So i'm looking for opinions on which i should buy. What i'm looking for is drop and ride quality
ChiSleepyEyes is offline   Reply With Quote
Old 10-10-2010, 06:01 PM   #3059
chiboy002
chiboy002 is an unknown quantity at this point
why not just get coils? they can go high enough for 4x4
i bought an excedy oem clutch a while back, regret, is it just me or is it fucking impossible to get my rears to break traction with this? It seems like it doesnt hold up, it was new in like early may.
Any1 recommend an upgrade clutch? Im stock ka-de, i was looking at ACT ones
street dancer.
GLEAM
Old 10-10-2010, 09:01 PM   #3060
cole shoes
cole shoes is an unknown quantity at this point
Okay so I have an Sr with an odyssey battery and for the past month I've been traveling and haven't had time to drive my car so the battery died and I went out and bought a battery tender and it wouldn't even detect the battery so I took it out and jumped it with my truck(jump started, haha that sounded funny so I'll leave it like that) and now the tender will detect it and charge it but when I put it back in my car nothing happens.
Bad connection? Bad battery? I don't want to waste money on a battery if I don't need one what do you guys think?
Thankssss
cole shoes is offline   Reply With Quote
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki
