#3301 |
#3304 |
everything I've read says that S14 FLCAs are 10mm longer than S13 ones.
#3307 |
![]() Join Date: Dec 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
ok i was just wonering cause it seems everywhere you look you see s13 control arms selling for like 100 bucks for bth new and s14 be like 200 each.. i wanted to know if there was a difference cause they look the same to me and i heard they are interchangeable.. so you couldn't use the s13 with s14 ball joints?
#3308 |
![]() Join Date: Feb 2010
![]() Feedback Score: 19 reviews
My rear caliper leaks and when it goes low I just refill the master cylinder. It went low and I filled it but now I've lost all pressure in my brake pedal. I'd have to press it to the floor for it to work. I've been pumping the brakes to get fluid back into the system but the pressure still isn't back. The cylinder worked fine before this. What else can I do to return the pressure?
#3309 |
AEM Oil Temp Gauge in an Greddy Oil Filter Sandwich plate.
What adapter do I need to get this to work? From searching I have found that the AEM is 1/8 NPT (along with 2 other larger adapters) and that the Greddy may be in BSPT. There are two ports in the Greddy Oil Sandwich that may be used, I'm guessing one is a 1/8 BSPT and the other is larger. Can anyone confirm, or add to this information? I'm looking for an adapter. Thanks!
'89 Sil80, SR20DET, GT2871r .64 |
#3310 | |
#3311 |
Can someone tell me the thread pattern of the s14 godspeed rucas, the male heim joint part.
Nothing says racecar like a stock car with no interior. |
#3312 |
The pressure in my pedal was fine when it was leaking. I go out to drive my car today and I lost all the pressure. It was working fine yesterday. I just need a quick fix to get the pressure back so I can drive to school. Still looking for a new caliper so yeah.
#3313 | |
Bleed the system real good, but air will get in the system again once you start to use the brakes. Really, there's no temporary solution that I'm aware of.
#3314 |
does anyone know where I can get 3 mm brake pad spacers for q45 brake conversion or any information on how to make them. I did a search on google and zilvia and couldnt find the information i need.
#3315 | |
![]() Join Date: Dec 2008
![]() Feedback Score: 35 reviews
Ive never heard of spacers being needed.
-Jorge |
#3316 |
Hmm.. It's been leaking for a longg time though. Its a really slow leak, the idiot light for the brakes only came on twice since I've had the car and its been about six months. The pedal was fine before this but I'll bleed tomorrow and see how that goes. Since its only the passenger rear would I have to bleed all four corners or just the problem side?
#3317 | ||
#3320 |
[QUOTE=axiomatik;3722148
If it only pulled in air at the caliper, you may be able to just bleed that line. If it pulled in air from the reservoir from the fluid getting too low, you will have to bleed the whole system. Bleed the one corner and see how it feels.[/QUOTE] Lucky me its the side you start out with first when you bleed the whole system. I'll do that today when I get home from school and update. Thanks. |
#3321 | |
AFC #1
![]() Join Date: Oct 2003
#3322 | |
will this part work???
#3323 |
![]() Join Date: Jun 2009
Hi all, Does anyone knows if the rocker cover bolts that goes in the center are all the same in all KA24DE engines or only are the same in the 240sx's
i know the s13 has 3 bolts in this place on the rocker cover and the s14 has 2 bolts |
#3329 |
gas-charged shocks usually use nitrogen, so it won't combust, but super heating the gas will likely make it rupture violently. pV=nRT
#3330 |
![]() Join Date: May 2009
how bad is this damage?
![]() ![]() no it doesnt affect the way i drive for those who ask does any one know a shop that repair this?
My Daily Driver |
