Old 12-18-2010, 06:18 PM   #1
matts13vert
matts13vert's Avatar
Trader Rating: (31)
matts13vert is an unknown quantity at this point
Feedback Score: 31 reviews
KA Street Faction's “Spirit of Fortune” S13 Vert (Socal Dream Super Stock KA-T Setup)
2014-08-04: FORWARD TO PAGE 7 FOR UPDATED SETUP.
A few months ago, I decided to turbo my KA, but only if I can get it to look as factory as possible, so no shiny piping or flashy parts. I wanted this to look 100% STOCK. Luckily, a guy on Craigslist was selling some turbo parts from an SR, so I swooped them up on my way to Formula D (Beginning of October 2010). It took me about two months to find and buy all the parts, then the build started (Beginning of December 2010).
All the parts used:
-T25 Turbo
-SR Manifold modified to be used on a KA with Stock SR Heat Shield
-370cc Injectors
-SMIC w/ Intercooler Piping and OEM air duct
-Greddy 3" Elbow
-3" Down Pipe
-S14 Upper Intake Manifold with plugged PCV Ports
-PCV system modified using one check valve, tee, and oil separator
-NISSPORT Oil Pressure Adapter
-Mishimoto Radiator with Dual Electric Fans (painted black)
-Hayden Automotive Fan Controller
-R.S. Enthalpy Tuned Ecu (T25, N60, 370cc)
-Walbro 255lph Fuel Pump
-Blitz DD Blow Off Valve Recirculated (painted black)
-S13 SR20DET OEM Intake Box
-JGS Motor Mounts (rubber)
-Nismo Type B FPR
-Z32 Fuel Filter
-NGK BKR7E Spark Plugs
-Isis FPR Adapter
-Greddy 36mm Radiator Temp Switch Adapter
-Bosch Spark Plug Wire Set
-N60 MAF
-Circuit Sports Thermal Plenum Intake Gasket
-Circuit Sports Magnetic Oil Drain Plug
-Innovate 3833 Turbo Timer w/ Wideband
-XTD Stage 3 Clutch
Extras Installed
-DIF Solid Aluminum Steering Bushing
-Energy Suspension Polyurethane Steering
2009: 17x8 / 17x9 Volk/Manarays, Cusco Comp-S Coilovers
2010: 18x10 XXR 521’s, PBM Pro Coilovers, Sleeper KA-T (210 WHP)
2011: 18x10 AME TM02 Tracers, Fully Built KA-T (350 WHP)
2012: 18x10 Work Bersaglio, Fully Built KA-T (350 WHP)
matts13vert is offline   Reply With Quote
Old 12-18-2010, 06:20 PM   #2
Razi
Razi is an unknown quantity at this point
Very nice setup!
You should get a T28 later down the road, I love my S15 T28.
Razi is offline   Reply With Quote
Old 12-18-2010, 06:24 PM   #3
98_240sx_se
98_240sx_se is an unknown quantity at this point
matt, your setup is so nice and clean!
ps guys, im alex from nico lol. i did the welding
thanks again matt
98_240sx_se is offline   Reply With Quote
Old 12-18-2010, 06:40 PM   #4
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
wow , you really did achieve the stocking looking ka-t
props man
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 12-18-2010, 08:03 PM   #5
1on1
1on1's Avatar
1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all1on1 is a name known to all
hmmm makes me want to go ka-t because i want that stock looking feature.
instagram
1on1 is offline   Reply With Quote
Old 12-18-2010, 08:11 PM   #6
turbotofu
turbotofu's Avatar
turbotofu is an unknown quantity at this point
O_o nice sleeper setup!
turbotofu is offline   Reply With Quote
Old 12-18-2010, 08:31 PM   #7
HPKMotorsports3
HPKMotorsports3's Avatar
HPKMotorsports3 is an unknown quantity at this point
nice job man... post some numbers up and possibly a vid...
Originally Posted by shiftdrift View Post
you running on hopes and dreams?
