Old 01-02-2011, 07:28 PM   #1
obsolete
obsolete is an unknown quantity at this point
s14 Rearview mirror rattle with solid engine mounts
Those who made their own solid engine mounts, do you have a problem with your rearview mirror rattling while accelerating/cruising after putting them on? I'm thinking of getting a mirror that attaches to the windshield hoping it would solve it, but wanted to see if anyone has done this already. or if they have other ideas.
obsolete is offline   Reply With Quote
Old 01-02-2011, 07:54 PM   #2
Jaketenpointo
Jaketenpointo will become famous soon enoughJaketenpointo will become famous soon enoughJaketenpointo will become famous soon enoughJaketenpointo will become famous soon enough
Thats what makes solid mounts so cool. Vibrating EVERYTHING. Most people hate them.
But really, your mirror is going to shake no matter what. Mounting to the windshield won't help.
Jaketenpointo is offline   Reply With Quote
Old 01-02-2011, 08:00 PM   #3
deolio
deolio's Avatar
Old 01-02-2011, 08:03 PM   #4
PacificDrift_Nick
PacificDrift_Nick's Avatar
PacificDrift_Nick is an unknown quantity at this point
My car had a rubber piece that held the mirror against the glass and I had poly filled soilds no problem.
S13hatch
PacificDrift_Nick is offline   Reply With Quote
Old 01-02-2011, 08:03 PM   #5
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
The swivel joint on the mirror tends to become loose with age
that could also contribute to the shaking
on a note: why do people feel the need to run solid mounts?
Old 01-02-2011, 08:10 PM   #6
chiboy002
chiboy002 is an unknown quantity at this point
this.
the swivel gets super loose... there are a couple options
buy a new one
lift the mirror so that you can no longer use the "night time angle" option... meaning the bright ass lights behind you and night will just keep blinding you can that "angle" is the one you use 24/7
glue it (same problem as above)
glue it and buy a blue tinted overlay/mirror (broadview)
and that rubber thing.. i had mine and it sucked. If you fill it with 3/4 pennies it helps so much
street dancer.
GLEAM
Old 01-02-2011, 08:24 PM   #7
PacificDrift_Nick
Mine worked great
I ran simi solid because I intended to track my car and wanted to minimize engine movement
Old 01-02-2011, 09:26 PM   #8
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
lol solid mounts equal hella shake hahaha
S-Nation S13 is offline   Reply With Quote
Old 01-02-2011, 10:06 PM   #9
bc.
bc.'s Avatar
bc. is an unknown quantity at this point
I only hear bad things about solid mounts on sr's.
bc. is offline   Reply With Quote
Old 01-02-2011, 11:28 PM   #10
TwItCh
TwItCh is an unknown quantity at this point
Send a message via AIM to TwItCh
i dont like them for street use
TwItCh is offline   Reply With Quote
Old 01-02-2011, 11:34 PM   #11
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
because your running shitty mounts. My JGS mounts are amazing.
Bigsyke is offline   Reply With Quote
Old 01-03-2011, 12:35 AM   #12
daftphunk
daftphunk's Avatar
daftphunk is an unknown quantity at this point
I have stock mounts and ever since I did the SR swap, when driving at higher speeds my Rearview shakes out of place.. it sucks always having to adjust it.
I am aware the swivel gets old but is there any way to fix it without gluing?!
daftphunk is offline   Reply With Quote
Old 01-03-2011, 01:54 AM   #13
Bigsyke
Bigsyke's Avatar
Rubber or foam insulator on base and longer screws,
I also placed rubber expansion plugs in the firewall, as well as a solid rubber block screwed onto the firewall to see if it would absorb any energy resonated throughout the sheet metal, not sure if it helped since my rear view mirror only moved when it was really hot out, which is when the vibration was also at its least. That means its either greased or lubricated in some form. Must remove the lubrication.
Old 01-03-2011, 02:40 AM   #14
soreballz
soreballz's Avatar
Trader Rating: (22)
Feedback Score: 22 reviews
Do you have the rubber mounts or the poly mounts?
