Old 01-05-2011, 04:59 PM   #3931
Corbic
Corbic's Avatar
Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic Corbic
Originally Posted by codyace View Post
If you ever plan to modify it beyond stock, go SR20. If you ever want to keep it stock and drive it, go sr20. Yes, I said it that way on purpose. CA18 is just ancient junk IMO.
Not to mention a stock CA18 barely makes any more power than a KA24DE.
Corbic is offline   Reply With Quote
Old 01-05-2011, 05:06 PM   #3932
RedSiBaron
RedSiBaron is an unknown quantity at this point
i just bought my s13, and im getting a lot of extra road noise in the rear end of my s13, it gets MUCH MUCH MUCH quieter when i load the right rear...it sounds like a roar, ive slid under the rear end while its on the ground and didnt see anything visually and grabbed the drive axles and shook them and they didnt have any play, also the drive shaft looks like its newer, and in good condition...thoughts?
EDIT: also forgot to mention it gets louder with speed, does not seem to be gear related
RedSiBaron is offline   Reply With Quote
Old 01-05-2011, 05:13 PM   #3933
PITCH
PITCH's Avatar
PITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to beholdPITCH is a splendid one to behold
Also can the diff output shafts (the 5 or 6 bolt connection that bolts the diff to the axles) be removed?
If they are removed out of the diff, can I use a set of output shafts from an open diff? S14 Open diff output shafts into a J30 diff.
PITCH is offline   Reply With Quote
Old 01-05-2011, 07:46 PM   #3934
Wake
Wake's Avatar
Does anyone wanna trade a zenki 180sx bumper (with smic vent) for a Q's silvia bumper?
Clarification: I have a silvia bumper, I want the 180sx bumper.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 01-05-2011, 09:32 PM   #3935
arj
arj is an unknown quantity at this point
is it safe to use 8mm wheel spacers on stock studs?
arj is offline   Reply With Quote
Old 01-05-2011, 10:33 PM   #3936
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
As I stated on the last page, as long as they are the same type.
6 bolt must be in 6 bolt (5 in 5).
VSLD shafts (one long one short) must go back with VLSD differentials.
Open Shafts (both same size) must go back into an OPEN differential
(you can't mix and match them)
http://zilvia.net/f/chat/297481-smal...ml#post3806228
No. Search next time. Small Q thread doesn't mean 'dont' search and ask'
Old 01-05-2011, 11:11 PM   #3937
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Can someone who has a 240sx hatchback with the wing off take measurements for me and tell me at what points the holes are at?
I'm trying to see if a kouki 180sx hatchback has the same mounting locations as the USA 240sx hatchback.
Thank You!
Luvs2slide is offline   Reply With Quote
Old 01-06-2011, 09:26 AM   #3938
nevertheless
nevertheless's Avatar
nevertheless is an unknown quantity at this point
Im trying to figure out what turbo, injectors, and headgasket size to go with.
Heres my setup so far:
freshly built cp pistons/ eagle rods
arp headstuds
Tomei 270 procams
Tomei sold lifters
255 walbro
Jessefuckinwood
Street Prowl
nevertheless is offline   Reply With Quote
Old 01-06-2011, 09:32 AM   #3939
Corbic
Corbic's Avatar
arp headstuds
Tomei 270 procams
Tomei sold lifters
255 walbro
This is a "small question"?
Old 01-06-2011, 10:26 AM   #3940
smoked240
smoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymoresmoked240 is not welcome here anymore
Send a message via MSN to smoked240
Can't boost over .5bar. would it be better to run straight vacuum from the Intake manifold to the Boost controller? I turned the BC all the way open and can only hit .5 bar, then my hose came off my Intake tube how it's hooked up and hit 1bar. It's an s13 swapped rb25.
Also if I rev the car up and let the rpms drop it will shut all the way off unless is tap the gas to keep it alive. could this be lack of fuel? Right now I am running the stock s13 fuel pump, but I am going to be buying the 255. I was just curious if this is it?
smoked240 is offline   Reply With Quote
Old 01-06-2011, 12:18 PM   #3941
obsolete
obsolete is an unknown quantity at this point
yes. T-off the hose that goes from IM to FPR
Do you have the bov vented to atm? that might be one reason why.
obsolete is offline   Reply With Quote
Old 01-06-2011, 12:21 PM   #3942
obsolete
Should the a/c fan turn on when you turn the ignition to ON? never did this until i shut the engine off by pulling the coilpack harness. (don't ask me why)
Old 01-06-2011, 12:22 PM   #3943
nathanong87
nathanong87's Avatar
editdf fdasdfsad
natelife.tumblr.com
Old 01-06-2011, 03:54 PM   #3944
chiboy002
chiboy002 is an unknown quantity at this point
if i have a greddy oil cooler/diff brand oil cooler/sandwhich plate and what blitz gauges, for example, would the thread size/pitch be the same? Are they universal or do i need adapters?
street dancer.
