03-13-2011, 09:54 PM | #95 |
I know this is an older post but I wanted to know where you got your throttle cable mount, I see your s14 swap had the stock cable mount but you got a shiny new one that looks like a better mount...
thanks, |
03-14-2011, 02:21 PM | #98 |
+1 i want to see how this is going....looking real nice
08-14-2011, 06:04 AM | #103 |
Sorry for lack of updates, car's not been worked on for some time. Parts from Japan took a lot longer to arrive too.
Rebuild engine that I'm assembling atm: Re-galvanized bolts etc: Used engine enamel to spray the block/trans and some parts Front cover/oil pump, water pump, oil pans, crank pulley, oilblock, thermostat & housing, lower intake, alternator, ps pump, v-belts, fuel rail, coolant pipes etc on and torqued to spec. upper intake & exhaust mani with turbo on for test fit. waiting for oil in/out gaskets for the turbo (this rocker cover is on just to keep dust out) |
08-14-2011, 12:11 PM | #105 | |
Thanks, I try to do my best
Just fininished re-polishing the intake and test fitted w/g, it used to hit the strut brace when the engine ran before. |
08-16-2011, 10:07 AM | #109 |
Thanks all,
Fitted the flywheel/clutch and egt sensor in the exhaust manifold today New flywheel bolts again Had to cut a hole in the heatshield for the egt sensor Block specs: Block: drilled honed to 87mm CP 87mm pistons Eagle rods Crank lightened/knife edged/balance Acl main/bigend shells Arp main studs New freezer plugs Head: Arp head studs Cosworth hg BC 264 cams BC valve springs titanium retainers Tomei rocker arms stoppers New VCT cam sprocket New hydraulic lifters New rockers arms New oil spray bars Acc: New comprehensive gasket set New distribution set New water pump New oil pump/front cover New crank seals New thermostat Gearbox on with ghetto clutch centering tool ie used tape to clamp a small diameter pvc tube inside a sparkplug socket. Twinplate was a pain to center took me 3 times before the box slipped on perfect. 30mm front ARC anti roll bar, weighs less than half compared to the original nismo power brace Mercedes benz r129 silver arrow sl60 amg 334x32mm front discs Last edited by R@tch; 08-18-2011 at 03:02 AM.. Reason: update |
08-29-2011, 11:01 AM | #110 |
Received steering discs this weekend, this was the final part I wanted in before refitting the engine.
Last few bits on the engine; Oil return/feed, dipsticktube, engine mounts and downpipe. Bit of a mess, time to put everything back in there |
09-03-2011, 06:07 PM | #117 |
Trader Rating: (22)
Feedback Score: 22 reviews
Right the **** on! That's a very nice build. I hope that car gets as much use as it deserves... I was following your build over on SXOC, nice to see some progress.
11-24-2013, 10:18 AM | #119 |
It's been quite a while since the last update... The car is fully registered for driving on the Dutch road with the sr20det running on e85 producing 403hp at only just 0,9 bar (13 psi). Enough talk, some pics/descriptions
Ast (aragosta) coilovers ttt top hats: GK-tech knuckles with custom adapters for the endless calipers, Powder coated Nagisa Auto flca's, Manatee racing rlca's, ruca's, Ikeya formula toe rods: Next miracle cross bar: Engine bay: Garage Kagotani carbon diffuser Vinyl wrap carmine red: some pictures from last sunday. sits a bit high atm Last edited by R@tch; 11-24-2013 at 02:42 PM.. |
