Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Tech Talk > Z Chassis
Z Chassis Technical discussion related to the Z Chassis such as the S30, S310, Z31, Z32, Z33 and Z34.
Old 06-06-2010, 02:20 AM   #1
swiftstyles
swiftstyles is an unknown quantity at this point
What should my oil pressure gauge read at idle?
300zx TT is all stock. Does this look ok?
swiftstyles is offline   Reply With Quote
Old 06-06-2010, 02:30 PM   #2
pat1
pat1 is an unknown quantity at this point
the stock gauge is a piece of junk. Mine is off bid time. Put a aftermarket and see what you get.
pat1 is offline   Reply With Quote
Old 06-09-2010, 01:24 PM   #3
TTnickdizzle
TTnickdizzle's Avatar
TTnickdizzle is an unknown quantity at this point
That looks a bit low... how high does it get over 4500rpm?? it should be above 60psi during higher RPMs.... and at idle is should be around the middle between the zero and the first line. If it drives strong and its not knocking the it could be your oil pressure sending unit going out.
TTnickdizzle is offline   Reply With Quote
Old 06-09-2010, 01:29 PM   #4
DeatschWerks
DeatschWerks's Avatar
DeatschWerks is making a name for him/her selfDeatschWerks is making a name for him/her self
For idle, that looks about right. But without having linear values on the gauge, it's hard to know for sure. Idle pressure should be around 20-25psi.
Chris @ DeatschWerks.com
Fueling Your Passion for Performance!
DeatschWerks is offline   Reply With Quote
Old 08-30-2010, 11:49 PM   #5
jmabo205
jmabo205 is an unknown quantity at this point
the stock oil pressure gauge won't get you an good reading, better to get a autometer gauge and see from that. But the stock should be around what deatschwerks said
jmabo205 is offline   Reply With Quote
Old 09-14-2010, 12:00 PM   #6
usafdarkhorse
usafdarkhorse's Avatar
usafdarkhorse is an unknown quantity at this point
Is the engine hot or cold?
That looks alright for a fairly warm engine.
89 Skyline GT-R / 70 240Z / 72 240Z / *sold* 91 NSX, 99 S15R, S30Zs
usafdarkhorse is offline   Reply With Quote
Old 10-22-2010, 11:12 AM   #7
Z32TT-R
Z32TT-R's Avatar
Z32TT-R is an unknown quantity at this point
Normal
Z32TT-R is offline   Reply With Quote
