Old 10-04-2010, 12:33 PM   #601
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Did you mean 7/16"?
Black R is offline   Reply With Quote
Old 10-04-2010, 12:47 PM   #602
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
If anyone needs a set of brackets, I have a new set of STI->S13 brackets.
Decided to go a different route and won't be needing them.
$100 shipped anywhere.
Blow me, bitches.
Slammed180 is offline   Reply With Quote
Old 10-04-2010, 01:39 PM   #603
lvlanolin
lvlanolin is an unknown quantity at this point
Originally Posted by Black R View Post
Did you mean 7/16"?
Lol yeah I did
lvlanolin is offline   Reply With Quote
Old 10-15-2010, 06:07 PM   #604
Black R
Black R's Avatar
Ok I went to ace hardware and matched up the caliper mounting bolts:
M12 x 35, 1.75 pitch. (m12 x 30 might work better)
I hope class 10.9 is ok...
Old 10-17-2010, 06:05 PM   #605
lvlanolin
Finally got the front brackets done!!! Well now I'm working on the back setup and as of right now, for the rear, I have evo brakes evo stoptech rotors and z32 ebrake assembly but the rotors don't fit with the ebrake assembly so I was wondering if the z32 stoptech rotors are the same diameter if so that should work with the setup right?
Old 10-26-2010, 07:25 AM   #606
Black R
Black R's Avatar
Oh and fwiw, those using evo calipers; the 03-06 brembos are different than the 07+
I have the earlier calipers (ct9a) - which is what most of us have...
Oh, and for the guy who said the outer mounts were wrong in that diagram; you're right! The spacing center to center of the caliper bolt holes should be 6 & 3/16", which is 157mm - not 155 like in that pic.
Old 10-27-2010, 06:42 AM   #607
badboy6686
badboy6686 is an unknown quantity at this point
Originally Posted by fueled by hate View Post
getting ready to do the swap tomorrow, finally got all the pieces to the puzzle. Couldn't have done it without the info in this thread.
Are these cts-v? they're sick.
badboy6686 is offline   Reply With Quote
Old 10-27-2010, 04:56 PM   #608
Black R
Black R's Avatar
Oh, and can anyone confirm the thickness of the bracket?
Is it indeed 1/2"?
I think I made mine a little too thick...
Old 10-28-2010, 10:33 PM   #609
xpinoyxmk
xpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura about
Totally forgot about this thread. This thread has actually saved me from rear ending someone.
Had my evo 9 brembo's on since last December. God do i love the stopping power i have now and they dont even have good pads lol. Z32 BMC probably helps with it though.
Also, i think i read that z32 conversion lines wont work with evo brakes?? Wrong i'm actually running them. Agency motorsports ones. Work fine, no leaks or anything.
Oh and they do attract a lot of attention lol, its nice though to know that when i use my brakes my car actually stops.
Can you see the brembos??
xpinoyxmk is offline   Reply With Quote
Old 11-09-2010, 07:16 AM   #610
Black R
Black R's Avatar
I'm just getting mine mocked up and I'm not thrilled with the thin area that the oem bolts have to thread onto once the bracket is the proper thickness: .5" to 3/8"...
The notches to clear the caliper ribs don't make me happy either.
I think I'll remake mine in a different L or S shape next time...
Old 11-09-2010, 09:03 AM   #611
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
Just now getting around to looking at my evo brembos; what size thread and pitch and length and hardness bolts do we need to use with them?
What bleeder screws also?
12x1.5 bolts
length depends on bracket and washer thickness being used
30 - 35mm is roughly where it'll fall
10.9 is as strong as it gets
it's what we supplied with the brackets we made
It's been well documented
z32 rear rotors is what you want to keep working ebrake
STi rears bolt up but pad thickness is less
Evo rear will need a bracket or re-drilling to fit
Is it indeed 1/2"?
1/2" is close but not perfect
STi and Evo actually require different thickness brackets
(hole spacing is also slightly off)
is the reason why we ended up making a bracket for each caliper specifically
with worn components - pads, rotors - 1/2" may work
but most likely fitting problems will arise with new parts
look at the calipers
z32 ones - front and rear - have a fitting inside ---> z32 lines
Brembos don't have the fitting, same as OEM ----> OEM lines
you may not have had a problem yet
or maybe never will but doesn't mean it's right
Hence the reason we kept the thickness uniform on our brackets
and told people to grind down the ribs on the calipers
shape is determined in great part by the amount of room to have there
ps. STi calipers don't need as much grinding as Evo ones
but Evo ones are oriented the proper way for pad wear
also STi calipers use a 12x1.75mm bolt which is a pain to source
we ended up contacting a bolt manufacturer and having a batch made specifically for the project
Old 11-09-2010, 10:15 AM   #612
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
Feedback Score: 82 reviews
Any one here just run def brake setup?
NEED Bolt kits for your car?
Old 11-09-2010, 10:52 AM   #613
Black R
Black R's Avatar
I'm thinking about switching to his setup.
I just bought evo calipers like a year before he made his kit.
I may dump my setup though and get onboard the def lightweight unsprung weight-saving train.
