Old 10-19-2010, 05:59 PM   #1
lrb99
lrb99 is an unknown quantity at this point
KA KA I need a ka-t kit or parts.....................
no crazy expensive stuff be reasonable and must have pics
I need a FMIC and piping , BOV , tuned Ecu , oil lines , gauges
WHAT I GOT SO FAR
T-25 Turbo and Bottom mount Manifold, Oil catch can , Fuel pressure Regulator , Oil pan w/welded bung
lrb99 is offline
Old 10-19-2010, 06:14 PM   #2
satal95
satal95's Avatar
Trader Rating: (24)
satal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud ofsatal95 has much to be proud of
Feedback Score: 24 reviews
Have a holset setup only missing the dwn pipe. Decided to go a different route
Signature image exceeds allowable size.
satal95 is offline
Old 10-19-2010, 06:17 PM   #3
nismo91blk240sx
nismo91blk240sx's Avatar
Trader Rating: (22)
nismo91blk240sx is an unknown quantity at this point
Feedback Score: 22 reviews
I have an emance ecu tuned for a t3 turbo/550cc injectors/z32 maf
nismo91blk240sx is offline
Old 10-19-2010, 06:23 PM   #4
revolutionz_s13
revolutionz_s13 will become famous soon enoughrevolutionz_s13 will become famous soon enoughrevolutionz_s13 will become famous soon enoughrevolutionz_s13 will become famous soon enoughrevolutionz_s13 will become famous soon enough
I have an emanage ultimate ecu, brand new. Very solid ecu, however not enough for the 1000cc injectors im running. $400 obo
From the GReddy site:
The GReddy e-manage Ultimate is as close to a stand-alone management system as you can get while maintaining the best features of a "piggy-back" engine management; an economical price, the usage of existing sensors, the ability to easily alter factory settings and not having to tune from scratch. But unlike the original e-manage, the Ultimate is more refined, requiring specific application usage (which we are constantly adding application updates that you can download FREE via greddy.com, Tech WebPages.) The benefit of this is, the included PC-based USB "Ultimate Support Tool" allows for even finer tuning capabilities, improved flexibility in fuel & ignition control and adds impressive data-logging qualities to make tuning quicker and easier. The increased number of input and output ports of the Ultimate, along with new built-in adapters add many new options to the unit. In addition to standard e-manage airflow-based adjustments, the Ultimate version includes new and upgraded features. The Parameter Set-up, tab menu format of the Ultimate has improved direct Map control for adding and subtracting Fuel and Ignition. The ability to switch between 2 preset tuning Maps (i.e. Street or Race program) via externally mounted toggle switches. There are Maps for Individual cylinder adjustment for both Fuel and Ignition. There are also options to convert injection and ignition systems (i.e. group or sequential injection and group or individual fire ignition.) An Airflow Output Map option even allows for airflow meter elimination. And when used with a wideband A/F Meter, the Air Fuel Target Map can self-tune an Injector base tuning Map, to speed up initial tuning. There are also built-in Boost, Rev and Speed Limiter-Cut features. To create super smooth operation, there are various fine tuning Correction Maps to adjust for Throttle Acceleration, Vehicle Speed, Water Temp, Intake Temp, Auto Trans Shift, Anti Engine Stall, and Idle. To further aid in tuning, e-manage Ultimates improved integrated Monitoring, Map Tracing and Datalogging features far exceed any other piggyback controller on the market. Even when not connected to the software, 8 channels of datalogging (at 20msec intervals) can be recorded and stored to be reviewed later. With the Support Tool connected, over 30 channels can be covered. Other new features include: Improved RPM recognition, Warning Settings, Password Protection for individual tuning Maps, NVCS (Nissan), VTEC (Honda), O2 Feed-back, Clean Fouled Plugs, and numerous others in future updates. Ideal for optimizing and fine-tuning for performance products like Exhaust, Air Intake, Intercoolers, Boost Controllers, and Turbochargers, the e-manage Ultimate fills the gaps between conventional piggyback and expensive stand-alone engine managements. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some or all functions may not be compatible with some applications.)
revolutionz_s13 is offline
Old 10-19-2010, 06:33 PM   #5
Walperstyle
Walperstyle's Avatar
Walperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really niceWalperstyle is just really nice
Send a message via MSN to Walperstyle
Not to destroy the dudes sale, but I'd rather run a AEM<motec<viipec just from the tuning aspect.
Go to AMS's site and consider getting a full rebuild kit if you want to do it right. Also get overbore pistons and get the machine shop to match your block to the pistons and crank. Get oversized bearings too for the same reason.
Do it right, or don't do it at all.
KA-T ORG-Function over Flush
Walperstyle is offline
Old 10-19-2010, 07:34 PM   #6
lrb99
pics thank you
lrb99 is offline
Old 10-19-2010, 07:41 PM   #7
lrb99
I completely agree Im just looking for a turbo kit to have to fit my car get it all mounted before winter then pull my motor and wrench on it all winter long by summer my shit will be done right . thanks good shit man
lrb99 is offline
Old 10-19-2010, 07:43 PM   #8
lrb99
hello fellow xceeder pics and price
lrb99 is offline
Old 10-19-2010, 08:22 PM   #9
tix240
tix240 is an unknown quantity at this point
I'gve got a garret T3 / 04 turbo, efi specialists tune, tuned for 740cc injectors, z32 mafs and the t3. and I've got everything you need except the mafs...
if yer interested pm me
tix240 is offline
Old 10-19-2010, 08:35 PM   #10
lrb99
you got a pm
lrb99 is offline
Old 10-19-2010, 09:14 PM   #11
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
i've got 450cc injectors brand new lmk
upsdude is offline
Old 10-19-2010, 09:56 PM   #12
matts13vert
matts13vert's Avatar
Trader Rating: (31)
matts13vert is an unknown quantity at this point
Feedback Score: 31 reviews
ive got an oil restrictor brand new .062"
matts13vert is offline
Old 10-19-2010, 10:28 PM   #13
Righthand180
Righthand180's Avatar
Righthand180 is an unknown quantity at this point
Send a message via AIM to Righthand180
You have a PM
"She may not look like much, but she's got it where it counts, kid."