GLEAM
Old 01-06-2011, 05:52 PM   #3945
roadster6909
roadster6909 is an unknown quantity at this point
I have an oil leak, but i cannot tell where it's coming from, please help!!
Here are more pics Pictures by roadster6909 - Photobucket
roadster6909 is offline   Reply With Quote
Old 01-06-2011, 06:46 PM   #3946
smoked240
Yes I do. That makes sense. well it's a turbonetic's raptor and I don't have the bottom port hooked up so after I re run my BC and hook up that port on the BOV and i'll see if it helps! Thanks man!
Old 01-06-2011, 07:01 PM   #3947
Mesarina
Mesarina's Avatar
Mesarina is an unknown quantity at this point
how do you load just the rear right tire?
Mesarina is offline   Reply With Quote
Old 01-06-2011, 08:25 PM   #3948
Wake
Wake's Avatar
your driveshaft probably needs to be balanced
S.P.P.S. Member #00
Old 01-06-2011, 08:26 PM   #3949
JKL1031
JKL1031 is an unknown quantity at this point
Mifune racing, anyone heard of them? they have a 2.5' exhaust I was looking at.
JKL1031 is offline   Reply With Quote
Old 01-06-2011, 08:52 PM   #3950
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
i cant figure out if this hood is sold like this or if it was made...if its sold, does anyone know who sells it...or one like it? thanks guys.
Imarvin240 is offline   Reply With Quote
Old 01-06-2011, 09:52 PM   #3951
codyace
codyace's Avatar
Trader Rating: (58)
Hard to say 100%, but do you have that dipstick tube in all the way? I usualyl use a screwdriver and hit it in all of the way.
Looks like a generic parts company reselling chinese made copycat stuff.
Old 01-07-2011, 12:46 AM   #3952
yingiang
yingiang's Avatar
yingiang is making a name for him/her selfyingiang is making a name for him/her selfyingiang is making a name for him/her self
im trying to ditch the electrics fans im running right now and use oem shroud/fan and im not entirely sure where to start. ive searched and cant find what i exactly need other than the obvious fan/shroud/fan clutch..but which one do i need for the sr?
and where the heck do i get the fan clutch and fan?
yingiang is offline   Reply With Quote
Old 01-07-2011, 07:02 AM   #3953
obsolete
For Sale section. KA and SR clutch fans are different though so get the correct one. it bolts to the water pump pulley.
Old 01-07-2011, 08:11 AM   #3954
Corbic
Corbic's Avatar
I bolted my KA fan blade onto my SR clutch, works fine, no issues.
Fan Shroud, Nissaparts.cc has them fir $25
Old 01-07-2011, 08:31 AM   #3955
roadster6909
[QUOTE=codyace;3815797]Hard to say 100%, but do you have that dipstick tube in all the way? I usualyl use a screwdriver and hit it in all of the way.
I dont think the dip stick would be causing it to leak that much oil, but ill give it a try.. You just hit it in? Or do you screw it in? Or..
Old 01-07-2011, 08:40 AM   #3956
5150james
5150james is an unknown quantity at this point
Recirc it. The anti-stall kit negates any benefit it claims to have. Get better mpg also. Running it plain on a maf car is a nightmare as it floats open and closed in vac.
Ok cool thank you. I've been searching for a picture or diagram for a week now as to see how to do it. Anyone know where I can find one? Or can explain how to recirculate it. I'm sorry I'm new to this.
5150james is offline   Reply With Quote
Old 01-07-2011, 11:25 AM   #3957
smoked240
You can just get some hose and connect it to the bov and run it back into your intake after the Maf sensor.
http://turboneticsinc.com/forum/turb...ypassValve.pdf
That is a link to the one I have but it should help explain how to recirculate it. It is down on page 2.
Old 01-07-2011, 11:44 AM   #3958
Ramonesfreak2010
Ramonesfreak2010's Avatar
Ramonesfreak2010 is an unknown quantity at this point
What goes in these two holes?
Circled in red.
Redtop SR20DET
EDIT: Realized its timing chain guide. Is that necessary?!
Ramonesfreak2010 is offline   Reply With Quote
Old 01-07-2011, 01:08 PM   #3959
codyace
codyace's Avatar
Trader Rating: (58)
Totally not needed, in fact I think there was even a TSB on it. KA's don't need it either.
Old 01-07-2011, 01:27 PM   #3960
arj
this part of my proppeller is leaking is this an easy fix or i gotta buy a new proppeller? this is my first 240sx and rwd so i dont have any idea.
edit: is it the Transmission Rear Seal Driveshaft need to be replace? if not whice one? thanks
