#3271 |
![]() Join Date: Oct 2007
Trader Rating: (53)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 53 reviews
ABS master cylinder only has two outlets, one for the front and one for the rear. from there it goes to the ABS unit and the outputs of that go to their respective brake calipers. if you try and use the ABS master cylinder without the ABS unit then one of your front calipers wont be hooked up. you need to find a non-ABS master with three outlets.
#3272 | |
#3277 |
![]() Join Date: Jul 2007
![]() Feedback Score: 8 reviews
randomly i hear this 'click' coming from the lower right part of my dash. if im in the drivers sear i hear it from the area of the headlight retract button. it sounds like a tick of a clock. when it happens it might happen, then again 3 seconds later, then nothing.
anybody have any ideas what this could be? its not something stupid like my keys rattling. car is a stock 91 s13 coupe with stock ka24de. |
#3278 | |
@pwrmves14 |
#3279 |
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
What kind of hoses are people using for this GT oil drain? Power steering or fuel hose maybe???
http://www.treadstoneperformance.com...65-0-thumb.jpg
#3280 |
![]() Join Date: Oct 2009
SR Intake manifolds??
Just curious, Are the S13 SR Intake manifolds and S14 SR Intake Manifolds interchangable? Wondering if an S14 would work on an S13 Sr20det? Is either one better? Thanks.
#3283 | |
![]() Join Date: Nov 2007
sounds like something is turning on, are you running ac/heater? cd player maybe....doest it do it when your not driving? like car sitting on, or car sitting off. |
#3285 | |
please delete your post, and google each word separate. a dictionary will help your answer. fucking is an exaggeration in this text. and classy is like fancy. like opening a door for a pretty lady.... watch some james bond movies...he's all about class. and yes, i'm aware of the language barrier. |
#3286 | |
![]() Join Date: May 2010
lol. i knew what each word meant, i jst thought it would mean something different but thanks lol
#3288 |
#3289 | |
front suspension - yes, if you drill the lower mounting holes bigger to fit s14 bolts or don't drill and use sleeves for the 13 bolts cross member - yes power brace - no
#3290 | |
I'm asking because I have a newly rebuilt S13, needing only cosmetics, but I've been thinking of going to a S14....right after I should my conversion harness for pennies, figures. |
#3291 | |
you can swap a 14 s/f to a 13 and vice versa, but you need offset bushings to do it right. people swap a 14 s/f to a 13 because of the way the rear end works on the 14 and it's a little wider. when you launch a 13, the rear wheels camber in during the squat whereas a 14, the rear wheels tuck straight up leaving more rubber in contact with the road. so swapping a 13 s/f into a 14 would be more of a 'downgrade'.
#3292 |
![]() Join Date: Dec 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
quick question, are the front lower control arms for the s13 and s14 the same or is there a difference? i heard the s14 arms for are longer, but dont how true it is..
#3294 | |
I figured it would be a downgrade since I've found the S14 into S13 stuff. My sub is stripped and recoated, PBM bushings, welded diff, poly bushings in knuckles and arms. It'd be a pain to do all that all over again. |
#3295 |
![]() Join Date: Feb 2010
No no no.. Not some crazy color?! I want to change it from the rare navy blue to black. Thats not outrageous but just simple. Any certain brands for vinyl paints?
#3296 |
no its not anything like that, not running a/c or heat, i have no dc player. It only happens when car is running, im not sure about it happening with the car just "on" i.e. engine not running.
#3298 |
![]() Join Date: Dec 2008
Trader Rating: (79)
![]() Feedback Score: 79 reviews
Do KA Single Cam Spark plug wires work on a Dual Cam KA?
My Build: The "Coupe De Ville" 1JZ Build!! |
#3300 |
Tags |
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki |
