11-11-2010, 07:41 PM | #62 |
sure i'll source it myself and find out the truth
11-12-2010, 04:43 PM | #64 |
i'm just going to list one of the manufacture for this cheap turbos
Okiya Group Co., Ltd. CME Turbo Co., Ltd. Wa-Line Industrial Co., Ltd. Hangzhou Changzhi Parts Co., Ltd. in the end there's one that supplies for you and made it for you. i'll post after i call them thanks i dont need google when i know how to source them out
11-12-2010, 05:39 PM | #65 |
Bro, you don't have to be a dick. This should've been handled in PM. You're really not acting like a Premie treating a vendor like this. Try to be more respectful before you know the truth.
11-12-2010, 10:13 PM | #67 |
i'm going to leave this as is
quality assurance over production creates a better product
11-13-2010, 07:43 AM | #69 |
11-15-2010, 01:13 PM | #71 | |
Sorry it wont, but we will have the rebuild kit. Max boost @25psi |
12-09-2010, 05:40 PM | #73 |
Im curious as to why the 18g is the only turbo that has actual dyno results posted and why it seems like this is the one being advertised the most? Are your other t25/t28 turbo setups for the SR and KA not as reliable? Post some dyno's and more info up about them and im sure they would get much more respect.
12-09-2010, 06:59 PM | #74 | |
Cause the 18G is pretty new for some customer so that why we doing more advertise for this turbo, and the 18G is good for people want little more power without upgrading any other parts. Yea....I have this Dyno sheet for a while but dont really have time to upload it this is on our Race Car as well(old setup) S14 Black Top CP Piston Carrillo Rod BC CAM Godspeed intake manifold Stock turbo manifold open wastegate Low Boost @ 15 Hi Boost @ 23 btw this is out T28 Turbo |
12-09-2010, 07:37 PM | #75 |
Is the leftside graph the 15psi and the rightside graph the 23psi?
Should this t28 honestly be capable of running consistent 23psi runs??...Seems extremely steep. |
12-13-2010, 04:45 PM | #76 |
Im in for some long term reviews from the test car owner and other people who have run this turbo.
BX|Photo LS400 - Slammed | Fitted | Loud |
12-14-2010, 01:03 AM | #77 | |
Trader Rating: (37)
Feedback Score: 37 reviews
when will the td06 20g bottom mount come out also will it work for a ka-t bottom mount and how much |
12-14-2010, 11:01 AM | #79 | |
I have this on the other thread but the mod. close it here is the video YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 1st Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 2nd Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 3rd Pull YouTube - Godspeed Time Attack 240SX S14 18G Turbo Dyno 4thd Pull thanks |
12-17-2010, 11:35 PM | #80 | |
12-17-2010, 11:48 PM | #81 |
im about 25 track events later and some daily driving with my TD05 and it still has ZERO shaft play. i say this turbo would be a BEAST on a KA or a high boost SR it is a little laggier i make full boost of 15psi bout 3800 but nothing a clutch kick wont fix
12-24-2010, 06:03 PM | #84 | |
Pretty sure the stock wastegate ~14.5 psi will give you the 300. |
12-24-2010, 06:20 PM | #85 |
Now if only we can find out whether it needs a restrictor or not. Im about to order this turbo and want to order everything needed at once for a reliable install.
12-24-2010, 07:05 PM | #86 |
no restrictor in my car i made 305 to the wheels at 15psi. full boost around 3800, but youd probably see it sooner with a stock intake manifold. id say around 3300-3500
01-06-2011, 01:51 PM | #89 |
Dam this looks promising - When I go Ka-T I'll def hit up GSP!
Rirey your bay looks nice can't wait to see you breath fire!
Yeah.. Umm no.... Rules Violation |
01-12-2011, 09:00 PM | #90 |
would the factory injectors flow enough for that 18g? I've read that 220hp is about the max you should put them since they would be at a duty cycle of 95%
anyway I may consider giving this turbo a try once I hear more testimonials from others.
'78 280Z-LSx|76mm turbo|1840cam|8.8 Diff |
