Old 02-11-2011, 02:14 AM   #4531
slow40sx
slow40sx's Avatar
slow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud ofslow40sx has much to be proud of
Send a message via AIM to slow40sx
Originally Posted by BLKTOPSR20DET View Post
quick question im doing a vlsd swap on my s13 and the diff is off a z32 can i also use the axles even if i am using the rear knuckles as well.
what? did u just ask if z32 axles work with z32 rear knuckles????
slow40sx is offline   Reply With Quote
Old 02-11-2011, 10:52 AM   #4532
ROUGE180
ROUGE180's Avatar
ROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfectionROUGE180 is close to perfection
Send a message via AIM to ROUGE180 Send a message via Yahoo to ROUGE180
It is my understanding that 89 240s didn't come with consult port. I've been researching BLAZT and other datascan programs. The all describe the cable being on the driver side near the fuse box under the steering area. I found this. What is this?
ROUGE180 is offline   Reply With Quote
Old 02-11-2011, 11:05 AM   #4533
irax
irax's Avatar
that kind of looks like the OBD1 connector but i'm not 100% sure
irax is offline   Reply With Quote
Old 02-11-2011, 11:49 AM   #4534
ROUGE180
ROUGE180's Avatar
That's what I was thinking. I mean it certainly looks like it and I've google image searched and when I put in "nissan 240sx obd1 connector" a similar pic comes up. Hmmmmm... maybe my car is a 90 and not an 89 as I thought.
Old 02-11-2011, 02:21 PM   #4535
Wake
Wake's Avatar
Single cams came with consult ports. You are misinformed.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 02-11-2011, 04:28 PM   #4536
mktachibana
mktachibana is an unknown quantity at this point
wonder if 17x9 +17 up front 18x9.5 +12 in rear will fit with just a roll. i dont want to rent a fender roller and end up needing to take it to the shop for a pull. Oh this is an s13 also. Thanks.
mktachibana is offline   Reply With Quote
Old 02-11-2011, 04:31 PM   #4537
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Pretty sure that's just California cars that had consult.
49 state cars did not, but stanza (u13) did.
e1_griego is offline   Reply With Quote
Old 02-11-2011, 04:36 PM   #4538
Wake
Wake's Avatar
Touche my good man.
I forget we set the standard sometimes.
S.P.P.S. Member #00
Old 02-11-2011, 08:25 PM   #4539
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
are s13 alternators interchangeable with s14?
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 02-11-2011, 11:00 PM   #4540
chiboy002
chiboy002 is an unknown quantity at this point
s13 driver side motor mount. The motor can't go up much more without crushing the seam on the fire wall (don't want that) and without my car getting off the jacks more. I can't get the motor mount off cause its such an awkward angle that i cant spin it or slide it since it hits the steering or the power steering pump.
How do most people get that shit off? The bolt is off the engine side, but i cant get it to come off the chassis side. Passenger side was a breeze
street dancer.
GLEAM
Old 02-12-2011, 12:32 AM   #4541
BLKTOPSR20DET
BLKTOPSR20DET's Avatar
BLKTOPSR20DET is an unknown quantity at this point
no i was asking if i can use the z32 axles with the vlsd on my s13 i know that the diff fits with some changes but not shure about the 5 bolt axles cause many ppl say you can and others say you could not but in my case im using the upright so not shure if the axles will fit.
BLKTOPSR20DET is offline   Reply With Quote
Old 02-12-2011, 01:18 AM   #4542
codyf44
codyf44 is an unknown quantity at this point
turbo elbow worth it on S14 zenki blacktop? with gt2871r
codyf44 is offline   Reply With Quote
Old 02-12-2011, 02:47 AM   #4543
Wake
Wake's Avatar
Your fucked, LOL
I usually take the bolts off the bottom first and pull the motor mounts with the engine.
LOL
SO your not sure if your z32 axles will fit in your z32 uprights while connected to your z32 diff?
Your losing me kid.
More/cleaner exhaust flow is always good on a turbo. Assuming your talking about an aftermarket replacement elbow.
S.P.P.S. Member #00
Old 02-12-2011, 08:46 AM   #4544
ROUGE180
ROUGE180's Avatar
Ahhhh so my car started out life in Curlyfornia eh? My born in date is 5/89
Old 02-12-2011, 10:57 AM   #4545
BLKTOPSR20DET
im asking if z32 axles will fit in my 240.