HPKMotorsports3 is offline   Reply With Quote
Old 12-18-2010, 08:44 PM   #8
STEEZxIT
STEEZxIT's Avatar
STEEZxIT is on the path to ruinSTEEZxIT is on the path to ruin
wheres the "like' button when you need it. good stuff, let us know how it goes if you ever get pulled over...
@dangerdamian
STEEZxIT is offline   Reply With Quote
Old 12-18-2010, 08:45 PM   #9
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Verrry nice. Im impressed
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 12-18-2010, 08:47 PM   #10
matts13vert
Trader Rating: (31)
Originally Posted by Razi View Post
Very nice setup!
Thanks! I might consider that down the road but for now I'm very happy.
thanks again matt
Thanks Alex. If anyone wants more info on the manifold pm this guy he is the one that modified it to work on the KA.
props man
Thanks!
You should do it the manifold is the final touch makes it pretty much stock.
Thanks!!
Thank you. Hopefully I will get some numbers up soon to see where its at and ill post vids when I can.
Will do hopefully they cant tell the difference.
Thanks
Old 12-18-2010, 08:48 PM   #11
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
this is very cool. it even involves a heat shield on the exhaust mani!!!!
good work!
@UpshiftEngineering
KoukiMonsta is offline   Reply With Quote
Old 12-18-2010, 08:50 PM   #12
s13 drifta
s13 drifta's Avatar
Trader Rating: (105)
s13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enoughs13 drifta will become famous soon enough
Feedback Score: 105 reviews
I really like the manifold idea. Looks good.
PM me for s13 or s14 parts!
s13 drifta is offline   Reply With Quote
Old 12-18-2010, 10:07 PM   #13
Nick_04K
Nick_04K's Avatar
Nick_04K is an unknown quantity at this point
Wow! Nice job haha. By far the most OEM looking KA-T i've ever seen.
Would love to have this! But more pics of your vert please! Maybe some video??
Nick_04K is offline   Reply With Quote
Old 12-18-2010, 10:21 PM   #14
eklips3
eklips3's Avatar
you notice a difference with the DIF solid aluminum steering bushing ??
Old 12-18-2010, 10:22 PM   #15
psychos13
psychos13's Avatar
psychos13 is an unknown quantity at this point
Nice set up...
But y stock looking?
psychos13 is offline   Reply With Quote
Old 12-18-2010, 11:12 PM   #16
STEEZxIT
STEEZxIT's Avatar
if im not mistaken, i saw you car at the anaheim K1 Schassis car show/meet. correct?
yeah. there was a coupe there with KA-T, but he had aftermarket mani and piping. but they were all paint flat black, and from what he told me, cops let him pass being dumbfounded and stuff... cuz of his stock intake box an what-not, but i think yours looks much more stock than his, maybe clean up that intake piping and that zipties...other than that, it would def fool a newbie fan boy if you play your game hard. lol good shit though man.
@dangerdamian
Old 12-18-2010, 11:19 PM   #17
rob22
rob22's Avatar
Trader Rating: (50)
rob22 is an unknown quantity at this point
Feedback Score: 50 reviews
same set up im going with.!
good stuff.!
wtb s14 roof wing/spoiler! pm me
rob22 is offline   Reply With Quote
Old 12-18-2010, 11:21 PM   #18
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I dig this...I get a kick out of the 'stock looking' engine bay...keeps the authorities guessing right!
Awesome on the factor manifold conversion. I will undoubtedly use a stock FWD sr manifold on my next turbo altima!
Old 12-18-2010, 11:29 PM   #19
Razi
Haha that was me.
Yeah, even with my half-wrapped Megan manifold and painted pipes he let me go.
This setup will fly under the radar no problem!
Old 12-19-2010, 12:30 AM   #20
STEEZxIT
STEEZxIT's Avatar
^^^yeah clean coupe bro.
yours and the OPs are pretty dope set-up, considering its mostly OE stuff and under the radar type...but you did have a front mount, OP still have the sidemount..still dope though. i like.