-Kyle
Old 01-03-2011, 06:02 AM   #15
obsolete
I did notice my swivel is very loose, but i felt it was the vibration in the arm part of the mirror that caused it. I guess one causes the other.
I didn't have to run solid mounts, just mine were really worn out so I just gave it a try rather than buy new ones.
I don't mind the overall noise in the car except for this part. it's pretty violent. actually, if the rattle was constant, i might not mind it as much, but it comes and goes depending on the RPM. highway cruising at 3k doesn't make the noise. just constant shifting on local roads sound gets annoying.
Old 01-03-2011, 07:10 AM   #16
nathanong87
nathanong87's Avatar
natelife.tumblr.com
Old 01-03-2011, 12:01 PM   #17
Bigsyke
Bigsyke's Avatar
Poly, but if I were to do it again I would use the rubber, and not use the supplied nuts.
Old 01-03-2011, 01:21 PM   #18
Z_Spool
Z_Spool's Avatar
Z_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura aboutZ_Spool has a spectacular aura about
Meh... my stereo makes it shake. You just learn to deal.
Z_Spool is offline   Reply With Quote
Old 01-03-2011, 01:30 PM   #19
phobs
Trader Rating: (60)
phobs is an unknown quantity at this point
Feedback Score: 60 reviews
Rubber piece thing, it's pretty chill.
phobs is offline   Reply With Quote
Old 01-03-2011, 01:40 PM   #20
obsolete
Where does one find something like that?
Old 01-03-2011, 02:00 PM   #21
phobs
Trader Rating: (60)
I found mine at the junkyard on a hatch.
Old 01-03-2011, 02:05 PM   #22
usdm180sx
usdm180sx's Avatar
There is a hole on the back of your mirror where you can adjust the tension with a thin phillips screwdriver.
-Norm!
Old 01-03-2011, 08:49 PM   #23
240KA
240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice240KA is just really nice
how come 240 people bitch about the vibration caused by poly mounts so damn much, yet they buy stiff ass bouncy coilovers? lurking honda-tech, i didnt hear as much bitching about the vibrations caused by stiff motor mounts.
240KA is offline   Reply With Quote
Old 01-03-2011, 09:00 PM   #24
chiboy002
why do you bitch about people bitching? Honda-tech is full of stupid thieves who prolly don't even realize the shaking
Phobs - off topic - but did you paint your interior white or is it just that shiny under all of it? It looks so sexy from the 3 inches i see lol
street dancer.
GLEAM
Old 01-04-2011, 02:47 AM   #25
phobs
Trader Rating: (60)
It's just gutted as of now. That's just the factory paint.
Old 01-04-2011, 04:41 AM   #26
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Vibrations from a stiff engine mount aint exactly the same as running on stiff suspension. Vibrations from an engine mount will be constant on 4 bangers as long as the engine is running. Atleast having a stiff suspension, you get a break when you drive slower and on smooth road surfaces.
But back to the OP, last thing you should be worried about your rear mirror. I had a buddy who's windshield rattled loose on solid aluminum mounts.
CLICK HERE!!!
Old 01-04-2011, 11:45 AM   #27
BoostSlideWayz
BoostSlideWayz's Avatar
BoostSlideWayz is an unknown quantity at this point
Send a message via AIM to BoostSlideWayz Send a message via Yahoo to BoostSlideWayz
Originally Posted by deolio View Post
^ pretty much all you can do.
1994 toyota supra...... n-a D=
1992 nissan 240sx KA24E-T fully Built =D
BoostSlideWayz is offline   Reply With Quote
Old 01-07-2011, 01:03 AM   #28
daftphunk
daftphunk's Avatar
Is this true? Haven't seen it in my S14 so not sure if it's an S13 thing.
Old 01-07-2011, 02:31 AM   #29
TheRealSy90
TheRealSy90's Avatar
I have solid aluminum blocks for my motor mounts.
I have a 5 panel wink mirror and it doesn't shake at all...
Such a good signature.
Old 01-07-2011, 06:59 AM   #30
obsolete
WINK MIRROR! so that's what those are called.