Old 11-09-2010, 12:06 PM   #614
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Only the prototype set has been made and it's on Def's hands
rest of the parts are still being machined
Old 11-09-2010, 01:29 PM   #615
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
Anyone know if R33 gts-t calipers can be used with z32 brackets to fit 350z rotors? Just wondering because i may go that route instead of this brembo thing since it seems to be kind of a pain in the ass.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 11-09-2010, 03:39 PM   #616
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
If the gts-t caliper work on z32 rotors on s-chassis then I don't see why they
wouldn't work with that set up.
Personally I would got with the Brembo set up just for the sexiness factor
but that's just the ricer in me
99% or cars don't need anything beyond z32 calipers
Old 11-09-2010, 08:35 PM   #617
revat619
Retired General
revat619's Avatar
Dude i couldnt agree more. I only want to do the brembo thing because it looks cool. I have 18 inch wheels with stock brakes and it looks terrible.
I was gonna go with evo front calipers and sti rear calipers with the Z32 ebrake set up, but all this talk of having to change brake boosters and finding the right lines and modifying brackets and all that other shit, i'm just not feeling it anymore.
I'm not sure if R33 calipers work on Z32 rotors. If they do then yeah i'll do that with the 350z rotor and z32 rears and powder coat them brembo brilliant gooooooold and paint the nissan letters red. There is absolutely no shame in my game.
www.Jspec.com
Old 11-10-2010, 08:41 AM   #618
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Ha ha, tell me about it
I'm getting ready to put STi Brembos front's and z32 rears on my daily S14
stock KA and automatic....
lol, but I have two sets of Brembos - Evo and STI - that we used when designing the brackets collecting dust
I'll probably also end up with a set of Def's Wilwood set up
and not to mention the z32 sets I've also collected through the years
so yeah, it's lame to put Brembos on the daily but might as well put to use the parts I got laying around
Old 11-10-2010, 10:51 AM   #619
Black R
Black R's Avatar
Cool
Well if you recall, I kept sending you pm's up until December of last year and you had put your bracket development on hold.
So I eventually got tired of waiting and got it done.
IMO, tower240's brackets would be what I'd buy had I to do it all over again... Just for the ease of bolting them on with no worries.
Old 11-11-2010, 08:28 AM   #620
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
sorry, I don't recall, I get a ton of 'interest' on stuff we've made
but brackets where available over 6 months ago
That's Mike's username on NRR
the other person I refer to when I say "the brackets WE made"...
Old 11-12-2010, 11:16 AM   #621
MrMcgarrett
MrMcgarrett's Avatar
Trader Rating: (313)
MrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfectionMrMcgarrett is close to perfection
Feedback Score: 313 reviews
Send a message via AIM to MrMcgarrett
The R33 calipers use bigger rotors than the Z32's so it wouldn't work.
MrMcgarrett is offline   Reply With Quote
Old 11-12-2010, 11:22 AM   #622
Def
Yea, I do. They're nice.
Seriously though, I have a prototype set. So far they've seen 500-550 track miles and holding up strong, about to get another 250-300 on them this weekend (leave in a couple of hours for Texas World Speedway - very high speeds).
The production run should be finishing up in the next week or so, then they'll be shipped out to everybody that participated in the group buy.
DEFSPORT
Old 11-12-2010, 02:49 PM   #623
godrifttoday
Trader Rating: (82)
DAM why did i get a house! lol i should have just hooked up my car haha
when will u do another group buy?
Old 11-12-2010, 03:34 PM   #624
Black R
Black R's Avatar
Well they're on, but I'm not pleased at having to use 10mm spacers with 25th anniversary 350z wheels...
I added some threaded bolts and tapped the small side at 10-24 bc I read some evo guys didn't like the tension pins that they normally use.
That being said, I think I'll put this setup fs so I can go with a wilwood setup.
Old 11-12-2010, 03:58 PM   #625
revat619
Retired General
revat619's Avatar
o ok. Yeah i thought they were different. Any idea how R33 rotors compare to 350z ones as far as size?
www.Jspec.com
Old 11-12-2010, 04:06 PM   #626
WISH ONE
Finally finished up my brakes last saturday after many months letting my car collect dust.
Custom billet half inch aluminum brackets, hardware, custom braided lines, 350z track rotors and a set of wilwood superlite calipers with pads is all you need.
not including any of the time it cost me, time is money lol.
Over all cost was roughly $590. for parts only
RevolutionBrake sells an entire kit almost identical to this for $800+ another alternative is to spend the $1000-1200 for the real deal and purchase the wilwood kit.
Ill post more pics when i get a chance.
Old 11-12-2010, 04:28 PM   #627
revat619
Retired General
revat619's Avatar
^^^ Sexual.
www.Jspec.com
Old 11-24-2010, 09:42 AM   #628
ixfxi
ixfxi's Avatar
so whos going to be the idiot to install R35 calipers on their S13.
when its all said and done, you could probably just buy an actual brembo GT big brake kit new, for less money
Old 11-24-2010, 08:13 PM   #629
lvlanolin
I managed to get my evo front brakes on with the same 350z wheels and i didn't need a spacer, I mean its close but it clears
Old 11-25-2010, 08:24 PM   #630
MrMcgarrett
The R33 rotors are 296mm in diameter and the 350Z Rotors are 324mm.