@dangerdamian
Old 12-19-2010, 01:02 AM   #21
junn
junn's Avatar
junn is an unknown quantity at this point
Nice work
But I don't see the hot pipe
junn is offline   Reply With Quote
Old 12-19-2010, 01:07 AM   #22
Razi
Thanks!
Matt, I just noticed your radiator is painted! I was thinking about doing that to my Koyo. Super stealthy man! haha.
Old 12-19-2010, 01:08 AM   #23
matts13vert
Trader Rating: (31)
good work!
Yup thats what I wanted stock manifold with the heat shield. Ultimate sleeper lol.
thanks!
Thanks, I'm happy you like it.
Im happy with the result it truly does look OEM. I'll post more pics and future videos in this thread soon.
Yea I noticed a difference with the solid there is no play when you turn the steering wheel side to side while you moving at a decent speed. I recommend it. the feedback from bumps is much greater but I dont mind the aggressive ride.
Originally Posted by psychos13 View Post
Nice set up...
I just wanted a low-key setup to fly under the cops radar.
Yea I was at the k1 meet I ended up taking the trophy for best wheel fitment home that day. I dont think I saw that coupe, I cant remember. Are their any pics of his bay? He got lucky lol I'm curious to find out if the cops will know its turbo or not. But I'm not about to go get pulled over on purpose just to find out lol
The zip ties are all gone now, only thing i need to do is clean up the intake piping or paint the couple black.
Thanks for the feedback!
good stuff.!
Good luck man.
Hell yea hopefully they wont even think twice about the engine being modified. Sweet let us know when you do that I'd like to see how that comes out.
Haha that was me.
You got any pics of your set up? I'd like to see what Steezxit is talking about.
I considered front mount but still thought it was too noticeable so I went with side-mount route, I found an OEM duct for it so that made me lean towards the SMIC too haha
Originally Posted by junn View Post
Nice work
Look closely under the cold pipe coming out of the SMIC.
Thanks!
Yea just hit it with some Rustoleum flat black and your golden haha
Old 12-19-2010, 01:20 AM   #24
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
holy shit....hella low key, welds are nice as well..
S-Nation S13 is offline   Reply With Quote
Old 12-19-2010, 01:22 AM   #25
mkezzo16
mkezzo16's Avatar
mkezzo16 is an unknown quantity at this point
Def likin the setup, if I dont go rb20, i'll be going with a similar setup
mkezzo16 is offline   Reply With Quote
Old 12-19-2010, 01:49 AM   #26
Razi
My engine bay from the 1st K1 meet.
I made my own "cooling panel" and painted it black to cover the front mount.
Currently, I got rid of all those vacuum lines at the front.
I might tuck my injector harness and stuff, and neaten up my fuel line stuff.
Old 12-19-2010, 02:38 AM   #27
doomviillain
doomviillain's Avatar
doomviillain is an unknown quantity at this point
Send a message via Yahoo to doomviillain
im jealous, this is what I wanted! good setup man, props
You are seventeen.
Your argument is invalid.
doomviillain is offline   Reply With Quote
Old 12-19-2010, 02:43 AM   #28
4DOOR_LIFE
4DOOR_LIFE's Avatar
i had to double take for a second. as i was scrolling down i go " wait where is the set up". haha then i looked over the pictures again.
nice work man. not often you see teenagers putting this much effort into a car and doing it right.
makes me miss my vert.
Instagram: @Elegant.Company
4DOOR_LIFE is offline   Reply With Quote
Old 12-19-2010, 02:51 AM   #29
rat240
Trader Rating: (87)
Feedback Score: 87 reviews
what is this car going to do
Old 12-19-2010, 03:09 AM   #30
JAYTRON
JAYTRON's Avatar
JAYTRON is making a name for him/her selfJAYTRON is making a name for him/her self
Send a message via AIM to JAYTRON
Oh I dunno, maybe like DRIVE and stuff?
JAYTRON is offline   Reply With Quote