Han Solo
Righthand180 is offline
Old 10-20-2010, 12:49 AM   #14
satal95
satal95's Avatar
Trader Rating: (24)
Originally Posted by lrb99 View Post
pics thank you
Will get you pics later on today but this is what it will come with.
holset h1c
jgs manifold
oil lines and adaptors
nissport oil adaptor
oil feed sandwich just in case you need more oil ports
38mm tial wastegate
IC setup
550cc dw injesctors
efi specialist tuned ecu(z32 maf, 550 injectors and for a t3/t4 setup)
z32 maf
aftermarket down pipe and 5 bolt o2 housing(just in case you want to change to a more common style t3/t4)
rfl bov
tapped oil pan
also have a brand new aem uego and some extra gauges that I could include also.
satal95 is offline
Old 10-20-2010, 08:51 PM   #15
dRift_g0ddess
dRift_g0ddess's Avatar
Trader Rating: (44)
dRift_g0ddess is an unknown quantity at this point
Feedback Score: 44 reviews
Hey whats up I got a 2.5" v-band & clamp
turbo intake pipe with welded 5/8 bung (for valve cover breather) and 19mm-3/4 bung for recirc of bov
lmk
Friends don't let friends build SR20's. Have faith in your KA!!
dRift_g0ddess is offline
Old 10-21-2010, 03:53 PM   #16
lrb99
s13
lmk
i have a apexi filter already thanks the clamps are tempting but i'll wait
lrb99 is offline
Old 10-21-2010, 09:57 PM   #17
project7x
project7x's Avatar
project7x is an unknown quantity at this point
i have an oil line kit FS for your turbo. pm me if intersted
project7x is offline
Old 10-21-2010, 10:14 PM   #18
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
http://zilvia.net/f/sale-items/34792...ks-intake.html
http://zilvia.net/f/sale-items/34064...ale-1-3-a.html
i have engine hoist for rent
i do SR wiring
vutony is offline
Old 10-22-2010, 08:57 AM   #19
dRift_g0ddess
Trader Rating: (44)
my bad.. filter not included. just the pipe with the bungs. I also have a bnib cast turbo mani.. Cast Turbo Manifold 240sx Top Mount Ka24de S13 S14 S15: eBay Motors (item 200533540613 end time Oct-29-10 19:08:38 PDT)
i bought it, and never installed. this sets the turbo forward and allows room for the bmc, lmk
Old 10-22-2010, 10:27 AM   #20
trikk
trikk's Avatar
trikk is an unknown quantity at this point
I got a greddy turbo timer, and greddy profec B spec 2 boost controller, a set of 370cc injectors, greddy turbo elbow for t25/t28 and downpipe. HKS SS BOV, Front mount intercooler (no pipes). Let me know what you're interested in.
trikk is offline
Old 10-22-2010, 02:07 PM   #21
a-s-silvia
a-s-silvia's Avatar
a-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymorea-s-silvia is not welcome here anymore
Send a message via AIM to a-s-silvia
I have a sidemount off of an sr complete, a ebay mani, t25, sr370cc injectors, and an elbo with 1 broken stud make me an offer
[SIGPIC][/SIGPIC]
a-s-silvia is offline
Old 10-23-2010, 10:49 PM   #22
lrb99
ka-t kit
pics please
lrb99 is offline
Old 10-25-2010, 09:10 PM   #23
Ramenoodle
Ramenoodle is an unknown quantity at this point
you have a pm coming your way bro
Ramenoodle is offline
Old 10-25-2010, 09:28 PM   #24
lrb99
haha thanks man
lrb99 is offline
Old 10-28-2010, 12:50 PM   #25
xFix Kaos
xFix Kaos is an unknown quantity at this point
PM me i have an n60 maf with pigtail
Emance ECu tuned for 370cc injectors stock maf and t25 turbo
xFix Kaos is offline
Old 10-28-2010, 09:45 PM   #26
lrb99
interested in the ecu
lrb99 is offline
Old 10-29-2010, 09:54 AM   #27
xFix Kaos
i can do 200 shipped...otherwise im gonna keep it and use it on my Ka-t
Old 10-29-2010, 05:54 PM   #28
lrb99
I just got a t25 turbo and manifokd ,catch can and fuel regulator still need a FMIC and piping I also need a HKS bov and 370 injrectors and other pieces to finish my kit
lrb99 is offline
Old 10-29-2010, 05:58 PM   #29
lrb99
KA
with me just getting these other items it be a week or two to recoup some more cash but I think the ecu will be that last thing i'll get to ensure the correct tune thanks
lrb99 is offline
Old 10-29-2010, 09:25 PM   #30
whitenoise
whitenoise's Avatar
whitenoise is an unknown quantity at this point
Send a message via AIM to whitenoise
i have a SR greddy/trust downpipe with O2 bung welded on, all u need is to extend it a bit to fit KA-T. $100 + shipping
http://TM-SPL.COM
whitenoise is offline