Old 02-12-2011, 11:19 AM   #4546
c72c
c72c's Avatar
Trader Rating: (25)
c72c is an unknown quantity at this point
Feedback Score: 25 reviews
they'll fit as long as the output shafts are the same.
c72c is offline   Reply With Quote
Old 02-12-2011, 11:21 AM   #4547
nothix
nothix's Avatar
nothix is an unknown quantity at this point
depends a lot on your tire size.
Check RimTuck.com for references
offset looks good to me, but you're gonna need to stretch the tires some.
225/245 maybe?
Originally Posted by Irresistible View Post
How do I remove the e-brake rubber/plastic boot trim thingy? I'm trying to get a "drift knob" button thing on that I got from itsproper!+ but I can't get the damn cover off to be able to remove the spring under it to install it correctly.
pull on it harder. Sometimes they can be a b*tch to remove
Also, try twisting it.
'89 Sil80, SR20DET, GT2871r .64
nothix is offline   Reply With Quote
Old 02-12-2011, 12:26 PM   #4548
BLKTOPSR20DET
many ppl are saying that one of the axles is a bit too long
Old 02-12-2011, 12:38 PM   #4549
chiboy002
Your fucked, LOL
i couldn't pull the engine, otherwise i woulda done that. In my frustration i over looked the bolts on the engine mount that connect the engine to the mount bracket.. i got that shit off in 10 minutes lol. I spend like 1 hour and bent the shit out of some screw drivers trying to pry it off
street dancer.
GLEAM
Old 02-12-2011, 02:51 PM   #4550
RedSiBaron
RedSiBaron is an unknown quantity at this point
ok, zilvia search function isnt working again and i need to guy buy this so i can change some axles out
QUESTION: What size 12 point socket do i need to remove rear drive axle nuts from the axles in the hubs of my s13? is it a 42mm?
thx
RedSiBaron is offline   Reply With Quote
Old 02-12-2011, 02:53 PM   #4551
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
Got it. Stopped being a bitch and pulled on it properly.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 02-12-2011, 03:28 PM   #4552
RHD95S14
RHD95S14 is an unknown quantity at this point
thx
I THINK it's a 36MM
RHD95S14 is offline   Reply With Quote
Old 02-12-2011, 03:57 PM   #4553
BLKTOPSR20DET
Originally Posted by RHD95S14 View Post
I THINK it's a 36MM
yea its a 36mm 6 point nut it has a cover in front of the nut with a cotter pin.
Old 02-12-2011, 04:38 PM   #4554
chiboy002
thx
the 12 point is just a cover. Like everyone said, 36mm 6 point and a breaker bar.
When i did mine, i jacked it up, removed the wheel and all that, then put wheel back on and set it on the ground without center caps on. Slip the socket on like that then do it cause the ebrake might not grip enough without being on the floor.
street dancer.
GLEAM
Old 02-12-2011, 04:40 PM   #4555
RedSiBaron
Oh so that goofy thing under the cotter key is a cover...I thought it looked big and goofy...smart thinking on nissans part to put a cover on there to keep out corrosion
Old 02-12-2011, 05:03 PM   #4556
BLKTOPSR20DET
it also keeps the nut from moving out of place
Old 02-12-2011, 05:09 PM   #4557
chiboy002
under the stock oil sensor there was a little allen-screw plug like the ones on sandwich plates/relocators.
Can i use this as a sensor tap or is it for something else?
street dancer.
GLEAM
Old 02-12-2011, 06:31 PM   #4558
RedSiBaron
Right, instead of having a castillated nut or having a notch to use a punch on
Old 02-12-2011, 07:09 PM   #4559
ms!3
i have a hicas with abs. i had to change out a spindle and the replacement didnt have the fitting for the abs sensor. it wont be up for a while so im wondering if ill have any problems with the brakes once i start driving it? lol i have no idea.
ms!3 is offline   Reply With Quote
Old 02-12-2011, 08:17 PM   #4560
C-unit
C-unit's Avatar
C-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to allC-unit is a name known to all
Does anyone know if S13 strut top has the same dimension as S14? I have some pillow top mounts from S13 and thinking of using it on the s14.
C-unit is offline   Reply With Quote
180sx type x kouki, 1jz, 2jz, 300zx, clutch, faq, ka24de, n/a, non-turbo, question, redtop s13 180sx silvia, s14, search, solenoid, starter, z32, zenki
